[Rom]WB-XPERIA TW Gingerbread V4 | 55fps, no Audio lag, xLoud & Bravia | 8/8/2011
Wolfbreak
66
Wolf
TW | Gingerbread 2.3.3 | Theme, Tweaks & Extra's |​
How to install my ROM Video
| Demonstration Video of my ROM
Screenshots
Requirements
  • Any working ROM with xRecovery
  • Flashtool
  • FTF bundle posted below
  • Wolf_Xperia_6.0.0.zip posted below
Features
  • Stock Sony Ericsson 2.3.3 ROM
  • Pre-rooted (Superuser files pre-installed, busybox pre-installed!)
  • Recovery 0.3 (fully working)
  • FPS Uncap Hack
  • Mobile BRAVIA Engine, xLoud and Theme Chooser
  • Very Light Weight [80mb]
  • DLNA
  • More Free Memory&RAM
  • Build.prop tweaks
  • CPU Governor Tweaks
  • removed unneeded SE and Google Services
  • Ringtones and Notifications on SD Card to save internal Memory
  • faster Startup
  • better Memory Management [more free RAM]
  • improved Peformance, Smoothness and Battery
  • Reboot Options Mod included
  • Compcache Tweak
  • patched app_process & system_server for alot smoother ROM
  • patched sqlite for alot faster IO R/W + Battery
  • Battery Tweaks
  • Process Priority Tweaks
  • Automatic ZipAlign
  • SD Card Speed boosted
  • VM/Sysctl tweaks
  • Kernel tweaks
  • Android Internal Taskkiller tweaked
  • I/O Scheduler tweaks
  • Reduced lags
  • Better memory management
  • Network speed tweaks & improvements
  • alot more so check it out....
How to install this ROM?! [Fresh Install]
  1. Reboot into xRecovery and make a back-up of your current ROM. (You'll need a working xRecovery or else it will say Device/SD Card busy).
  2. Wipe the following in xRecovery:
    • Factory Reset (Full wipe)
    • Wipe Cache Partition
    • Wipe Dalvik Cache
  3. Go to install Custom Zip and choose Wolf_Xperia_6.0.0s/c
    The following steps are only required if you don't have the new 2.3 kernel and .71 baseband, if you do have them you can reboot your phone and enjoy this ROM.
  4. Turn off the phone by taking out your battery when ROM installation is finished
  5. Open Flashtool and flash the FTF Bundle I made available for download. Press on Flash and follow the steps given to put your x10 into flashmode and flash the baseband and kernel.
  6. When Flashtool is finished you can plug out the USB, turn your phone on and enjoy this ROM!
Downloads
FTF bundle (2.3.3 kernel and baseband .71)
Additional Downloads
  • Click Here for Additional Downloads
Credits:
  • Zdzihu/FreeXperia Team for everything they did!
  • Doomlord/aZuZu for Root & Kernel
  • sj8023ld for Statusbar Not. Widget Mod
  • ThJap for some nice Tweaks and Japanese EMOJI & SP push fix
  • Goro for Kernel
  • PlayGunsta for finding some nice Tweaks
  • TripNRaVer for some Tweaks
  • pvyParts for EDT Tweaks & Not. Bar Toggle
  • my_Immortal for EDT Tweaks & Not. Bar Toggle
  • 28spawn for xLoud
  • All Users for their support
  • If i forgot someone send me a PM and i edit it!
Click to support my Filesonic Account
FileSonic, fast and easy file storage.
Reaktionen: Mario1974, Texaner, seneca64 und 6 andere
Werde dieses Rom nachher mal meinem Mädel aufs Handy packen. ;)
Danke dafür !!!
MfG
UKSheep
hmm, irgendwie kann ich mit der Rom nix downloaden ... weder per Wlan noch per Edge. Hat das noch wer oder bin ich der einzige bei dem das nicht geht? Der DL vom Market geht aber ohne Probleme ... nur der DL über XDA, übers Android App und über dem Browser gehen nicht.
Irgendwie ist diese ROM nicht das gelbe vom Ei....
Ich hatte vorher die 2.2 v07 mit Custom Kernel von Wolfbreak...
und die lief flüssig wie ein iPhone! mit sehr vielen FPS!
und jetzt läuft es einfach nicht Flüssig...
Wenn man ein HTC oder Samsung daneben hält sieht alles einfach nicht so flüssig aus.
sehr schwaches update...
Sony Ericssons schuld nicht meine junge :)
V003 mit Bravia Engine+Fixes und DLNA raus
Reaktionen: Frammy
ich meinte auch SE mit dem Update ^^
aber dank der V003 ist es schon was besser geworden ;) nur ich hab ein problem... ich kann irgendwie nichts runterladen aus dem browser? :/
Edit: Problem behoben, hab einfach "Download all files" ausm market runtergeladen dann gings irgendwie ^^
das wird noch ;)
Wenn man so wie ich Probleme hat mit dem XRecovery, flasht man besser in dieser Reihenfolge.
Eclair 2.1 Stock Rom->Root und XRecovery->Wipe´s->WB TW->FTF Bundle!
Dann bekommt man auch keine Fehlermeldung von XRecovery das die SD Karte nicht gefunden wurde!
Super ROM, endlich ist das X10 meiner Freundin auch zu gebrauchen!
Wie stabil läuft sie nun, da ständig Hotfixes kommen...?
stabiler als die offizielle 2.3.3 Rom :D
die Hotfixes fixen nur das, was Sony Ericsson nicht gebacken bekommen hat ;)
Bei Wolfs rom funktioniert alles, und ist flüssiger
006 full ROM raus basierend auf UK Firmware :)
Reaktionen: debiba und lkrys
Wie gros sind die optischen abweichungen zur stock rom?
- versendet mit meiner heißen persönlichen tippse ;p. -
Also von dem Feedback bis jetzt und persönlichen Tests ists viel schneller wie die stock ROM und läuft um einiges besser mit ARC Features wie xLoud oder Bravia Engine und viel mehr.
BTW 007 ist raus, checkt OP für Changelog
Reaktionen: Scum
Wie kann ich Desing verwenden und Circle Battery Mod for 006 ?
Top!
Die Installation war etwas umständlich (wegen dem XRecovery, welches über Adb Shell installiert wird), aber nun läuft die ROM 1A! Der SE-Launcher läuft super flüssig, so wie ich es mir eigentlich von SE erhofft hatte (wie beim Arc, Neo ...).
Top - besten Dank!
hatte zuerst die 2.3.3 Stock Rom drauf. dann diese hier geflasht,muss schon sagen,läuft wirklich flüssiger als die originale.Funktioniert auch alles super.
ja das mit dem "Circle Battery Mod for 006" ,
würde mich auch interessieren,läuft der nun nicht mehr?
Der Battery Mod geht noch ... steht ja auch dabei.
Mein Fazit der Rom:
keinerlei FC's oder sonstige Probleme ... außer das die Batterie nicht mehr so lange hält ... kann aber auch am 3G liegen das ich jetzt mit dem D1 Netz hab .. hatte vorher ja nur E.
Aktuell 21h 30 Min
45 % noch vorhanden.
=D
wenn ich den akkuverbrauch je hinbekommen hätte, würde ich keine andere Rom mehr nutzen =D
edit: sind die hotfixe schon in der rom jetzt drinnen, oder muss ich die nochmal extra flashen? (ganz normal per xrecovery oder?)
Mikemr
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
  • Slowfinga
Aaskereija
Aaskereija
