		tomtom12
Informationen aus dem ARCTABLET Forum übernommen, bitte löschen falls nicht erlaubt.:
ARCTABLET Forum
Ich habe die Rom jetzt seit kurzem laufen und muss sagen ich bin begeistert!
Läuft alles soweit Problemlos!
		Code:
	This is a generation 2 loader KK build for high-resolution tabs and RK903 wifi   ;-)
Elegance by Oma KitKat build v1.0
 stock 4.4.0 recovery, CWM 6.0.3.1 recovery
 system ext4
 selinux kernel yf #49 preempt 22.05.2014
 internal storage 4 GB
 ethernet support
 init.d support
 gameloft compatible
 USB-Hub enabled
 gamepad compatible (PS2, XBox,
 kernel modules (cifs, tun, lan, serial, audio)
 latest hosts, su, su-binary, busybox
 Reboot Menue, sEFix, FX Sound
 Dateimanager HD (Root)
 Nova Launcher
Flash instructions are included in the download pack.
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware.
hints:
 to improve UI feeling disable animation scales in developer options
 to improve battery drain set keep wi-fi on during sleep to never
 to get full access to the build enable /system rw in File Manager HD
 to disable su notifications change notification in su app
 to prettify the build use Xposed Framework > Starterpack
 to enable multi-user use the Xposed module Multi User
Thanks to gebe14 ;-)
Be aware: it is your own risk!
  Oma -ARCTABLET Forum
