[ROM][G901F][5.0.2][XXU1BOC4] *14.03.2015* NoNonsense ROM Beta v0.8.9 [TW]
blero
[ROM] [5.0.2] [G901F] [XXU1BOC4] [14 March.] [TW] ★ NoNonsense ROM Beta v0.8.9 ★
SM-G901F S5 5.02 TouchWhiz Lollipop ROM
This is my first ROM released as G901F is lacking Dev
It's for those of you that want NoNonsense!!
WARNING - THIS ROM IS ONLY INTENDED FOR G901F VARIANT OF SAMSUNG GALAXY S5- YOU HAVE BEEN WARNED!
Features
100% stock samsung look
Deodexed
ZipAligned
Debloated (Needs List Reviewing not final)
Knox Removed
Rooted
BusyBox installed
Init.d support added
Boot Sounds Disabled
No wipe - no user data lost by installing
Thing to be added
Custom kernel (waiting for source from Samsung)
I wanted something streamlined and easy to use without much customisation, built for myself to use as will be having to reset phone a lot when working on Lollipop custom kernel. But thought I would share if anyone else wanted to use. I have been using ROM for about 12 hours on my device with no issues.
You need to be on latest Lollipop Firmware 5.02, G901FXXU1BOC4 if you need it you can find out how to install here
http://forum.xda-developers.com/gala...5-0-2-t3053957
Then install CWM which can be found here
Flash my zip via CWM Recovery via normal method
The flashing of my ROM does not wipe any data from /data
Here are links to download of ROM
Link 1
https://www.androidfilehost.com/?fid=95916177934541399
Link 2
https://mega.co.nz/#!jlxHCQqb!DigiWjxgRQqYlwwhgMeEJZXg8BtUa6tnFFfVbXZ_GXg
Please I appreciate the feedback and any ideas for features I am thinking of going down road of having one pure stock bloat free rom NoNonsense and then another crammed with tweaks ie 5 way reboot, call recording, etc.
I will also be working on AOSP ROM as soon as kernel source available as I think that this is the most desired type of ROM for this device.
Thanks
JDizzle80
I would love to give this a try, sadly the links are both down.
Any chance?
Wass soll der der Beitrag? Das ROM ist nicht existend oder Downlloadbar!
Du siehst die Zeitangabe an den Posts?
  • Pulli67
bxalex
Shirkahn
katerkarlo69
hein-ballermann
katerkarlo69
burnmen
androiderer
Schnecky100
