[ROM] [ICS] [2-11-12] CyanogenMod 9 Pre-Alpha Build 1.2 [ Unofficial ]
Keksööö
CyanogenMod 9 Pre-Alpha [ Unofficial ]
For Desire Z [ Vision - G2 ]
Build with CyanogenMod Git "Android 4.0.3"
Using 100% Cyanogen Framework from Cyanogen
Using Device configuration, Hardware Camera from Andromadus
And Kernel-2.6.35.14 From Kali-
-What's Fully Working Here
- Sound
- Phone works 2G/3G
- Touch
- SD Card
- Wifi
- Sensors
- Root
- Headphones
- Bluetooth
- EGL
- Advanced Power Menu
- Screenshots
- Market
- Gallery
- Hardware Acceleration
- Video Playback
- GPS
- Tethering
- Facebook contact sync
-What's shoud been Improve and/or fix
- Hardware Acceleration - Very fast even with 2% of remaining battery
- No more Graphical Glith - Report : Still there but i tink this is rarely
- Keybord Light - Need to set "Auto-brightness"
- Performance Settings - "Overclock CPU, Memory Management, Surface dithering, 16bit Ttransparency"
- Less noise during phone call. That work both way.
-What's Kinda Work
- Camera....... "Camera app dosen't crash at startup"
-Somting else...
- Dont know, if you find something bad... tell me
- Search Voice
Special Thanks To
- All the CyanogenMod Team
- Andromadus Team
- Kali-
- TwistedUmbrella
- xda-developers
- Google
- Code Aurora
- HTC
_____________________________________________
CM9-vision-pre-alpha-build-2.0.zip : http://www.mediafire.com/?045pk49sidgi74x
100% Cyanogen Framwork - With some various patches
T-Mobile WI-FI Calling apps added "Don't know if is working - Can't try"
Random fix
CM9-vision-pre-alpha-build-1.2.zip : http://www.mediafire.com/?8omruh4p83x205r
WI-FI Fix
Camera Apps from Andromadus
Qcom_Display from CodeAurora
CM9-vision-pre-alpha-build-1.0.zip : http://www.mediafire.com/?fmdq1y943ehx0a6
Initial Build
Broken WI-FI
Google Apps : http://goo-inside.me/gapps/
Repo Tree : http://github.com/jerl92
Kernel Source : https://github.com/Kali-/htc-kernel-...msm-2.6.35-ics
Quelle: http://forum.xda-developers.com/showthread.php?t=1492461
Reaktionen: Cat
Keksööö;2701215 schrieb:
-What's have been Improve and/or fix
- No more Graphical Glith !!!!
Klingt ja vielversprechend... Danke fuers Verlinken.
Gesendet von meinem HTC Desire Z mit Tapatalk
Habs gerade installiert, vom ersten eindruck her ist echt echt etwas schneller alles alle anderen ics roms zur zeit. mal sehen was die nächsten tage bringen :D entwicklung geht mit riesen schritten vorran :D
Sieht schon einmal ganz gut aus.Wenn die Kamera und das FM Radio noch funktionieren täten würde ich mir die Version raufhauen aufs Handy.
Muss ich vorher für ICS was spezielles noch flashen?
Habe das ROM mal geflashed und er zeigt die ganze Zeit den "android" Schriftzug an und es geht nicht weiter. Oder habe ich evtl zu kurz gewartet?
Derzeit habe ich MIUI-2.2.3 drauf.
Baseband: 12.28b.60.140eU_26.03.02.26_M
Kernel: 2.6.35.14-cyanogenmod-g9e5cdf1
IMEI SV: 01
also beim ersten start dauert es schon ein wenig.
hast du fullvipe gemacht? ich habe erst ohne versucht von quattro rc4 zu cm9 aber dann ist immer der launcher abgeschmiert.
nach dem fullvipe war alles bestens und das rom läuft wie geschmiert. bestes ROM bis jez.
