[ROM][JB][FLO][JWR66Y][OTA] Jellybam 10.3 [14/09/13]
  • 2 Antworten
T-119a
T-119a
Jellybam vereint die Features von CyanogenMod, AOKP, Paranoid Android, Slimbean, PacMan und RootBOX.
In anderen Worten, hier findet man alle erdenklichen Features, die man bisher in Aosp Roms gesehen hat.:cool2:
Installation:
  • Wipe data / factory reset
  • Aktuelles Build flashen
  • Gapps sind schon enthalten!
  • Neustarten
  • Win:flapper:
Aktueller Changelog:
Code:
JellyBam v10.4 Changelog :
* Merge tag Android 4.3_r3.1 and bump the build up to JLS36G
* Fixed tf700t dpi issues
* Fixed blacklist settings fc
* Fixed hardware keys button rebindings and action, bring everything inline with CM
* Ported Active Display from chameleon OS
* Ported AOKP theme chooser
* Added ability to choose the lockscreen style (jellybean, eclair, froyo, ics and optimus)
* Fixed settings tile
* TabletUI: Hack to show statusbar icons while Halo is active
* BAMControl: Audio Settinngs: Add lock volume key in silent mode
* Calculator: Fix issue while in tablet mode (FC on switching calculator type)
* Fix many race condition, NPE, Memory leaks
* i9103: Switching device tree to avoid the call issue
* Contacts: Fix custom vibration selection
* Fixup Dock
* Update gapps
* Update ringtones and merge new cm ones
* Fix fstab memory leak
* Update PA to 3.99-RC2
* BAMControl: Active display a.k.a Moto live notifications!
* BAMControl: Active display: proximity sensor option
* BAMControl: Active display: add option for date
* BAMControl: Active display: add sunlight mode
* BAMControl: Icons update. Now everythings will be holo with holobam
* Trebuchet: Added gestures
* Trebuchet: Added icons scaling option
* Trebuchet: Added ability to customize application drawer background (Color or current wallpaper)
* Fix many race conditions and a big memory leaks on media scanner
* Update all PNGs image
* Bring back advanced settings (located under more...)
* Many new devices, many new fixes, much responsiveness, much smooth, much battery life ALL TO GETTTTTHER
Download:
-Kein Support für flo
Jellybam Forum:
BAM Android
Warum gibt es diese Rom nicht auf XDA?
Kann jemand was darüber berichten? danke
