Endavour@Pyramid | TripNDroid Mobile Eng.| ICS | with Sense 4.0 |
MrSchneiderish
MrSchneiderish
22
Hallo Leute,
hier ein mal das Neuste von TripNDroid. Es handelt sich dabei - meines Wissens jeweils - um die erste Custon ROM mit HTC Sense 4.0!
[PROJECT] [DEV] [ROM 16-02] Endavour@Pyramid | TripNDroid Mobile Eng. | JOINT VENTURE - RootzWiki
Posted 13 February 2012 - 01:57 AM
This is the announcement of a new rom for the HTC Pyramid!
Endavour! @Pyramid
This rom is an port of the leaked RUU for the HTC Endavour (Tegra 3)
For the first time TripNDroid Mobile Engineering is collaborating as a "Joint Venture" with other members to bring this rom to all Pyramid users.
At this point the team includes the following members;
- TripNRaVeR
project starter and maintainer
development
- baadnewz
development
- newtoroot
development
- V6-Maniac
development
- TMartin
development
Credits for this project are for the whole TEAM! TripNDroid Mobile Engineering, this time, will just function as a release platform to provide a regular way of releasing this. This is done so that there wont grow 10-20 topics for this rom which will lead to nothing. Now we have one place to discuss this rom.
Team members will receive the rom today, after we are all satisfied with the results it will be released!
Current status working:
- mobile network, data, sms
- wifi
- hwa
- sound
- gps
Not working:
- bluetooth
- videoplayback
- youtube(????)
- camera
Download:
http://www.4shared.c...ipNRaVeR-0.html
Dev-Host.org - The Ultimate Free File Hosting / File Sharing Service
If you have overlay issues as in popups not showing up then touch statusbar once to fix it! DO NOT REPORT IT
THIS RELEASE IS A DEVELOPER PREVIEW
READ: pre pre alpha beta whatever
Can be used daily with some issues, do not complain, do not request just play!
ENJOY!!
T.
Reaktionen: Ravenna
Erste custom rom mit android 4.0? Fail.
Ich bin der Meinung krawily schrieb erste ROM mit Sense 4.0!!!!?????
Der Meinung bin ich aber auch *wildmitLesebrillenumsichwerf* :)
Um genau zu sein, bei den Software-Daten ist Android 4.0.3 aufgeführt.
Fail-Fail würde ich sagen (aus dem Alter bin ich raus, keine Ahnung ob man diesen Begriff verwendet...)
Zum Thema:
Habe es eben schnell in der Mittagspause flashen können. Nach einigen Minuten muss ich sagen, dass diese ROM als wirkliche Alpha-Version zu verstehen ist!
Vom Funktionsumfang ist demnach alles grundlegende vorhanden, Mail, WLAN, Telefonie, Browser, Twitter, Wecker....
Großes Manko, der Market ist nicht vorhanden. Ich weiß grade nicht, ob es daran liegt dass ich mich nicht mit dem HTC-Konto verbunden habe oder schlicht daran, dass es sich um ein frühes Entwicklungsstadiumhandelt.
Nächster und sehr gravierender Punkt ist es, dass ab und zu beim Wechseln zwischen Menüs, nicht sauber dargestellt wird. Es kommt zu starker Fragmentierung und overlay problemen "If you have overlay issues as in popups not showing up then touch statusbar once to fix it! DO NOT REPORT IT".
Das größte Problem dabei ist:
Wenn ich z.B. meinen Posteingang per Home-Button schließe, sieht es aus als ob dieser nicht geschlossen wurde. Alles ist sichtbar, als ob ich noch im Posteingang wäre...ABER! Rein funktionell bin ich auf dem Homescreen, nur sehen kann ich ihn nicht, da sie "Schließ-Animation" buggy ist. Es kommt sogar sehr häufig beim Entsperren vor, dass ich noch den Entsperrscreen sehe.
Nach 34 Sekunden kam ich durch Zufall auf einen Workaround --> Kurz das Drobdown-Menü runterziehen und das Display wird refreshed.
Fazit den ROMs:
Sense 4.0 sieht in dieser Version schon sehr gut aus. Ich Sense-Gegner bin sehr positiv überrascht, dass ein sehr großer Bezug auf die Optik von Android ICS gemacht wurde. Es macht einen lockeren, leichten Eindruck
und trägt im Gegensatz wie Sense 3.0-3.5 nicht so dick auf.
Die reine Usability der ROM ist zusammengefasst: ALPHA!
Man sollte demnach die Aussage "THIS RELEASE IS A DEVELOPER PREVIEW --> READ: pre pre alpha beta whatever" schon sehr ernst nehmen :)
Kleiner Lichtblick: Laut twitter wird Trip bald ein erstes Update einspielen. Und das heißt bei ihm 1-2 Tage höchstens.
