X
Xain
Hi an alle, die von XDA Developers haben eine neue T-Mobile US Rom rausgebracht.
Hier laut XDA:
"Here is my Nandroid Backup of the newly leaked T-Mobile USA Froyo firmware, which I have rooted, deodexed and optimized. I hope y'all will find it to be of some use.
Download link: http://www.multiupload.com/IJVFK3RU0R
Note that it is NOT de-blurred.
For reference, these are the steps I performed:
1. Flash p3_jordan_umts_jordan-user-2.2.1-3.4.2-107_JDN-4-000000-release-keys-signed-T-Mobile-US.sbf with RSD Lite v4.9.
2. Turn off the device then reboot into recovery by pressing and holding VOL-DOWN + POWER. Access the Android System Recovery utility screen by pressing VOL-DOWN + VOL-UP simultaneouly. WIPE everything. NB: Use the POWER button to select.
3. Set up MotoBlur.
4. Root device with SuperOneClick, according to instructions in this thread: http://forum.xda-developers.com/showthread.php?t=913709. NB: Be sure to run SuperOneClick AS ADMINISTRATOR. Be PATIENT. After root success, REBOOT DEVICE.
6. Install Tenfar's Recovery.
7. Delete Family Room apps and other Bloatware:
Plug in device with USB Debugging ON and USB Connection set on NONE. Open a command prompt.
Open a command prompt and type (or copy and paste) the following commands:
Fire up ADB:
Code:
adb shell
Gain root access:
Code:
su
[After typing the "su" command for the first time, look at your device screen and grant permission for ADB superuser privileges.]
Mount the /system partition with write access:
Code:
mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
Switch to the /system/app dir:
Code:
cd /system/app
Remove the Family Room and Bloatware apps:
Code:
rm FamilyCalendarProvider.apkrm FamilyCalendarProvider.odexrm FamilyQuickContactWidget.apkrm FamilyQuickContactWidget.odexrm FamilyRoom.apkrm FamilyRoom.odexrm FamilyUpdates.apkrm FamilyUpdates.odexrm amazonmp3.apkrm Blockbuster.apkrm esmusica.apkrm GOTV_Altitude.apkrm hiphopofficial.apkrm Quickoffice.apkrm revolver.apkrm revolver.odexrm slackerradio.apkrm truecountry.apkrm WeatherWidget.apkrm WeatherWidget.odexrm Web2Go.apkrm Web2Go.odexrm YahooContacts.apkrm YahooContacts.odex
Reboot device:
Code:
reboot
8. Manually DEODEX device according to the instructions in this thread: http://forum.xda-developers.com/showthread.php?t=765270.
9. Overclocking time! (Props to Sorensiim for the instructions at http://forum.xda-developers.com/showthread.php?t=893291)
Install Milestone Overclock from the market and fire it up. Load the module and Press the menu button, go to settings and enter "1000000" as Custom rate and "52" as custom vsel. After pressing OK, pull the slider all the way to the right, so the selected frequency shows up as "1000MHz, 52vsel (Custom)". Click Apply and tick the box for "Autoload on boot"
10. Scaling (Another shout out to Sorensiim!)
Install SetCPU from the market and start it up. Set scaling to "Ondemand" and tick the box for "Autoload on boot" and exit the program. Now it's time to make the vsel correspond to the cpu frequency and save some power, as explained so brilliantly by Higgsy. Buy the man a beer! My setscaling.sh is here, Higgsy's excellent startup script is here. Download both to the root of your SD card. Then connect your phone to your pc and fire up ADB/MotoDev Studio. Once connected to your phone, here's what you need to do:
Code:
adb shellsumount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /systemcp /sdcard/setscaling.sh /system/xbin/setscaling.shcp /sdcard/install-recovery.sh /system/etc/install-recovery.shchmod 755 /system/etc/install-recovery.shchmod 755 /system/xbin/setscaling.shmount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /systemreboot
11. Create a new backup of the newly rooted, deodexed, overclocked/undervolted ROM with Tenfar's Recovery. NB: USB Debugging must be OFF or Tenfar's Recovery won't work."
Hier laut XDA:
3. Set up MotoBlur.
Fire up ADB:
Code:
adb shell
Gain root access:
Code:
su
Code:
Code:
cd /system/app
Code:
Reboot device:
Code:
reboot
Code:
