debaki
Dauer-User
- 500
Soooo mal wieder eine neue Aokp Rom die schon gute Bewertungen bekommen hat. Laut erster Bewertung wie die Hydrogenic Rom...^^ Ich hoffe nur das er noch den Lucky Patcher rausnihmt, ist ja nicht so gern gesehen.^^
Klick mich den ich bin ein XDA Link
- Based on AOKP Build 40 Android 4.0.4 IMM76I
- Aroma Installer
- ThunderBolt Tweak
- Fluxi Kernel
- Google Apps
- UpdateMe
- build.prop Tweak
- Nova Launcher
- Touchwiz Ux Launcher
- Solid Explorer Beta
- Samsung Stock Memo
- SuperSU
- xxTweaker
- Beautiful Background in Setting,Phone,etc.
- Semi-Transparant & Glow Popup
- Flying Effect
- X Lockscreen
- Very Fast & Stable
Version 3.0 (26 June 2012)
- Update to AOKP build 40
- Add Aroma Installer 2.0
* Add Adobe Flash Player
* Add Apex Launcher
* Add Apollo
* Add DSPManager
* Add OI File Manager
* Add Polaris Office
* Add Swype
* Add Trebuchet Launcher
* Add Touchwiz UX Launcher
- Update SuperSU 0.91
- Add Samsung Stock Memo
Version 2.0 (Canceled)
Version 1.3 (18 June 2012)
- Add Thunderbolt Tweak Version 2.7.7 (More Battery Saver!
- Add UpdateMe
- Add Touchwiz Ux Launcher 1.5.1
- Add AOKP Tips.
- Add "X-TremE AOKP" at Footer in Notification Bar.
- Decorate X Lockscreen.
- Change Video Record sound.
- Change Battery Icon.
- Update build.prop Tweak.
Version 1.2 (17 June 2012)
- Fix Phone.apk when change dpi less than 182dpi Phone will not working. (Thanks Mudahuda for reporting)
Version 1.1 (16 June 2012)
- Add DSPManager
- Add Noise Suppression.
- Add Flying Effect when move to the other window.
- Update to Fluxi Kernel XX.02-b4 (Lastest)
- Update to xxTweaker 0.3.9 b5 (Lastest)
- Update to Solid Explorer Beta 1.2.4 (Lastest)
- Update to SuperSU 0.90 (Lastest)
- Change Background to Default Background. (if you want my background,Download Patch in Download topic)
- Remove Beats Audio. It doesn't work good with Poweramp. (Thanks Mudahuda for reporting)
Version 1.0 (10 June 2012)
- Release Rom
- (AOKP Build38 Bug) External SD not mount when connected to the PC. Use Multi Mount SD-Card in Google Play instead.
Rom
X-TremE AOKP Version 3.0
X-TremE AOKP Version 1.3
X-TremE AOKP Version 1.2
X-TremE AOKP Version 1.1
X-TremE AOKP Version 1.0
