Umi Rome X Vorgestellt / Flacher als Xiaomi Redmi 2 / Beste Kamera für Einsteigermodell
efox-shop
efox-shop
Enthusiast
269
UMi will soon launch their new device, the UMi Rome X, an entry-level smartphone which will surprise users because of its amazing design. Typically, budget smartphones are characterized by a rough design and being too thick and ugly, so they are not stylish nor feel comfortable in the hand. Most users would like to have a good-looking entry-level phone, but this feeling have been ignored repeatedly by phone makers. Fortunately, UMi, in their quest to be one of the leading brands on today’s market, decided to bring the premium design and experience into entry-level phones as well, and, for this reason, they are launching UMi Rome X, the slimmest entry-level phone.
UMi Rome X
Xiaomi Redmi 2
UMi Rome X will feature a 7.9-millimeter frame, being even thinner than the Samsung Galaxy Note 4, which incorporates an 8.5mm frame. One the other hand, the Xiaomi Redmi 2, one of the most successful low-end devices, has a 9.4mm thickness. As we can see, there’s a 2.5mm difference between both phones.
Moreover, UMi Rome X metal frame will be made of polished stainless steel, which is extremely lightweight and rugged at the same time. On the other hand, low-end devices as the Xiaomi Redmi 2 are fabricated in plastic. Nevertheless, despites having similar specifications, Xiaomi Redmi 2 costs $109.99, while UMi Rome X will cost only $49.99. As we have seen, Xiaomi device costs almost twice than the UMi Rome X, being Rome X not only 2.5mm thinner, but also having a metal frame, which provides durability and contributes to offer a premium feel.
UMi Rome X will incorporate the best camera for an entry-level smartphone
Most of the entry-level phones typically incorporate low-quality sensors, which do not allow users to make decent photographs.
UMi Rome X is incorporate Sony IMX179 sensor
Currently, higher quality sensors are manufactured by Sony. An example of Sony manufactured sensor can be found on the UMi Rome X, which incorporates a Sony IMX179 8-megapixel sensor. This sensor is claimed to be the best among all the 8-megapixel sensors, both Sony and other brands.
Sony IMX179 is not only the best 8-megapixel sensor on today’s market, but also is the model used in well-known devices such as Google Nexus 5, Oppo R1, Huawei Honor 6 Plus or Nubia 9 mini, all of them with a much higher price than UMi Rome X
Here are some pictures taken with the Sony IMX179 sensor shown:
As we can see in the pictures above, the Sony IMX179 is a high quality sensor that will allow users to take amazing photos with their UMi Rome X.
As already mentioned, Sony IMX179 is the best 8-megapixel sensor on the market, allowing users to capture memorable moments with superb image quality. As we have seen, we can usually find this sensor as part of mid-range devices, however, you could enjoy this high quality photo on the UMi Rome X camera, an entry-level device which will cost only $49.99.
Full Spec of UMi ROME X:
2.5D 5.5 inch LTPS 1280 x 720 HD Screen
MTK6580 Quad Core 1.3GHz
Android 5.1
1GB RAM + 8GB ROM
Sony IMX 179 8.0MP( SW13.0MP ) with dual flashlight
2500mAh
Pre Order here:
Umi Rome X - Günstiger als Umi Rome und flacher als Xiaomi Redmi 2
__________________________________________________
Deutsche Google Übersetzung:
UMi bald ihre neue Gerät, das UMi Rom X, eine Entry-Level-Smartphone, das den Benutzern wegen seiner erstaunlichen Design überraschen wird gestartet. Typischerweise werden Budget-Smartphones durch eine raue Design aus und zu dick und hässlich, so dass sie nicht stylish noch wohl fühlen in der Hand. Die meisten Benutzer möchten eine gut aussehende Entry-Level-Telefon haben, aber dieses Gefühl immer wieder telefonisch Trägern ignoriert. Glücklicherweise UMi, in ihrem Bestreben, eine der führenden Marken auf dem heutigen Markt zu sein, beschlossen, das Premium-Design und Erfahrung in die Entry-Level-Telefonen sowie zu bringen, und aus diesem Grund werden sie startet UMi Rom X, das flachste Eintrag -Niveau Telefon.
