Beendet: MXQ Pro+ TV Box 64 Bit Android 5.1
  • 3 Antworten
Gast
Verkaufe eine nagelneue und nur kurz ausprobierte TV Box mit Android. Die Box ist angeblich 4K tauglich und soll so gut wie alle Medien fressen, leider bin ich mit der Oberfläche überfordert und habe keine Zeit mir das anzupassen etc.
In den Specs stehen folgende Dinge:
Amlogic S905 Quad Core
2GB RAM
16GB ROM
2.4G 5.8G Dual-band WiFi
Gigabit Ethernet
Bluetooth 4.0 Connectivity
Support 4K
Genauere Beschreibung:
This MXQ Pro+ TV Box is equipped with Amlogic S905 quad-core CPU and Mali-450 GPU. It is a multimedia center which enables you to have the absolute best and most versatile home media experience. It will let you enjoy plenty of HD movies, TV dramas and more videos on demand whenever you like with your friends and family.
Main Features:
● Amlogic S905 quad-core CPU is rapid and stable which can give you high speed feedback and smooth response.
● Mali-450 as GPU of this TV Box which gives you the high definition pictures and videos.
● With 64bit Android 5.1 stable and smooth system.
● 2GB RAM + 16G ROM: It gives you more space to download your favorite apps and caches to browse websites, play games, run apps, watch movies more smoothly.
● 2.4GHz / 5GHz dual-band WiFi (10 / 100M / 1000M Ethernet): It offers a more stable WiFi signal for you to enjoy higher quality video experience.
● Bluetooth 4.0 connectivity: Easy pairing with most Bluetooth-enabled devices (computer, mobile phone, keyboard, and others).
● Supports H.265 video code, enjoy the high-resolution video even at a low-internet-speed environment.
● Supports 4K HD video, which brings us clearer image quality and 3D vision enjoy.
● HDMI 2.0 connector: You can directly connect your TV to MXQ Pro+ TV box through a HDMI cable and set up your home cinema for the best 4K x 2K HD multimedia experience.
● Supports multiple language and multiple format video.
● Network functions: VUDU, Miracast, XBMC, Airplay, Skype chatting, Youtube, Flicker, Facebook, online movies, etc..
● Free Internet searching, thousands of android applications, many kinds of games, etc..
● Infrared remote control let you enjoy your wonderful life which the wireless brings to you.
Specifications
General
Model: MXQ Pro+
Type: TV Box
GPU: Mali-450
System: Android 5.1
CPU: Amlogic S905
Core: 2.0GHz
RAM: 2G
ROM: 16G
Color: Black
Media Supported
Decoder Format: H.265
Video format: 4K,4K x 2K,ASF,AVC,AVI,DAT,DIVX,FLV,H.264,H.265,ISO,MKV,MOV,MPEG,MPEG1,MPEG2,MPEG4,MPG,RM,RMVB,TS,VC-1,VOB,WMV
Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
Photo Format: BMP,GIF,JPEG,PNG,TIFF
Product Details
Bluetooth: Bluetooth4.0
Power Supply: Charge Adapter
Interface: AV,DC Power Port,HDMI,RJ45,SD Card Slot,SPDIF,USB2.0
Language: Multi-language
Firmware Information
System Bit: 64Bit
Power Requirement
Power Type: External Power Adapter Mode
Power Adapter Output: 5V 2A
Dimension and Weight
Product weight: 0.200 kg
Package weight: 0.520 kg
Product size (L x W x H): 11.50 x 11.50 x 2.80 cm / 4.53 x 4.53 x 1.1 inches
Package size (L x W x H): 24.00 x 12.80 x 6.10 cm / 9.45 x 5.04 x 2.4 inches
Package Contents
Package Contents: 1 x MXQ Pro+ TV Box, 1 x IR Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
Verkaufe die Box für 35 Euro inkl. Versand
Reaktionen: electric540
Hier ich, schreibe mir eine pn ich nehme die Box
Sollte electric, unerwartet abspringen melde ich mich mal als nächster.
Verkauft
OswaldKnolle
  • Gesperrt
OswaldKnolle
OswaldKnolle
mareis1973
mareis1973
mareis1973
kubean
kubean
kubean
mamibe
mamibe
mamibe
