[ROM+Kernel] [5.1.1] [UBER-4.9/5.1] UBERCM for G3 [D855]
  • 0 Antworten
kingoftf
kingoftf
Ehrenmitglied
55.382
Hier noch ein ROM aus dem XDA, Dev ist Fechinator, der schon einige Kernel entwickelt hat.
Sein eigener Kernel ist auch Bestandteil dieser ROM.
[ROM+Kernel] [5.1.1] [UBER-4.9/5.1] UBERCM f… | LG G3 | XDA Forums
Basierend auf CM 12.1 compiled mit UBER-49 Toolchain for ROM and UBER-5.1 Toolchain for Kernel.
My FechdaKernel is integrated in this ROM with all the features except Multirom Support.
It's made for the best performance on our device and it's really really fast and smooth. For battery, before you complain,
it's still acceptable but not as good as Stock CM. But you come easily over the day
Features
ROM:
- -ofast optimized
- compiled with latest UBER-4.9 toolchain
- added a lot of GCC flags
- Floop Nest optimized
Kernel:
IO Schedulers:
-CFQ
-DEADLINE
-FIFO
-FIOPS
-NOOP
-ROW (default)
-SIO
-TRIPNDROID
-VR
-ZEN
Governors:
-Interactive
-Conservative
-Ondemand
-Powersave
-Performance
-Wheatley
-SmartassV2
-Smartmax
-IntelliMM
-Pegasusq
-Slim
-Lionheart
-Nightmare
-Hyper
-ZZMoove
ZZMoove Profiles
TCP Congestion Algorithms:
-Cubic (default)
-Reno
    • Compiled with Toolchain UBER 5.1
    • -Ofast Optimized
    • Voltage Control Support
    • Intelliplug
    • Simple_ondemand GPU Governor Fixed
    • simple_gpu_algorithm GPU Governor
    • GPU Optimization Flags
    • F2FS Support
    • KSM Support
    • LCD Notifier Patch - Powersaving when used ZZMoove Govenor
    • Slightly CPU OC from 2,46Ghz to 2,53Ghz
    • Sweep2sleep
    • Sound Control
    • GPU: OC to 657MHz, Idle on 27MHz and add 100MHz Step
Installation:
ROM und Gapps downloaden und in den internen Speicher des G3 kopieren, Reboot in TWRP, Wipe Data/Factory Reset,
Flash ROM und Gapps, Reboot
Fertig.
Flashen wie immer unter Ausschluss jeglicher Gewährleistung durch den Dev oder sonst wen!
Download:
ROM:
cm-12.1-20150617-UNOFFICIAL-d855.zip | cm-12.1-20150617-UNOFFICIAL-d855.zip | by fechinator for G3
Gapps:
gapps-511-base-20150617-1-signed.zip | gapps-511-base-20150617-1-signed.zip | by Deltadroid for Galaxy Tab 2 7.0
Es sollen wöchentliche Upates erfolgen
NICHT ÜBER OTA UPDATEN, DANN GEHT MAN ZURÜCK AUF STOCK CM OHNE DEN ANGEPASSTEN KERNEL UND DIE OPTIMIERUNGEN
Credits:
@Cl3Kener for UBER-Toolchains and for build optimizations on Optipop
@CyanogenMod team for Rom
and all the credits which are given in the kernel thread : http://forum.xda-developers.com/lg-g...ernel-t3126745
Source:
CyanogenMod · GitHub
Fechinator/FechdaKernel · GitHub
No, it's not Uber CM from @RobbieL811 , i talked to him and it's okay to call it this way. (There was no better name on my mind)
Some informations:
You can boost the speed and performance even more with using "Lionheart" or "Pegasusq" Governor.
If you want it balanced use "Interactive" Governor.
If you like to save more battery use "IntelliMM" or "ZZMoove" Governor with a battery saving profile.
