rhrawr
HeatshiverLX - 4.2.2 for D802
Light eXperience
If I did it right, you won't even know it.
Light eXperience
DEUTSCHE INFO
Diese Rom basiert auf der Version JGQ39B des LG Stock Rom. Zur Verfügung steht eine Deodexed Version (empfohlen) und eine Odexed Version. Die Deodexed Version ist weitestgehend angepasst, während in der Odexed Version kein Custom Kernel und sonstige Veränderungen zum Einsatz kommen. Außerdem besteht die Möglichkeit eines der verlinkten Pakete zu wählen und das Rom so seinen eigenen Vorstellungen besser anzupassen (mehr unter Pakete).
ÄNDERUNGEN
Aus Original-Thread zitiert...
v1.1/v0.9
-Updated to newest kernel release (still considered experimental
v1.0/v0.8 (Initial Release)
Tweaks:
-GPS for better accuracy
-APN for allowing numerous sim cards without the need to add them manually
-Host file for blocking an ENORMOUS amount of known ad sites
-Build.prop for too many things to list, but includes fast boot & fast reboot, battery optimizations, faster UI, call quality, phone and camera tweaks, and many, MANY more...
-init.d added
-Numerous scripts for RAM & battery optimization, speed, and sysctl tweaks
-BusyBox added
-Keyboard emojis possible
-Headset sound boosted
-Camera mods and maximum bitrate increased for photos
-etc.
Mods:
-Disabled boot and shutdown animation for speed
-Added extended power menu under "Power off and restart"
-Flying messages
-Green glow border pulls
-Battery circle & percentage mod
-Changed default wallpaper and lockscreen
-Network speed on status bar
-Several apps deleted for space and speed
-Keyboard themes
-Custom kernel (use the ES Package...)
-etc.
v1.1/v0.9
Tweaks:
-init.d added
-BusyBox added
-etc.
Mods:
-Flying messages
-Keyboard themes
-etc.
All packages are flashable. There are several apps per package, but you are given the choice to install one, all, a specified amount, or none. Each package contains ONLY free or lite apps.
ES PACKAGE - The Essentials Package - Think of it as a REALLY GOOD starter kit.
BX PACKAGE - The Basix Package - A lot of apps that could come in handy (no social media).
PS PACKAGE - The Power Saver Package - Apps that can greatly increase your battery life... further.
NN PACKAGE - The Naughty but Nice Package - There are some security apps, and some apps that are for... "educational" purposes only.
LG PACKAGE - This has all the original LG apps in case you want something back that I deleted
- fstrim - If you can't wait for 4.3 of my ROM, and want fstrim support now, buy and download Tasker. Use this thread to allow fstrim support, then use something like LagFix to "trim".
- Custom Kernel - If you are using the odexed version and want the custom kernel, you can go to this thread, download the zip, and flash it.
- Network Speed - If you are using the odexed version and want the network speed on your status bar, you can install Xposed and then use Xblast Tools (both in the BX Package).
INSTALLATION
1) Backup vom aktuellen Rom machen.
2) Factory Reset durchführen.
3) Neues Rom (+Paket) flashen.
4) Reboot.
DOWNLOAD ROM
Deodexed v1.1
Odexed v0.9
OLDER ROM VERSION
DOWNLOAD PAKETE
ES PACKAGE
BX PACKAGE
PS PACKAGE
NN PACKAGE
LG PACKAGE
Original-Thread von Heatshiver auf XDA.
