h0sch180
Ehrenmitglied
- 2.238
- Themenstarter
- #21
Update ist da!
Changelog
Changelog
Code:
08-04-2020
* build/
120732527 Bump Security String to 2020-07-05 [h0sch180]
624bbd835 Bump Security String to 2020-06-05 [h0sch180]
5704d3297 Bump Security String to 2020-05-05 [h0sch180]
7d958e6df Bump Security String to 2020-04-05 [h0sch180]
cce31030d Bump Security String to 2020-03-05 [h0sch180]
080588b2c Bump Security String to 2020-02-05 [h0sch180]
f37b14bbb Bump Security String to 2020-01-05 [h0sch180]
365169c36 Bump Security String to 2019-12-05 [h0sch180]
75b44a929 Bump Security String to 2019-11-05 [h0sch180]
16012bd67 Bump Security String to 2019-10-05 [h0sch180]
ce3f1ef7a Bump Security String to 2019-09-05 [h0sch180]
5409bee34 Bump Security String to 2019-08-05 [h0sch180]
0073566cd Bump Security String to 2019-07-05 [h0sch180]
f0f1fb77e Bump Security String to 2019-06-05 [h0sch180]
dc4856378 Bump Security String to 2019-05-05 [h0sch180]
* frameworks/base/
3867e2d1359 Verify all possible hosts that match web nav [h0sch180]
ca6cca5a1a3 RESTRICT AUTOMERGE Use consistent calling uid and package in navigateUpTo [h0sch180]
2c663621318 RESTRICT AUTOMERGE Create separated tasks for different apps from startActivities [h0sch180]
8848e6fe755 Fix potential double destroy of AssetManager [h0sch180]
8850add95f2 Revoke 'always' web handler status when not autoverifying [h0sch180]
c09509ffe5b Fixes NPE when preparing app data during init [h0sch180]
58904a029c9 Handles null outInfo in deleteSystemPackageLI [h0sch180]
0c4fbc0f339 Fix security problem on PermissionMonitor#hasPermission [h0sch180]
520bcd3c05a RESTRICT AUTOMERGE Make toasts non-clickable [h0sch180]
e0d156cfa3e DO NOT MERGE back porting for fixing sysui direct reply [h0sch180]
69caa6736b8 DO NOT MERGE: Disable SpellChecker in secondary user's direct reply [h0sch180]
6bd54f45df6 Prevent system uid component from running in an isolated app process [h0sch180]
43ed5f1017f Only allow INSTALL_ALLOW_TEST from shell or root [h0sch180]
69fffeebbc2 DO NOT MERGE Validate wallpaper dimension while generating crop [h0sch180]
afe5d3dbcbb Do not compute outside given range in TextLine [h0sch180]
2f744c08780 RESTRICT AUTOMERGE Strict SQLiteQueryBuilder needs to be stricter. [h0sch180]
c39d8bab2bb Set default phonebook access to ACCESS_REJECTED when user didn't choose one [h0sch180]
2ddf8b0e754 RESTRICT AUTOMERGE Enable stricter SQLiteQueryBuilder options. [h0sch180]
3cfc9f36def Add MANAGED_PROVISIONING_DPC_DOWNLOADED (nyc). [h0sch180]
4d0117901ea Fix Layout.primaryIsTrailingPreviousAllLineOffsets [h0sch180]
eaeea6a4937 HidProfile: sync isPreferred() with HidHostService [h0sch180]
51e6ea50fb2 Clear the Parcel before writing an exception during a transaction [h0sch180]
ed238a93519 Add cross user permission check - areNotificationsEnabledForPackage [h0sch180]
baf08090d70 Limit IsSeparateProfileChallengeAllowed to system callers [h0sch180]
5300247c5d6 Permission Check For DPM.getPermittedAccessibilityServices [h0sch180]
dea2a60f968 Added missing permission check to isPackageDeviceAdminOnAnyUser. [h0sch180]
c0af1527ac7 DO NOT MERGE - SUPL ES Extension - Safer Init and Not After Boot [h0sch180]
* frameworks/native/
cc9a1ed38 Don't leak input events to dumpsys on user builds [h0sch180]
fa95a1e11 Resize object capacity when shrinking Parcel [h0sch180]
8f38f1954 Sensor: use FlattenableUtils::align [h0sch180]
279cb08ac Fix race between SensorManager ctor and callback [h0sch180]
5b3e6650b Free mObjects if no objects left to realloc on resize [h0sch180]
0698ef758 libbinder: readCString: no ubsan sub-overflow [h0sch180]
b6a735a8f libbinder: Status: check dataPosition sets. [h0sch180]
* n_asb/
ef47b5856 add n-asb 05-07-2020 [h0sch180]
* packages/apps/Settings/
c512bab1b5 RESTRICT AUTOMERGE Allow LockScreenPattern to be launched in the pinning screen [h0sch180]
4c47bf99c2 Prevent accounts page directly opening in screen pinning mode [h0sch180]
918354d371 Make ScreenPinningSettings behaviour consistent with lock tasks. [h0sch180]
16134aee57 Do not allow draw on top for App notification settings [h0sch180]
5ccdb14273 Do not allow draw on top for default sms picker. [h0sch180]
* system/core/
9d8f6fca3 FlattenableUtils::align memsets [h0sch180]
ac09655b5 Fix a memory leak in gatekeeper. [h0sch180]
08-03-2020
08-02-2020
08-01-2020
07-31-2020
07-30-2020
07-29-2020
07-28-2020
07-27-2020
07-26-2020
07-25-2020
07-24-2020
07-23-2020
07-22-2020
07-21-2020
07-20-2020
07-19-2020
07-18-2020
07-17-2020
07-16-2020
07-15-2020
07-14-2020
07-13-2020
07-12-2020
07-11-2020
07-10-2020
07-09-2020
07-08-2020
* android/
3880308 manifest: Track our own dng_sdk [syphyr]
* external/chromium-libpac/
0f300f3 Cherry-pick "Refactor Regexp.prototype" [syphyr]
* external/dng_sdk/
6859c11 Targeted minimal fix for security issue in CVE-2020-9589. [syphyr]
* external/v8/
2060ac7e [RESTRICT AUTOMERGE] Cherry-pick "Refactor Regexp.prototype" [syphyr]
07-07-2020
07-06-2020
