AleviDroid
Dauergast
- 583
Der neue Release-Thread für CM! Hier wird nur Changelog und Downloadlink gepostet!
Update:
28.01.2011 0.07-11.01.28
- proprietary files update (boot.img=>kernel, modules etc from SHOLS_U2_05.26.0)
- the infamous SMS bugs fixed (the OS version should actually read 2.2.2, sorry, I left 2.2.1 there)
- Greek support added to LatinIME 2.3 (including dictionary)
- ext4 module included (can be used to mount ext2 only - writing to journalled ext3/4 is not working correctly yet)
- new separate BPSW update.zip package (same as in SHOLS_U2_05.26.0/SHLA_U2_05.0C.0)
Downloadlink:
cm-6.1.2-0.07-11.01.28
Source:
android.doshaska.net | Nadlabak's little bits and pieces for Motorola Milestone and Android
Update:
Downloadlink:
Source:
