Eyjafjallajökull
verkaufe meinen kaum genutzten Einplatinencomputer.
Rock - Radxa
Radxa Rock Pro is a update version of Radxa Rocksingle-board computer, based on RK3188, integrated with Bluetooth 4.0, WiFi, LAN, RTC, IR and etc. The CPU is ARM Cortex-A9 with Quad-core at 1.6Ghz, and also including GPU that support OpenGL ES 2.0. you can play 1080p videos, and output with HDMI. There are 8GB flash internal storage, also can be expanded via MicroSD card that supports SDXC cards up to 128GB. As a barebones single-board computer, the key feature for developers however will be the dual 40-pin headers that provide a range of extra goodies including 'GPIO, I2C, SPI, Line in, USB 2.0, PWM, ADC, LCD, GPS' and more.
Specification:
Power consumption requierments: 5V2A
Dimensions: 10x8cm (4"x3.1"), about 1.2cm (0.5") tall
Compatibility: android, linux FreeBSD System Characteristic
CPU: ARM Cortex-A9 quad core @ 1.6Ghz Memory 2GB DDR3 @ 800Mhz
Storage: 8GB Nand Flash, Micro-SD SDXC up to 128GB Display and Graphics
GPU Mali400-mp4@533Mhz, OpenGL ES 2.0
Digital Video HDMI 1.4 up to 1080p@60hz
Analog Video AV output
Network LAN 10/100M Ethernet port
WIFI 150Mbps 802.11b/g/n with antenna
Bluetooth Bluetooth 4.0
I/O Add LVDS interface(FPC connector at the bottom of the board)
Add touch panel interface
Add CSI interface for camera module Audio S/PDIF, headphone jack
USB HOST 2 USB 2.0 standard A type
USB OTG USB OTG micro-USB connector
Serial Serial Console for debugging
IR Support self defined IR remote
Other
Led 3 programable leds
RTC Support power off alarm
Extend header 80 pins including GPIO, I2C, SPI, Line in, USB 2.0, PWM, ADC, LCD, etc
Rock - Radxa
Specification:
Other
