Wickeda
bei xda gibt´s ein neues ROM Entwickler übernehmen keine Haftung für Schäden an eurem Ace!
Originalthread bei xda-developers: [ROM] CyceronPL-v1.0 based on KPH 2.3.4 - xda-developers
Stand vom: 31.7.2011
Download:
http://forum.xda-developers.com/atta...8&d=1310632842
and
Multiupload.com - upload your files to multiple file hosting sites!
What's in ROM:
- Region set to Xeo
- Deodex KPH ROM
- Kernel 3.7 CF-ROOT
- Juwe's RAM script
- Animation CRT (please include all animations)
- PowerMenu
- Old Android Market
- New Sony Sketch font
- Gingerbread Launcher
- GO LUncher EX
- Smoother animations
- CM7 Bootanimation
- Left the bells added in FirstUA 1.1
- Supports DTA2SD - Enter Tweak Manager and select DT: Auto start and reboot. (DTA2SD to work the card must have a partition EXT4).
- CVM Manager
- Ext4 Manager
- Ability to change the font and add new fonts
- Ability to set your own MP3 as ringtones
- Google + (social networking applications)
- The percentage of battery theme
installation:
1st Copy the file and ClockWorkModAce.zip CyceronPLv1.0.zip memory card
2nd Install a plain KPH using Odin'a - (if you have it skip this step)
3rd Enter Recovery (Home + Power) and install ClockWorkModAce.zip - (if you are already ClockworkMod recovery you can skip this step)
4th Take a restart, and then do wipe data / factory reset the recovery
5th Install the recovery CyceronPLv1.0.zip
6th After installation, reset the phone (the first run will take quite a while)
7th Run selected tweaks in the Tweaks
8th Enjoy the new CustomRomem
