Problem beim Erstellen eines TableLayouts per Code !
  • 0 Antworten
BFK
ich versuche ein TableLayout dynamisch (also per Code) zu erstellen.
Das Table Layout soll genau so aussehen..:
Code:
  <TableLayout
            android:layout_width="fill_parent"
            android:layout_height="wrap_content"
            android:orientation="horizontal"
            android:layout_marginRight="20dp"
            android:layout_marginLeft="20dp">
         <TableRow
                android:layout_height="wrap_content">
                <TextView
                    android:text="Field 1"
                    android:background="#0000FF"
                    android:textSize="13dp"
                    android:textColor="#fff"
                    android:includeFontPadding="false"
                    android:layout_width="0dp"
                    android:layout_weight="1"
                   <TextView
                     android:text="Field 2"
          </TableRow>
  </TableLayout>
Mein Code sieht bis jetzt so aus..:
Code:
/* Table Layout */
        final TableLayout table = new TableLayout(getApplicationContext());
        TableLayout.LayoutParams lp_normal = new TableLayout.LayoutParams(LayoutParams.FILL_PARENT,LayoutParams.WRAP_CONTENT);
        lp_normal.setMargins(getPixels(20), 0, getPixels(20), 0);
        table.setLayoutParams(lp_normal);
        table.setOrientation(TableLayout.HORIZONTAL);
        /* Table Row */
        TableRow row_1 = new TableRow(getApplicationContext());
        row_1.setLayoutParams(new TableLayout.LayoutParams(LayoutParams.FILL_PARENT,LayoutParams.WRAP_CONTENT));
        TableLayout.LayoutParams lp_txt = new TableLayout.LayoutParams(0, LayoutParams.FILL_PARENT);
        lp_txt.weight = 1;
        // TextView 1
        final TextView txtField_1 = new TextView(getApplicationContext());
        txtField_1.setTextColor(Color.WHITE);
        txtField_1.setText("Field 1");
        txtField_1.setLayoutParams(lp_txt);
        txtField_1.setIncludeFontPadding(false);
        row_1.addView(txtField_1);
        // TextView 2
        final TextView txtField_2 = new TextView(getApplicationContext());
        txtField_2.setTextColor(Color.WHITE);
        txtField_2.setIncludeFontPadding(false);
        txtField_2.setText("Field 2");
        txtField_2.setLayoutParams(lp_txt);
        row_1.addView(txtField_2);
        table.addView(row_1);
So wie der Code-Abschnitt so steht, wird überhauot nichts erstellt.
Ich glaube auch, dass es an das "setLayoutParams" der beiden TextViews liegt, weil wenn ich keine "setLayoutParams" an den beiden TextViews benutze, wird das TableLayout erstellt, ALLERDINGS sieht es nicht wie gewollt aus (die Spalten sind nicht gleich gross).
Aus irgendeinem Grund kann ich keine Layout-Parameter an den TextViews festlegen.
Was könnte ich machen..?
Jennywise
Jennywise
Jennywise
