Status des Themas:
Es sind keine weiteren Antworten möglich.
  1. quasimodo, 24.01.2012 #1
    quasimodo
    quasimodo Threadstarter Gast
    [​IMG]
    [​IMG]Beim Entwickler
    [​IMG]
    Screenshots -
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG]
    Credits-
    Perka - perkaMOD
    PAWITP AND TEAMHACKSUNG
    Galnet and his team
    Miui china
    Cyanogenmod team
    DerTeufel1980 for his amazing kernel.
    Brain master
    Neobuddy89
    Adyscorpious
    Miuiandroid.com
    RolluS(myui team -
    rollus.net.myui.for , about them , FORUMS , THERE DOWNLOAD ZONE)
    Hit [​IMG] guys if u like and appreciate our work
    DONATE to me or daxinfinity or ali khalid or perka (lols so many of us ) if u like our work . . [​IMG] [​IMG] [​IMG]
    guys you can Join drZrom group on facebook for faster helps and further assistance - Anmelden | Facebook
    __________________
    HIT Thankxx guys , if i have helped you!!! [​IMG] [​IMG]
    Zuletzt von einem Moderator bearbeitet: 10.02.2012
    caipi75 bedankt sich.
  2. quasimodo, 24.01.2012 #2
    quasimodo
    Beta 8.1--changelog--
    *Added German, polish and french to the rom so now we have 6 languages.
    *fixed apn s.
    *Fixed TV out...now works properly.
    * Any other reported bug that hasn't been fixed is either a MIUIv4 base bug or it doesn't have a fix for it yet.
    CHANGELOG BETA 8 -
    *New base - 2.2.3 release for nexus s .
    *Devil kernel v1.0.
    *English, Chinese and portugese for now , additional language packs to soon come.
    *fixed laggy Google market. [​IMG]
    *fixed laggy gtalk app. [​IMG]
    *fixed slow dialer . [​IMG]
    *4 way reboot...power off, reboot, hot boot, recovery.
    *various tweaks.
    *ADDED CMMUSIC, MIUI MUSIC FROM GB , AND GOOGLE MUSIC ORANGE BY DAXINIFNITY.
    *Anti spam app in English. Obviously also in portugese.
    *monitor.apk in English and also in Portuguese as well.
    *Stock boootanimation.
    *Fixed camera.apk which doesn't crashes when changing MP(really sorry cause I don't remember who gave it to us).
    *File explorer bugs fixed.
    *Mms app bugs fixed.
    *Many more fixes, sorry don't remember.
    change log beta 7:-
    *fixed RIL problems , now the network should not die again and again....incoming should work for everyone .
    *Fixed super user problems.
    *fixed package installer FC problems.
    *latest devil kernel.
    *tons and tons of changes and many major and minor bug fixes.
    Change log beta 6:
    *new devil kernel.
    *fixed installation process.
    *fixed ril issues.
    *fixed super user problems.
    *added removed .
    *Aries parts from cm9 have been modded by miui Portugal so now they appear on app drawer...and they work. Aries parts app now also has TV out settings.
    *calls, 2g, 3g, 4g, 5g, 6g , 7g , 8g, all Gs work now.
    *fixed settings - data usage .
    * more which I don't remember.
    Beta 5 changelog-
    *updated base to 2.1.20 official MIUIv4 for nexus s , no more galnet based.
    *EXTERNAL SD CARD NOW WORKS properly, detected by gallery app and can be unmounted.
    *data usage option works in settings.
    *THEMES NOW WORK.
    *new kernel --glitch v14 b1
    *zip aligned.
    *removed many brain master tweaks because they clashed with glitch kernel.
    *build.prop tweaks.
    *ril issues fixed -- hope so.
    *wifi fix removed.
    *using all stock apps that come in 2.1.20 base.
    *more stable and better battery life.
    known issues-
    *external SD card can't be accessed through PC if you connect via USB .
    *themes work though not everything is changed as per theme when u apply it cause themes aren't modified to work with MIUIv4.
    *signal bars in notification bar has graphical glitches.
    *phone takes a lot of time to detect networks. [​IMG] ....needs to fixed.
    *some MIUIv4 bugs and graphical glitches.
    * more which maybe unknown .
    Zuletzt von einem Moderator bearbeitet: 09.02.2012
  3. quasimodo, 24.01.2012 #3
    quasimodo
    FAQs-
    Q- how can I enable bln/ ?
    A-its already working. No need to do anything.
    Q- is the rom multi language ?
    A-we don't make the rom we just make it better, base of rom is from MIUIgalnet so if they add any language we won't remove it. But still we will try adding languages if we can.
    Q-can I install the rom without wiping?
    A- for the first time I recommend wiping for bug free use, after u install the rom once u can update to any new version without wiping.
    Q-where can i find external SD ?
    A-external SD card is in 'emmc' folder in the root of the Device. Use any root browsing app to access external SD card.
    More FAQ s will be added soon.
    __________________
    Zuletzt von einem Moderator bearbeitet: 25.01.2012
  4. id.goPLAY, 24.01.2012 #4
    id.goPLAY
    id.goPLAY Android-Experte
    463
    Erhaltene Danke:
    123
    05.12.2010
    Phone:
    Galaxy S7
    Das (noch) vorhandene problem:
    DeepIdle kann man mit Teufel Kernel & NStool's regeln?!
  5. quasimodo, 24.01.2012 #5
    quasimodo
    Hallo iPLAY, habe es noch nicht getestet?