Da du sie ja schon so gut getestet jast, kannst du mir sicherlich auch eine Frage beantworten: Hattest du auch kein Sense als Launcher? Ich hatte den Stock-Launcher, den Stock-Lockscreen und auch nur die Stock-Widgets. Nur die Apps waren im Sense-Look.
mfg Marcel
mfg Marcel
Jop, same here. Man bekommt vorerst nur einen kleinen Einblick.
seit ich diese rom drauf habe, funktioniert mein htc sensation nicht mehr... dh. ich kann es nicht mal aufstarten, der display bleibt schwart. was kann ich dagegen tun?
Hast du wirklich die ROM per Recovery geflasht oder die ganze RUU? Wenn zweiteres, dann hast du jetzt nen Backstein. Du kannst nicht einfach ne RUU eines fremden Gerätes flashen.
Kommst du denn noch in den Bootloader?
mfg Marcel
ich komme nicht mehr in den bootloader. ich habe es per recovery geflasht.
Also, ich bin da ganz normal ins recovery menu rein und dann von dort aus installiert.
Edit:
Was kann ich jetzt tun?
Also wenn du nicht in den Bootloader kommst, nimm mal den Akku raus und leg ihn wieder ein. Warte 15 Sekunden und schließ das HTC an den PC an. Sollten Treiber von Qualcomm installiert werden, hast du eventuell ein Problem. Denn dann wars das wohl. Nur was da passiert ist, kann ich dir nicht sagen.
mfg Marcel
Hattest du vorher schon eine Android 4.0.x Version geflasht?
Hboot aktuell?
HTC RUU aktuell?
SuperCid?
Nen changelog scheint es nicht zu geben, oder?
Bei mir läuft Sie bisher sehr gut. Werde berichten. Akku zieht recht schnell leer.Gibt es da vielleicht einen besseren Kernel?
Gesendet von meinem HTC Pyramid mit der Android-Hilfe.de App
Moi, moin,
es läuft so weit recht sauber und ist halbwegs als alltagstauglich zu bezeichnen.
Ich nutze diese ROM seit etwas 2 kompletten Tagen und heute wirds das erste mal richtig gefordert, sprich Mail, Web, Musik, SMS, Telefonieren, bloggen usw...
Was ich bis jetzt gemerkt habe ist, dass einige Animationen noch stark zerhackt sind und unsauber laufen. Damit kann man aber leben, denn Funktionen sind so weit kaum gestört.
Lediglich die Shutdown-Animation und die Wetter-app sehen unpassend von der Auflösung aus.
Der Musicplayer schmiert immer ab und muss geschlossen werden...schade, da es für mich recht wichtig ist (es leben die öffentlichen Verkehrsmittel!)
Fotos und Videos kommen jedoch wie geleckt :)
Von ICS sieht man im Gegensatz zur vorherigen Version nichts mehr. Optisch ist es so weit meine Erfahrung zulässt komplett Sense 4.0 mit haufenweise Widgets. Dabei ist Sense endlich nicht mehr so übermäßig dick aufgetragen und es entsteht ein "leichter" Eindruck.
Super ROM für mich.
Und schon ist die beta 003 raus.
Mal sehen, ob ich schon vormittags an die ROM rankomme.
Bluetooth soll nun gehen, Soundprobleme wurden gefixt und weitere Optimierungen sind eingeflossen.
Grüße
MrSchneiderish
Gesendet von meinem HTC ENR_U mit der Android-Hilfe.de App
Beta4 is raus, nur der download fehlt...
Changelog 004:
- Update bluetooth fix
- Fixed graphics tearing and glitches
- Teeter added
- Fixed some weather stuff
- Fixed downanimation
- Fixed gps
- Hacked for Qualcomm chipset
- Hacked overlay support (not fully working)
- Hacked Qualcomm's way of graphics instead of Tegra 3
- Removed some Tegra stuff
Hmm da er vor 20min angefangen hat die Rom hochzuladen könnte es bei 450-500mb rom gute 1-2h dauern ^^
Also denk ich mal das Virtuous in ca. 12h die Build 4 bringt ^^ xD Wenn ihr versteht was ich meine...ich sag nur CAMFIX ^^
Außer m-deejay hält sich wirklich dran und wartet auf den Ruu-Leak vom HTC ONE
Edit.: 18 minutes left -_-'
Edit2.: Und da ist er http://www.4shared.com/zip/nxqlULek/Endavour_pyramid_TripNDroid_00.html
Slassh woher hast du die Info das schon wieder eine Neue Version gibt?
Auf auf xda ist noch nichts neues zu lesen.
Gesendet von meinem HTC Sensation XE with Beats Audio mit Tapatalk
O
OneGamer
O
  • candlebox
daniel9180
  • minecraft2014
Ruftac