Gesendet von meinem HTC Vision mit Tapatalk
Hab den Thread auf 2.0 geupdatet und zu deiner Frage einfach ein Superwipe machen und dann flashen und dann hat sich die Sache :)
von SuperWipe habe ich noch nichts gehört.
Habe im CWM einfach einen Wipe gemacht und es nochmal geflashed, dann ging es. Sieht gut aus und läuft auch recht rund. Hoffe die Kamera funktioniert bald richtig, bekomme nur lustige Bilder raus.
stell die auflösung auf vga dann gehts.
installier gerade 2.0
könntest du noch bitte denn quellthread posten?
Download ist leider down
Hat jemand vielleicht schon eine andere Lösung für das Kamera-"Problem" gefunden (ausgenommen auf VGA stellen)?
Jemand ne Ahnung wie ich ein eigenes Lied als Ringtone einstell? Normalerweise hau ich das in der Ringtones Ordner auf meiner SD. Jetzt wird er aber nicht angezeigt. Gibt es einen anderen Ordner, oder kann mir jemand sagen, wo der Ordner auf ./ liegt damit ichs per adb push in den ordner verschieben kann?
Liebe Grüße
Gesendet von meinem HTC Vision mit der Android-Hilfe.de App
pack klingeltöne auf sd karte in den pfad /sdcard/media/ringtones sms töne in den pfad /sdcard/media/notification
wie im screenshoot
Erstell den Ordner einfach. Sollte glaube ich sowohl direkt mit /sdcard/ringtones als auch unter /sdcard/media/ringtones funkionieren. Oder auch direkt ins system, nach:
./system/media/audio/ringtones
Ist jetzt in der Beta Phase! ;)
Download & Changelog
[13-4-12] Beta
- CM9-vision-BETA.zip
Changelog
-Framworks ->
- Lasted cyanogen revision with ->
-- Lot of things have been added since last pre-alpha relase.
- Trackball wake
- Legacy touchscreen [Apps compatibility]
- Keyboard backlight fix
- Camera HAL for HTC Sense devices
- RotationVectorSensor2 [Rotation vector for some ICS app like Google maps]
-Display ->
- Lasted branch ics_chocolat from CodeAurora with cyanogen support.
- CRT animation
- Official andreno ics libs by qualcomm.
-OMX ->
- Lasted revision of mm-core and mm-video, from CodeAurora.
- HD playback working : Netflix, Youtube HD
-Camera ->
- Camera work [No flash for now]
- Camcoder work [480P @ 15FPS]
- Panorama work [Don't move too fast]
-Common ->
- Optimization & compatibility [OpenGL, Board configuration, SurfaceTexture]
- Microphone working
- Less noise during call
- CyanogenMod 9 boot aniamtion
- CyanogenMod Torch app
- Build ID IMM76D
- JPEG-Turbo lib [Generally 2-4x as fast as the unmodified version of libjpeg]
-Kernel android-msm-2.6.35-ics-bfs from androamdus with ->
- Fix illogical LorDmodUE configuration mistakes
- inital import of bcmdhd driver from CodeAurora
- Update configuration for new wireless structure
MFG
Craver1990
Update!
Beta 2 ist da.
[24-4-12] Beta 2
- CM9-vision-beta2.zip
Changelog
-Frameworks ->
- Enable dither if needed
- Invalidate HWC Geometry on buffer validity change
- Bugfix : Expanded volume overlay"
-Camera ->
- Flash work
- Fix green slide in 5MP
-Kernel [done by pierror] ->
- Framebuffer: new version backported from primou 3.o kernel
- Lowmemorykiller: new one forked from HTC primou 3.o kernel
- lot of CPU frequencies improve
- boost some HW audio volumes
Kann jemand bitte die neuesten passenden Gapps hochladen? Da goo-inside.im offline ist...
XTPro
XTPro
XTPro
razer1993
razer1993
razer1993
Vauvenal
lonely_Knight