111
UMi Rom X
222
Xiaomi Redmi 2
UMi Rom X eine 7,9-Millimeter-Rahmen verfügen, wobei sogar dünner als das Samsung Galaxy Note 4, die ein 8,5 mm-Rahmen umfasst. Einer der anderen Seite, die Xiaomi Redmi 2, eine der erfolgreichsten Low-End-Geräte, hat eine 9,4 mm Dicke. Wie wir sehen können, gibt es eine 2,5 mm Unterschied zwischen beiden Telefonen.
Darüber hinaus wird UMi Rom X Metallrahmen aus poliertem Edelstahl, die extrem leicht und robust zugleich ist gemacht werden. Auf der anderen Seite werden nieder Endgeräte als Hirse Redmi 2 in Kunststoff hergestellt. Dennoch Despites mit ähnlichen Spezifikationen, Xiaomi Redmi 2 kostet $ 109,99, während UMi Rom X kostet nur $ 49,99. Wie wir gesehen haben, kostet Xiaomi Gerät fast doppelt als die UMi Rom X, wobei X Rom nicht nur 2.5mm dünner, sondern auch mit einem Metallrahmen, der Dauerhaftigkeit bietet und trägt zu einer Premium-Gefühl bieten.
UMi Rom X die beste Kamera für ein Entry-Level-Smartphone zu integrieren
333
Die meisten Einsteiger-Handys in der Regel übernehmen minderwertige Sensoren, die nicht zulassen, dass Benutzer auf anständige Fotos zu machen.
UMi Rom X übernehmen Sony IMX179 Sensor
Derzeit sind höhere Qualität Sensoren von Sony hergestellt. Ein Beispiel für Sony hergestellte Sensor kann auf der UMi Rom X, die eine Sony IMX179 8-Megapixel-Sensor enthält gefunden werden. Dieser Sensor wird behauptet, die beste unter allen 8-Megapixel-Sensoren, sowohl Sony und andere Marken.
Sony IMX179 ist nicht nur die beste 8-Megapixel-Sensor auf dem heutigen Markt, aber auch wird das Modell in bekannten Geräten wie Google Nexus 5, Oppo R1, Huawei Honor 6 Plus oder Nubia 9 mini, alle von ihnen mit einem viel verwendet höheren Preis als UMi Rom X
Hier sind einige Bilder mit dem gezeigten Sony IMX179 Sensor wurde:
444.555
Wie wir in den Bildern oben zu sehen, ist das Sony IMX179 ein hochwertiger Sensor, damit die Benutzer erstaunliche Fotos mit ihren UMi Rom X. stattfinden wird
Wie bereits erwähnt, ist Sony IMX179 die beste 8-Megapixel-Sensor auf dem Markt, so dass Anwender unvergessliche Momente mit ausgezeichneter Bildqualität zu erfassen. Wie wir gesehen haben, können wir in der Regel finden diesen Sensor als Teil der Mid-Range-Geräte Sie jedoch dieses hochwertige Foto auf dem UMi Rom X-Kamera, eine Entry-Level-Gerät, das kostet nur $ 49,99 genießen.
Voll Spec Umi ROME X:
2.5D 5.5 Zoll LTPS 1280 x 720 HD-Bildschirm
MTK6580 Quad-Core 1,3 GHz
Android 5.1
1GB RAM + 8GB ROM
Sony IMX 179 8.0MP (SW13.0MP) mit Dual-Taschenlampe
2500mAh
Espressojunkie
Espressojunkie
Espressojunkie
ChrisKraus
DOT2010
DOT2010
DOT2010
