[AOKP-ROM] *29.05.12* [4.0.4][AROMA] FOXHOUND 0.2 Cyano+Aokp |Fast|Ota|Customizable
  • 18 Antworten
So_ony
So_ony
Hey Leute!
Raffaele88 hat ne neue Rom Version rausgebracht und die wollte ich euch hier präsentieren!
Hier der original Link zu der Rom bei XDA:
[ROM][4.0.4][AROMA] FOXHOUND 0.1 Cyano+Aokp |Fast|Ota|Customizable [May 26] - xda-developers
Feature ROM
Based on Cyanogenmod 9 and AOKP
AROMA installer
Costumize installation
Android 4.0.4 -- IMM76I
Unsecure boot.img
Superuser & Busybox preinstalled
Deodexed
180 Degree rotation
Built in performance/init.d configuration (Thanks Kejar & company)
CM Brightness slider
Custom color for anything in RC
Clock Color/Location: Right, Center, Disable
Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
Nav Bar Transparency
Nav Bar Button Reorder: Back-Home-Search-Menu
Nav Bar Color Picker
Nav Bar Button Glow Duration: Off, Fast, Slow
Nav Bar: Long press to Search button
Nav Bar Hide on Lockscreen
Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
LCD Density (Careful with this)
Menu Button location: Right, Left, both, Remove
Menu Button Visability: Always show, Always show Invisible Icons
Lockscreen Style: Quad, Octo, Stock
Lockscreen SMS customizable shortcut
Lockscreen Horizontal Option
Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
Unlock Sceen with Legacy Menu Icon
Volume Key to Wake Screen
Volume Key to Skip Tracks
Long-press back button to kill process
Disable CRT off animation
ICS ringtones/notification sounds
Customize carrier text to whatever.
Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
Facebook contact sync integration (must wipe to get this)
Disable Boot animation
Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
Long press home for recent apps (thanks brucekey)
Dpi change to 200 (default are 240)
Insert Theme Manager (CM)
Insert TweaksGS2
Insert BLN in settings
Insert Ota app for update ROM
Insert SettingsGS2 (CM)
1.Make sure you're on the latest CWM
2.MAKE A NANDROID
3.Wipe data/factory reset in recovery
4.Flash ROM whit CWM
5.Reboot
Attention:
If you have problems installing the rom, simply repeat the operation
Changelog der 0.2 Version
Fix Brigthness
Insert more step for auto brigthness
Fix Nova launcher in aroma installer
Fix Fluxi kernel in aroma installer
Fix Bluetooth
Fix usb mass storage (test)
Fix White theme
Insert script for mount sd-card
Update Abyss kernel
Update Fluxi kernel
Download
AOKP Team - Link
CM9 Team - Link
Aroma Installer - Link
All Xda Developers​
Viel Spaß mit der Rom !
Reaktionen: mareis1973, Akira-1980, FotoMichi und 2 andere
Ich hab mir die Rom grad geflasht - dann hat ich einen FC in dem " Einrichtungsassistent" dann wurde mir nur noch die statusbar angezeigt sonst alles schwarz darauf hatte ich einen Reboot der in einem Bootloop endete -.-
Sent with my GT-I9100 with PARANOIDANDROID
komisch, also bei mir hat alles tatelos funktioniert
Wipe Data Factory Reset+Wipe Cache/Dalvik cache gemacht?
welchen Kernel benutzt du?
ja fullwipe und ich hab den siyah 3.2.6 ;) naja ich flash sie mir einfach nochmal :D
falls was sein sollte meld dich einfach :)
Hatte auch diesen fehler...konnte ihn nicht beheben
Hast du es nochmal probiert? Raffaele wird sich an die arbeit machen hat er gesagt :) einfach nochmal versuchen
Werde es nachher mal installieren.
Habs nochmal geflasht und im Aroma-Installer diesmal alles auf Standart gelassen und jez hats funktioniert :D
Super! Bei welcher custom einstellung hat es sich denn verabschiedet?
bei mir hat alles tatelos funktioniert! :thumbup:
Hatte das ROM gestern mal drauf, aber die Rotation funktioniert nicht und auf einmal waren meine Schalter in der Statusleiste weg und ich habe es nicht geschafft diese wieder sichtbar zu machen. :bored:
...und auch das Problem, daß im Market etliche Apps fehlen.
Was aber an der "wahrscheinlich" veränderten Density liegt.
Einfach Market Fix oder aus dem Market den LCD Density Modder draufmachen, oder die DPi auf 240 stellen.
Fertig
Das habe ich mir auch gedacht, aber auch bei 240 DPi hat sich nichts geändert.
Zum Thema Rotation habe ich bestimmt vergessen die Sensoren zu kalibrieren. :mad:
Sehr ärgerlich war allerdings, daß die Schalter in der Pulldown Leiste plötzlich komplett weg waren.
Wenn du mit der Auflösung spielst, darfst du nicht vergessen die Market Daten zu löschen..
Rotation und nicht kalibrierte Sensoren? Von Werk aus sind diese eigentlich eingestellt..
Beim Omega AOKP war es genauso, da klappte es erst richtig nachdem die Sensoren kalibriert waren.
Die Daten vom Market hatte ich auch gelöscht.
Das der Gyro-Sensor nicht mehr funktionierte liegt am anktuellen Fluxxi Kernel wenn du den drauf hast. Siyah geflasht und alles läuft Bombe. :thumbup:
Neue Version 0.2 über das OTA Tool erhältlich. Changelog gibt es bisher noch nicht.
edit:
hier nun der Changelog:
Changelog 0.2
Fix Brigthness
Fix Bluetooth
Fix White theme
Update Abyss kernel
Update Fluxi kernel
so wurde aktualisiert neue Version draußen :)
Changelog 0.2
Fix Brigthness
Fix Bluetooth
Fix White theme
Update Abyss kernel
Update Fluxi kernel