  6. thE_29, 25.01.2012 #6
    thE_29
    thE_29 Android-Lexikon
    1,381
    Erhaltene Danke:
    90
    07.07.2010
    Welche Sprachen sind da jetzt automatisch mit dabei?!
  7. frank e., 25.01.2012 #7
    frank e.
    frank e. Android-Lexikon
    1,530
    Erhaltene Danke:
    1,038
    15.04.2011
    Ich finde deine Arbeit super, jedoch wäre es schöner in Deutsch. So kann ich mich direkt nur noch auf XDA informieren, das ist das selbe.
    Gesendet von meinem GT-I9000 mit Tapatalk
    ChrisKey bedankt sich.
  8. id.goPLAY, 25.01.2012 #8
    id.goPLAY
    463
    Erhaltene Danke:
    123
    05.12.2010
    Phone:
    Galaxy S7
    Warte mal, das ist dein ROM?
    Scheisse.... respect man! :)
    Sent from my GT-I9000
  9. quasimodo, 25.01.2012 #9
    quasimodo
    Wenn Du magst, dann mache eine Deutschen Übersetzung.
    Ich ersetze dann die Englisch Texte: Besten Dank!
    Beta 6 ist Online und in Post 1 gelistet, Change Log in Post 2
    Edit: Läuft sehr Smooth!
    Fördern statt Fordern!
  10. philippsp, 25.01.2012 #10
    philippsp
    philippsp Android-Lexikon
    1,582
    Erhaltene Danke:
    247
    21.08.2010
    Schade, dass es noch auf englisch ist.
  11. steffen431, 26.01.2012 #11
    steffen431
    steffen431 Fortgeschrittenes Mitglied
    260
    Erhaltene Danke:
    66
    22.04.2011
    @quasimodo kannst du bitte eine deutsche Version machen und mit was machst du es.
    Mit APKTranslator od. welches Programm nimmst du.
    Wie gibt man bei dieser Version TB Rootrechte?
    G.steffen
  12. quasimodo, 26.01.2012 #12
    quasimodo
    Hallo Steffen, hast Du Lust es ins Deutsche zu übersetzen?;)
    Nein, Spaß bei Seite, kann keine Sprachpakete übersetzen und wie mmuuhh etc. die darin Fit sind,
    , noch nicht da Ran gegangen oder haben es wohl noch nicht geschafft.
    Habe Andy25 angeschrieben ob man da schon soweit ist,
    von Ihm aber noch keine Antwort erhalten, den für`s Nexus S gibt es ja schon eins.
    Zuletzt von einem Moderator bearbeitet: 26.01.2012
  13. steffen431, 26.01.2012 #13
    steffen431
    260
    Erhaltene Danke:
    66
    22.04.2011
    Ich habe es mir schon gedacht, denn hab noch auf keiner Seite was gelesen, daß man die v4 in irgend eine Sprache übersetzten kann.
    Muß halt noch warten, denn englisch ist nicht mein ding.
    Hab zwar heut früh mal drauf gemacht, weil mich es interessiert hat wie weit die Themen übernommen werden. So kann ich mich schon mal beschäftigen mein Thema für die v4 zu machen.
    G.steffen431
  14. quasimodo, 26.01.2012 #14
    quasimodo
    Zum Glück haben Wir ja das Recht Gut laufende OnCosmic RC3.1, so das Wir immer mal switchen können. Gelle! ;)
  15. quasimodo, 31.01.2012 #15
    quasimodo
    Beta 7 Online und in Post 1 gelistet
    change log
    Freakandr0id, Sarocc, gustel und eine weitere Person haben sich bedankt.
  16. emage, 31.01.2012 #16
    emage
    emage Android-Hilfe.de Mitglied
    135
    Erhaltene Danke:
    16.03.2011
    Ist mit dem ersten Punkt die Anrufannahme gemeint? Die hatte nämlich bei der letzten Version bei mir nicht funktioniert. Bis auf diesen (sehr wichtigen Punkt) lief die letzte Version schon ganz gut
  17. quasimodo, 31.01.2012 #17
    quasimodo
    Rufannahme geht!
  18. OL-Langer, 04.02.2012 #18
    OL-Langer
    OL-Langer Android-Hilfe.de Mitglied
    49
    Erhaltene Danke:
    04.06.2011
    Installiert euch LocaleSwitch aus dem Market. Dann habt ihr die apps in deutsch und die Uhr im 24 Std. Format sowie eine deutsche Sprachausgabe. Nur die Miui eigenen Menüs sind halt noch in Englisch.
    Freakandr0id bedankt sich.
  19. quasimodo, 06.02.2012 #19
    quasimodo
    Download link for beta 8 coming soon ....mirrors also but later.
    CHANGELOG BETA 8 -
    *Devil kernel v1.0.
    *various tweaks.
    _______________________________________________________________________________________________
    TRANSLATION PACKS
    Originaltext rtfpessoa by xda
    All the people that wants a translation pack, just need to send me the translation or one rom that has that language.
    Now i will start with german.
    Any other just send PM.
    Zuletzt von einem Moderator bearbeitet: 06.02.2012
  20. andidroid, 08.02.2012 #20
    andidroid
    andidroid Erfahrener Benutzer
    190
    Erhaltene Danke:
    46
    21.09.2010
    http://forum.xda-developers.com/showthread.php?p=22284261
    Build 8.1 coming today/tomorow with:
    Languages:
    Portuguese, English, Chinese, French, German, Polish
    Changes:
    Apn fix;
    TVOut now fully working (thanks to mrfyda and kakomalo that worked with me to get it fixed);
    Others i missed
Status des Themas:
Diese Seite empfehlen
