[ROM][16/09] ThiaiZO3D V1
  • 19 Antworten
  • Neuster Beitrag
joker.20
joker.20
Threadstarter
hier ein großartiges rom. OHNE LAGS!
ThiaiZO3D-Stock,Stable and fast Welcome to ThiaiZ O3D V1.0
I saw that a lot of people out there would like a stock,stable,fast and rooted ROM, so i decided to make one on my own, keeping it as much as stock as possible.This is my first O3D ROM (promised to myself that i would just start developing after GB update, but its comming very soon so it's time) . I'm coming from HTC Desire and Samsung Galaxy S2 where I have always developed my own ROMs.Be patient and I do really want to help this community to grow and find the best for this incredible peace of engineering called LG Optimus 3D.Suggestions are always welcome.
Here is how it looks:
YOUTUBE video comming soon
Features:
-Base: V10e
-Kernel:Acura Team Beta Kernel (Thanx Acura Team)
-Deodexed,Zipaligned (by me .apks from my old V10d)
-Some extra tweaks for speed and memory.(They are really working)
-Everything from LG is still there. (No Gulliver's book)
-ES explorer + CPU master. (Just free apps on my ROMs)
-HTC IME (Install from /data/app if you want it)
-Latest Android Market.
-Old busybox version 1.18.2 (to V6 Supercharger script)
-A little theme changing.
Known bugs:
-Default Ringtone can't be changed[FIXED]. Flash the update above
Multiupload.com - upload your files to multiple file hosting sites!
How you Install it:
-Download and copy the .ZIP file onto your SD or Phone.
-Restart device in CWM (Vol down + power)
-Backup your old Rom
-Wipe data + cache (All your data will be gone)
-Choose "Install Zip from SD card"
-Browse the .ZIP file and install it.(takes 3 minutes)
-Boot device and ENJOY.
-Start CPU master and change Scaling to "hotplug"
-Navigate with a file explorer to /system/etc/init.d and change permission on both scripts to "777" it means mark the 9 permission options.Reboot and the ROM is going to be faster.
-I do really recommend this [Script][Update 9 Beta 6!] V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! - xda-developers ask me if you dont know how to do.
-I'm not responsible for your mistakes you should know what you are doing.
THANX:
-ACURA Team http://www.htcspain.com/roms-384/acu...-2011-a-50087/
-Zeppelinrox for V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! [Script][Update 9 Beta 6!] V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! - xda-developers
-Ipy (Smoothness tweak) I re-made it to our O3D
**If you think this ROM is good, buy those people under thanx or myself a beer**
edehahn
edehahn
Stammgast
jetzt v1.3 verfügbar: [ROM][27/09] ThiaiZO3D V1.3-Stock,Stable and fast - xda-developers
Download: Multiupload.com - upload your files to multiple file hosting sites!
Features:
  • Base: V10J
  • Kernel:Stock Kernel
  • Everything from LG is still there. (No Gulliver's book + Angry birds)
  • 3D converter.
  • Deodexed,Zipaligned
  • Some extra new tweaks for speed and memory.(They are really working)
  • ES explorer + Skype patched + APN Manager. (Just free apps on my ROMs)
  • HTC IME (Install from /data/app if you want it)
  • Latest Android Market.
  • Old busybox version 1.18.2 (to V6 Supercharger script)
  • Performance pack.
  • Original 3D games (Nova,Golf2,Asphalt6) are patched to be installed on SDCARD.
Installationshinweise im XDA-Thread beachten!!
Kyomo
Experte
Funktioniert super, aber der Market geht nicht mehr. Also doch, ich kann downloaden, aktualiseren und so weiter, aber nichts mehr kaufen, dann kommt: "Ein Fehler ist aufgetreten. Versuchen sie es noch einmal" Ärgerlich.
Kyomo
Experte
Das ging flott: V 1.4.: [ROM][02/10] ThiaiZO3D V1.4-BaseV10K-Stock,Stable and fast - xda-developers
Download: http://www.multiupload.com/KG6CJ4WO09
Features:
-Base: V10K
-Kernel:Stock Kernel
-3D converter.
-Some extra new tweaks for speed and memory.(They are really working)
-ES explorer (Just free apps on my ROMs)
-HTC IME (Install from /system/app if you want it)
-Performance pack.
-Original 3D games (Nova,Golf2,Asphalt6) are patched to be installed on SDCARD.
-No themes on my ROMs anymore.Instead do your own here UOT Kitchen. Kitchen .Donate to them if you think the kitchen works good.
trax
Features:
-Base: V10e
Known bugs:
How you Install it:
THANX:
can you build in the tun.ko into yor rom? I need it for a vpnc (cisco) connection.
Thanks !
edehahn
edehahn
Stammgast
Thanks !
you should ask to ThiaiZ (who made this rom)
eydz
ist irgendwer der meinung es sei besser als king rom 3d?? und wenn ja wieso??
softkatze
Also ich bin der Meinung, das diese besser als die King Rom ist.Mehrere Gründe sind da anzuführen.Für mich ist es leider nicht ganz so schön, dass in der King rom alles dierekt in der Rom ist.Zum Beispiel der Go louncher der in der Rom Probleme bereitete (Beim beenden und dann wieder neustarten des Handys immer die gleichen Dinge auf 2 Homescreens,obwohl nur auf einem installiert und so weiter).Das nervt schon.Mit dieser Hier ist das Gott sei dank nicht der Fall wiemit diesem Schrecklichen Komplettpaket King Rom.
softkatze
Kyomo
Experte
Läuft in V1.5 sehr flüssig, bin begeistert. Es gibt auch wieder ein nicht aufdringliches aber doch schönes Theme von Haus aus.
Steffen1337
Screenshots bitte :)
Kyomo
Experte
Steffen1337 schrieb:
Gerade probiert, die Anwendung com.lge.util wurde unerwartet beendet. Habe sie in Titanium aber in Ruhe gelassen... Vorhanden ist sie.
Keine Ahnung, ob ich jetzt zufällig ein Bug in der ROM gefunden habe :confused2:
Motawa
-Restart device in CWM (Vol down + 3D + power)
Ist das alles was man tun muss? Oder muss man auch rooten?(was auch immer das ist^^)
Motawa
Stimmt schon aber dann ist die "how to install" anleitung trotzdem unvollstaendig(sonst haette ich ja nicht gefragt)
Gibts auch ein How To fuer uotkitchen(abgesehen von dem auf der hp)?
Motawa
Link ist leider tot.
schnibbel001
Hi All,
kann mir bitte jemand sagen, wie ich diese ROM wieder runter bekomme ?
Notfallwiederherstellung funktioniert nicht. Da kommt immer nur: Diese Gerät kann nicht wiederhergestellt werden, oder so ähnlich.
Bitte helft mir. Würde gene wieder auf das originale ROM zurück.
schnibbel001
Vielen Dank Ixi,
Du bist echt mein Held.
