[ROM] Synergy - (RC2.1 28/07/2011) - The Result Is Greater Than The Sum Of Its Parts
Gani
Gani
Dauergast
342
This is the port of Synergy rom to the Htc Vision aka Tmobile G2/Desire Z.
  • Based on Speedy_S_Sprint_WWE_2.72.651.2 Leak (Thanks 911 Sniper)
  • Sense 3.0 Lockscreen
  • Sense 3.0 threaded text messaging (Thanks SEO)
  • Sense 3.0 Weather (Thanks SEO and Damo)
  • Sense 3.0 MMS
  • Sense 3.0 Task Manager
  • Sense 3.0 Polaris Office
  • Sense 3.0 USB Menu
  • Synergy Updater app, allowing in rom updates (Addons and Themes)
  • Optional PureBlack theme (Thanks Krysick)
  • Green overflow scroll (Thanks Robocik)
  • Rased available MMS size Limit to 5mb (Default is still 2mb)
  • Support for ## Programming Codes (ex ##775#)
  • 1% battery increments and animated sync
  • Tweak to increase sdcard read ahead buffer (Thanks Calk)
  • Custom HTC Wallpapers
  • CRT display off/on animations
  • Optimized apks (thanks aamikam)
  • CRT TV shutdown animation
  • BusyBox v1.18.4 with color output disabled
  • Custom Notification sounds
  • Rosie settings with right button remap
  • Screen Scaling and systl.conf tweaks (Thanks Ziggy471)
  • Build Prop tweaks for faster screen transitions and call connect (Thanks CapyChimp)
  • Framework and Rosie transition times sped up (Thanks Calk and Aamikam for the Logic)
  • HTC hub (Huge thanks to aamikam)
  • 3G/1X status in Titlebar Mod
  • Transparent Rosie (Thanks Virus and Snq)
  • H264 native support
  • Synergy bootanimation (Thanks to the King of bootanimations.. Wrx4memp)
  • HTC_IME.apk with non arrows version
  • Landscape Rosie Support (Thanks TommyTomatoe)
  • Increased GPS Lock Performance (Thanks Ziggy471)
  • Wireless Tether 2.0.7
  • Added HTC Media Share (DLNA Server)
  • Unlimited tabs in Browser.apk (Thanks JoelZ9614)
  • Netflix Works
  • Updated DSP Manager
  • And much much more..
Weitere Infos und Download:
[ROM] Synergy - (RC2.1 07/28/2011) - The Result Is Greater Than The Sum Of Its Parts - xda-developers
Das hört sich ja mal ganz schön interessant an :)
Werde es gleich mal testen!
jeahbaby
  • jeahbaby
jkwak
jkwak
  • Joffazu
Joffazu
ElEm
