L30nh4rt
Dauer-User
- 223
Vor kurzem wurde im XDA Forum der AOSP Build in die Beta-Phase geschickt:
[ROM][Gingerbread] 2.3.7 | Clean Android | AOSP|Beta1 - xda-developers
Introduction:
I presente to you ANDROID OPEN SOURCE PROJECT (PUR google ROM)Made By Me and My friend EmoBoiix3
Features and working: (Almost everything)
-Touch
-Wi-Fi
-Bluthouth
-Data
-Audio
-GSM , mms send and receive
-Sensors
-Camera
-SD card
-USB connection
-Google Apps
-GPS
-Root,Superuser
-FMradio(using Bluethouth)
-Great 2D,Icreased I/O Using Kernel From Master Ketut
-T-Mobile engine Theme (you can use CM7 themes)
-CMscreenShot
What's not working:
-Can't set brightness Level(get FC when Press it)
-Can't set Sound Level(Get FC when press it)
-Anything Else you Tell Me!!
Credits:
-Master Ketut.Kumajaya For The grea CM7 Kernel
-Anyone How was developing or working on Fixing CM7 (we used Libs and Module and kernel From it and some Apps)
-Emoboiix3 and Me For working on this ROM
Download: http://db.tt/GT1TTeIv
PS:Since I'm at Home The Zip isn't a flashable Zip But a Clockworkmod backup extardct the zip and put the extracted folder SD card/ClockWorkMod/backup/ then Reboot to Recovey(ClockWorkMod 5 Is neccessary)and restore it as a nandroid backup
