scarface1991
Stamm-User
- 480
Dies ist die NeatROM basierend auf den SlimKat Sourcen mit einigen Verbesserungen und neuen Features (siehe features-Liste und Changelog).
Die ROM wird von _Sale_ aus dem XDA Forum entwickelt.
Features:
- Compiled from the latest SlimKat repos
- The Real Dark Slim
- Notification drawer Shortcuts
- Full hardware key rebinding
- Keyboard rotation
- Nova Launcher
- Superuser
- Darker Camera - colour filter options, gps indicator, picture quality, smart capture, shutter sound...
- Darker Gallery
- Phasebeam LiveWallpaper
- Wifi country code
- Mediascanner behaviour on boot
- Volume key cursor control
- Show permanent enter key on keyboard
- IME selector notification
- Auto keyboard rotation feature
- Systemwide blacklist support for calls and sms/mms
- Pattern size customizing
- Lock before unlock the new way
- Lockscreen shortcuts
- Fully revamped lockscreen target options
- Start widgets maximized on lockscreen
- Enable carousel animation on lockscreen
- Enable/disable camera widget on lockscreen
- Full customizable low battery warning
- Wake up on charge
- Volume rocker wake
- Volume rocker music control
- CRT animation the new way with new animation as well
- Fully customizable auto brightness
- Display rotation options (0, 90, 180, 270)
- Fully customizable volume panel
- Power connectivity alert
- Less frequent notification sounds
- Ascending ringtone
- Control safe headset warning
- Mute Camera shutter sound
- Quiet hours new extended version
- Mute Volume adjust sound
- SlimCenter
- Fully global menu customization
- Fully revamped navigation bar and navigation ring customizations
- Statusbar brightness control
- Full Clock and date customization on status bar
- Battery icons
- Quick settings style options
- Quick pulldown for quick settings
- Easy full swipe access between notification drawer and quicksettings
- Wifi access point is shown in notification drawer
- Hide carrier label on notification drawer
- Notification drawer shortcuts
- Notification transparency
- Notification drawer and quicksettings background as well with tablet support
- Fully customizable quick settings the new way with new included music tiles and features
- Battery tile new click/longpress behaviour
- Allow to disable QuickSettings completly
- Option in Dev Set to customize the device hostname
- SystemUI - double tap to sleep gesture
- IPV6 tethering support
- Allow applications to override power key
- DeskClock - back flip and shake actions
- Navigation bar
- Global menu - Expanded desktop
- Added CPU & RAM info
- Wakeup Options
- Enable/Disable Root (Enabled by default)
- Fixed StatusBar Back Button
- Es File Explorer
- NeatROM | Simple, Clean & Reliable as default home page for browser
- NeatROM Bootanimation v4
- Enabled HD Voice
- Init.d Support
- Added support for ADB over network
- Disabled charging LED
- Fully Customizable Hardware Buttons
- Disable/Enable Menu Key Unlock
- Clear all Recents Button (moved to the top/right)
- Better Battery Life
- Added Battery Animation while Charging
- Noise suppression for phone calls
- Browser-Enabled Bookmarks Sync
- No Call Ring delay ~0ms
- Fixed Custom Toggle
- Browser-Blue Progress Bar
- Added SlimPie
- Added Download Speeds in notification
- Fixed Camera-Save video to external SD Card
- Fixed Camera-Focus Mode
- SlimKat Stable
- New Dialer - Bigger Caller Photo
- Install Non-Market Apps Enabled by Default
- Package Verifier Disabled by Default
- Custom LED Charging Menu
- New Tweaks
Und vieles mehr
Kompletter Changelog:
xda-developers - View Single Post - [ROM][Apr 11][4.4.2] I9300 AOSP NeatROM v4.2
Screenshots
Installation
- Ins Custom Recovery booten
- Nandroid Backup von der jetzigen ROM machen
- Wenn ihr von einer anderen ROM kommt, Wipe Data / Cache
- Heruntergeladene zip auswählen und flashen
- Google Apps flashen
- Neustarten
