Kaffee4Eck
▬▬▬▬▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬▬▬▬▬▬
Kaffee4Eck AOKP v07
Spenden
ROM-INFO
- AOKP Milestone 6
- Simple, Clean, Fast, Batteryfriendly and Stable
- EZ Launcher aka ADW Launcher 2
- Tweaked Frameworks
- Ad Hoc Support (since B39)
- Multilanguage
AROMA Installer:
Apps:
- MiHome
- MiLocker
- MiFileExplorer
- GO Launcher EX
- Go Locker
- Go SMS
- Handcent
- Nova Launcher
- Apex Launcher
- Trebuchet Launcher
- Titanium Backup
Download AROMA Version include Gapps:
K4E_AOKP_07
Download without AROMA without Gapps:
K4E_AOKP_07oa
Addons:
---> Stock Framework <---
---> Orange Themed <--- OUTDATED!!!
GAPPS
Changelog:
Two Versions are coming:
AOKP_04 with AROMA Installer
AOKP_04oa without AROMA for a SIMPLE and CLEAN Version.
Westcrip (Hardware Info under Settings)
K4E_AOKP_01
K4E_AOKP_02
K4E_AOKP_04oaKaffee4Eck AOKP v07
Spenden
ROM-INFO
- AOKP Milestone 6
- Multilanguage
AROMA Installer:
Apps:
- MiHome
- MiLocker
- MiFileExplorer
- GO Launcher EX
- Go Locker
- Go SMS
- Handcent
- Nova Launcher
- Apex Launcher
- Titanium Backup
K4E_AOKP_07
K4E_AOKP_07oa
Addons:
GAPPS
Changelog:
Changelog v7:Major changes since Milestone 5
Removed FB sync
Added ability to hide sender and/or message body in notifications (Mms)Added CM9 T-Mobile theme manager
Added Sense 4 style Task switcher (you have the option of choosing from stock/web os/sense 4 now)
Added ability to play boot sound (disabled by default) -- read instructions in ROM Control > General > Boot sound
added delayed ring feature to Phone
added Emoji to Mms (enable in Mms settings)
added AOKP wallpapers app
added USB tether toggle,
added AOKP clock widgets
added notification counters
new boot animation
added nav bar widgets (must add nav bar widgets button/long press button in nav bar settings and add some widgets to play with!)
added AOKP stats (www.stats.aokp.co) -- you can opt out
added bluewall firewall - RC > General UI > Less Notification Sounds -- limits the number of notification sounds an app can play per X seconds, so like 1 GTalk ping/30s, but notifications will still be coming in
improved weather code
added "copy to clipboard" option in "Share" dialogs throughout Android
added hardware info in about screen
added new music layout to lockscreen (you can choose between old and new)
added nfc toggle
added nfc polling settings (Settings > More > NFC polling mode)
made lockscreen weather prettier
fixed DRM issues
- Tweaks in frameworks
- Update Kernel
More Stuff i need to check it first. ^^
Changelog v6:
Tweak Frameworks (Complet rebuilded)
Lockscreen Settings works no perfect
ThemeManager and Chooser fixed (Someone can't change Theme)
Settings rebuilded
Frameworks tweaked /Speed/Performance/Smoothness/Stability\
Updated AROMA Files
Changelog v4:
Fixed Settings (Everything should work now fine)
Fixed Update issue with Nova, Apex ect
Fixed Lockscreen Problems (I hope it works now correctly)
Improved Batterylife
Improved GPU and CPU (Only load nothing with Voltage ect)
Hardware Info added to settings (Thanks to westcrip)
Changed Frameworks for Speed, Stability and Smoothness
Updated all Apps in AROMA
Weather Fixed (Should work fine)
Changed SystemUI Icons Color and some files in Framework (Better looking to remove only Blue and Black)
Optimized only for Speed and Stability.
Many fixes here and there.
Credits:v3
NOW AROMA Installer
Fixed Lockscreen
Update Nova Launcher
Added ES File Explorer
Kernel Fluxi XX.02-beta9 (standard)
Fixed Phone.apk
Many things. ^^ I cant remember.
v2
Updated to B40
Added NovaLauncher
v1
Initial Release
K4E_AOKP_01
K4E_AOKP_02
K4E_AOKP_04
K4E_AOKP_05
K4E_AOKP_05oa
Stock Theme:
Orange Themed
Orange Themed
