hanspampel
Ehrenmitglied
- 9.865
- Themenstarter
- #21
Das wiste wohl selber flashen müssen um das rauszufinden.
Updated Kernel
Added Quick Pin Unlock (Settings/Security)
cLock Updates
Lockscreen Target Overhaul
NavRing Overhaul
Added CMs Calculator (More functionality)
Added flip and shake to snooze option to Deskclock
Added Increasing Volume option for Deskclock
Enable support for WebGL in Browser
Added Sleep Toggle
Added ability to allow Lockscreens to be themed when using themes
Added Allow 270 degree rotation (ROM Control/General UI)
Added Scrollable Toggles
Added Traditional Toggles
Added Backlight Curve Adjustment Settings
Updated Performance Control
Updated a ton of strings in ROM Control (Menus are a little less likely to be misunderstood.)
Added Reboot Toggle
Disable fast toggle if traditional/scrollable style is active
Added Screenshot Toggle
Added Screenshot Delay option
Fix opacity of LastApp Icon
Prevent Kill Task from killing SystemUI
Fix memory leak when creating SkBitmapProcShader
Added option to disable camera sounds
Added Cell Broadcasts
Fix NavRing icon size
I know there's more. Way too tired for this ChangeLog.
Updated Kernel
Updated to latest Nova Launcher
Gapps package updated to latest everything (Make sure to download it!)
RAM Bar View optimizations
Added AOKP Ribbons (ROM Control/Ribbons)
Lockscreen Targets Speed Optimizations
cLock Updates
Added Block Private Numbers To Blacklist Options
Toggles are in alphabetical order now
Fixed recents minimization animation
Fixed Potential FC on Hiding NavBar
Animate Transparency changes. (Instead of the white block in the status bar when switching between apps, it now look like a fade transition.)
SystemUI: fix memory leaks
Fixed Signal toggle layout
Made the HSPA+ drawables more consistent with the HSPA drawables
Fixed Screen Sizing for TabUI when HiddenNav Enabled
Added Transparency for TabletUI
Added Blacklist Options (Phone/Settings)
Brought Swagger toggle back
Added LongClick to FastCharge Toggle
Added Trickster Mod to Settings (This replaces Performance Control)
Fixed cursor leak in Email
Don't clear wallpaper when SystemUI disconnects
Fixed apps from crashing
Fixed cLock
Allow enabling WebSockets from Labs Preferences in Broswer (HTML5)
Lockscreen: adjust layout of GlowPad
Fixed NavRing Icon size
Fixed potential deadlock between LockScreen and WindowManagerService
Updated Vibration Patterns
Fixed a cursor leak
Fixed a race condition in backlight adjustment
I'm sure there's more I'm missing....
