[RECOVERY image] [Prerooted + Recovery] X10 GB 3.0.1.G.0.75
UKSheep
UKSheep
Dauergast
569
DooMLoRD schrieb:
This would not have been possible without the tools provided by aZuZu and the help provided by jerpelea!!!
THANK YOU GUYS!
[ Screenshots ]
[ Requirements ]
  1. any working ROM with recovery [best situation is to flash stock 2.1 se rom root it and install recovery]
  2. flashtool
  3. FTF bundle posted below
  4. Recovery image posted below
[ Features ]
  1. Stock SE 2.3.3 ROM
  2. prerooted (superuser files pre-installed, busybox pre-installed)
  3. FreeXperia recovery (slightly buggy but will be improved later)
[ How To (Recovery Image Way)]
*FOLLOW THE STEPS PRECISELY ELSE U WILL GET STUCK*
  1. download the ftf bundle & compressed recovery image from linnks below
  2. extract the contents of the recovery image to a folder on desktop
  3. u will get a folder with 4 files as shown below:
  4. connect device to PC and mount sdcard
  5. copy that extrated folder to /sdcard/xrecovery/backup/
  6. so final path to folder & files should look like:
    • /sdcard/xrecovery/backup/prerooted_X10i_3.0.1.G.0.75/cache.img
    • /sdcard/xrecovery/backup/prerooted_X10i_3.0.1.G.0.75/data.img
    • /sdcard/xrecovery/backup/prerooted_X10i_3.0.1.G.0.75/nandroid.md5
    • /sdcard/xrecovery/backup/prerooted_X10i_3.0.1.G.0.75/system.img
  7. once copying is finished unmount sdcard and disconnect cable
  8. reboot into recovery and restore this backup
  9. AFTER RESTORE IS DONE DO NOT REBOOT
  10. wipe cache, data partitions
  11. directly remove battery and wait for few minutes (since we dont have power off in recovery this is crude way to do it)
  12. now start flashtool and connect X10 in flash mode and flash the ftf bundle provided below
  13. after flashing is complete just restart device and enjoy prerooted X10 SE 2.3.3 GB!!!
[ How To (Alternate update.zip Way)] (thanks to kxhawkins)
Hi guys since i am out right now i couldnt test it but kxhawkins has posted direct flash-able update.zip HERE, instructions are there in his post... please test it out and report back...
[ Info ]
  • this has already been tested to work by me, erickwill & kxhawkins... but please test it and report back...
  • NO-KNOWN root exploit was used! all the info on how to do this is already there in the threads i had created earlier and of-course using some ingenuous thinking ;)... u can check my sig for the links to those threads...
  • i am going for a holiday for a 1-2 days... going to enjoy my new Canon EOS 550D/Rebel T2i DSLR }:)
    so wont be able to monitor the thread during that time... will work on custom kernels later... need to take a break from kernel dev for X10/Arc/Play...
[ Donations ]
if u feel that this work has helped u OR u think that the work i put into making this is worthy of donations, then click on the following link for buying me some coffee/beer/etc ;)
PAYPAL DONATION LINK
[ Downloads ]
  1. FTF bundle (contains only kernel & baseband from stock SE FW 2.3.3)
    http://doomlord.sylvester20007.com/x10/x10_gb/X10i_3.0.1.G.0.75_only_kernel_baseband.7z [Multiupload mirror]
  2. Recovery image
    http://doomlord.sylvester20007.com/x10/x10_gb/prerooted_X10i_3.0.1.G.0.75.7z [Multiupload mirror]
[ Warning ]
  • if u ppl (modders/rom makers) will be using this work atleast link back to thread & atleast acknowledge the work i did!!! (this mean u too TripNRaVeR)
  • the prerooted + recovery image might be slightly buggy (as i havent verified the permissions on all files yet) but till then u can enjoy prerooted SE 2.3.3 GB ROM
[ Known Issues ]
Included recovery (FreeXperia recovery) is slightly buggy and might give "unable to mount sdcard" problem if used multiple times in same recovery session.. it will be fixed later on...
Quelle: [RECOVERY image] [Prerooted + Recovery] X10 GB 3.0.1.G.0.75 - xda-developers
Reaktionen: anime und lkrys
Hallo, wie schaut das eigentlich wenn ich im moment Wb´s Gingerbread Rom drauf habe? Muss ich das FTP-Bundle dann trotzdem neu flashen? Ich würde es ja erstmal ohne versuchen...?
Mikemr
  • Handy61
Handy61
  • laugfred
Benji96
