Chris1996
Stamm-User
- 141
Video zur Rom:
RebelROM AOKP Galaxy S II 1.0 - YouTube
Download:
v1.3.1:
Downloadlink 1
oder
Downloadlink 2
Gapps nicht mehr in der Rom enthalten.
-Download GAPP'S
-Phone.apk die DPI unter 180 unterstützt: Download
Features:
-Based on AOKP-SGS2 ICS 4.0.4 -built from source, with some tweaks done by me
-FLUXI KERNEL ICS XX.01-RC5.2
-Google Apps & Face Unlock included in rom
-APEX launcher - Launcher settings integrated into settings
-OTA updater (thanks to Update me app) - Integrated into settings
-Multi-language fluxi xxTweaker app - Integrated into settings
-Solid Explorer added
-Apollo Music player
-Optimus 4x Style lockscreen
-CM9 keyboard (added languages )
Changelog:
1.3.1 (08/6/12):
-All bugs from 1.3 should be fixed
-Updated Apex Launcher to latest beta (1.2.2Beta1)
-Updated xxTweaker to latest beta (0.3.9_beta3)
1.3 (07/06/12):
-AOKP build 38 aokp
-pHrail's rebel rom boot animation
-all apks PNG optimized
-Optimus 4x lockscreen no longer included (not compatible ATM)
-Latest Fluxi kernel and xxTweaker
1.2.1 (1/6/12):
-Cleaned up a little bit
-Fixed kernel flashing problem
1.2 (30/5/12):
-USB connection mode option re-added (go to settings->storage->click menu button)
-DSPmanager replaced MusicFX
-Some more build.prop tweaks
+Google apps removed (flash GAPPS ICS separately)
1.1 (29/5/12):
-Optimus 4x lockscreen option cooked in
-Apollo music player
-xxTweaker updated to v.36
-Keyboard from CM9
-Couple graphical fixes in settings app (Apex setting icon changed, and "OTA update" renamed to "OTA Updater"
1.0.1a (28/5/12):
-1.0.1 +settings fix included
-Wipe cache+dalvik included in updater-script (does it by itself when installing)
1.0.1 (28/25/12):
-Removed "Device Tweaker" (tweakGS2.apk) from settings and rom, because it really isnt needed when you have xxTweaker.
-Couple other minor changes. ("Mod version" name change, etc)
Installation:
1. downloadet die Rom und die Gappa
2. legt beides auf eure interne SD
3. bootet ins Recovery
4. führt einen Fullwipe aus ( wipe data/factory reset, wipe cache partition, wipe dalvik cache, format system )
5. flasht die Rom indem ihr auf "install zip from sd card" geht und dann die Rom auswählt
6. nachdem der Flashvorgang beendet ist klickt ihr erneut auf "install zip from sd" und flasht die Gapps dann geht ihr zu "Reboot system now"
7. jetzt seid ihr fertig
Falls ihr ein Update machen wollt ist es nicht nötig irgendwelche Wipes auszuführen, da in den Versionen ab 1.0.1a ein Updatescript enthalten ist
-Netchip
-AOKP team
-Fluxi
-any other devs involved
Your work is REALLY appreciated
Screenshots:
->XDA-Thread<-
Extras:
Giant AROMA tweak pack coming soon! It wont be included in rom, that will remain a clean install and under 120mb (110 currently). But I will put up a "Tweak pack" that you download separately and run in CWM after install of Rebel Aokp (if wanted). It will offer a choice of things like, replace/add launchers (nova,trebuchet, xperia s etc), Change bootanimation, Add reverted Gapps(black), Different kernel choices (dormanx/siyah, with extweaks in settings vs xxtweaker etc) Bravia engine addon, beats addon.. Stuff like that, working on it now, and will release with Rebel AOKP 1.3
Request mods, bootanimations, launchers here http://goo.gl/Rj9sv
Its a Google docs spreadsheet, Put requests in there respected column
