[ROM]LeeDrOiD HD V5.0.0 - 5th Feb | Tweaks | APM | Fast | Stable | Pure Awsomeness!
themagnus
Presenting LeeDrOiD HD - The Return of! (For now anyway )
S-Off & a Custom recovery required
Android 2.3.5 - GingerBread & Sense 3.0... No gimmick's, no bullshit..
Just a Sensational Android experience from a very experienced developer
With thanks to: ChainsDD l snq- l Scar45 | Baadnwz | damo | Team RC | m-deejay | klquicksall | Alpharevx & Unrevoked | rmk40 | SteelH | Breinholst | j4n87 | daniels7 | Prateek | Scabes & >>> ShowP-1984 - Damn this guy is good! <<<
Huge thanks to j4n87 & daniels7 for the cration of LeeDrOiD Tweaks
Official Support Links:
» Chat live now or join #LeeDrOiD-Roms on Freenode (irc.handhelds.org)
XDA Thread
DOWNLOAD
ich hab es selber noch nicht getestet aber es ist interessant ^^
jemand ne meinung dazu ?
LeeDrOiD HD V5.1.1 - 7th Feb
Change Log
LeeDrOiD_HD_V5.1.1 7th February 2012 - PATCH
  • Fixed build.prop errors
  • Network connections fixed
LeeDrOiD_HD_V5.0.0 7th February 2012
  • HTC Inspire4G now supported
  • Added auto device recognition & patch
  • Fixed tweaks "Fix Permissions"
  • Fixed weather animations
  • Cleaned up build.prop duplicates
  • Fixed Rosie personalize button (And customization)
  • Fixed app drawer divider (Fully transparent)
  • Switched to ICS Style transition animations
  • Added additional missing locales (languages)
  • Fixed wifi signal indicator issues
  • Modified sound profiles (Preperation for full beats audio)
  • Removed final HTC Loggers & report agents
  • Updated stock Gingerbread launcher
  • Updated Adobe flash player & libs
  • Updated Rom Manager
LeeDrOiD HD v5.1.1
Semi transparent rosie dock bar + ultrasmooth/supersmooth v1.1
-Transparency in the dock bar set to 75%
-Fixed stick icon backgrounds (thanks to hamdir)
Flash in recovery and enjoy!
LeeDroiD-SemiTransRosiev1.1.zip
AMCooper
MarM
MarM
  • Morci91
Chooksi
anjoku
