[ROM][02/07/2011] SkyWater-Froyo-v1.2 [When Beauty meets the Beast]
  • 1 Antworten
HYUNDAI2010
MAKE SURE YOU READ THROUGH THE POST BEFORE INSTALLATION
About
This is my first proper full ROM. It is based on MoDaCo Fr19, sources from 0622. I got rid off some of the LG apps, and put on a nice blue/white theme. I will try and keep up to date with Modaco ROMs.
IMPORTANT INFO FOR V1.2
Update from v1.1
- flash as normal
Update from v1.0 or other ROMs
- full wipe first
- convert to EXT3 by flashing this from recovery - DOWNLOAD
- and then flash ROM
Key Features
- Based on FR19 and 0622
- new kernel
- Modded video recorder (thanks to somemadcaaant)
- LED notification
- removed debugging notification
- Silent screen capture
- new transparent lockscreen
- Custom Boot Animation
- themed HTC keyboard
- LG apps (Music, edited MMS, Memo, contacts, Alarm, Email, Fonts)
- Go Launcher EX
- and more...
Credits
- Paul - for the great job with MCR
- djmcnz - stock lockscreen, silent screencapture
- somemadcaaant - great job with increasing FR and bitrate on video
- erestor6 & LeoMar75 - borrowed some of their work on their themes
Download
ROM
Version 1.2
http://www.imperticus.com/android/Sk...Froyo-v1.2.zip
Multiupload.com - upload your files to multiple file hosting sites!
v1.1
http://www.imperticus.com/android/Sk...Froyo-v1.1.zip
v1.0
Options
LG Original Theme
LG Keyboard (thanks to rori)
Screenshot
Grad geflasht und positiv überrascht. der lockscreen und der hintergrund sieht bei mit aber anders aus als auf den screenshots
