[Kernel][ICS] ForzaferrarileoV3.1
  • 3 Antworten
bluedesire
bluedesire
Enthusiast
897
Hallo hat jemand Erfahrung mit dem Kernel wie verhält der sich?
This kernel , it's made for have the best performance and balanced battery consuption
, and since this is my first kernel and I'm still learning , any suggestions,hints,tips , are greatly accepted
REQUIRE UNLOCKED BOOTLOADER!!!!!
WORKS ONLY ON STOCK ROM , SO DOESN'T WORKS WITH AOSP BASED ROM(CM9/10,AOSP;AOKP); maybe works with miui , I don't know
I'm not responsible for damage to your device , use it at own risk!!!!
Features:
[V1] Based on .55 stock FW
[V1] Based on Arakmar ramdisk , with all the feature of Advanced stock kernel :CWM recovery , busybox, root , etc... [Very thanks to Arakmar forhis great work!!!]
[V1] BOOT Freq capped at 1512 MHz.
[V1] CPU Underclock/Overclock 30/1900 MHz
[V1] GPU 3D Overclock : 320 MHz (from the original 260 MHz)
[V1] GPU 2D Overclock : 228 MHz (from the original 200 MHz)
[V1] VDD SVS support ( for change voltages of cpu freq )
[V1] ZRam , ZCache and Frontswap
[V1] Snapdragon and other build optimization
[V1] VFP ( Virtual Float Point ) Neon and other optimization
[V1] Enabled Unaligned memory access
[V1] NTFS filesystem support
[V1] UTF-8 codepage support
[V1] Default TCP congestion algorithm shifted to "VEGAS"
[V1] [TEST] Increase max audio volume
[V2] GPU 2D OC to 266 mhz
[V2] GPU 2D scaling
[V2] CPU Smooth scaling (works only with pegasusq and ondemand)
[V2] Added CPU Topology
[V2] Optimized READAHEAD(sd cache) and Writeback Ratio
[V2] 3.0.57 linux upstream
[V3] MPDecision
[V3] RECOVERY INDIPENDENT WITH TWRP
[V3] Glibc
[V3] Small 2D GPU scaling fix
[V3] Optimized RWSEM algorithm
[V3] Other small tweaks
[V3] 3.0.71 linux upstream
[V3.1] Full 2D / 3D scaling fix and tweak : now you can set both using "kernel tuner" app
[V3.1]New logo. Thanks to dpiroto
[V3.1]New 1.7GHz OC version for who gets bootloops
More Governor:
[V1] Hotplug
[V1] Pegasusq
[V1] Interactive (Enabled)
[V3] Sakuractive
[V3] Adaptive
More scheduler:
[V1] VR
[V1] SIO
[V1] ZEN
[V3] ROW
LAST version
Download link here : Quote:
CWM package ForzaferrarileoV3.1 1.9Ghz fixed bootloops. after flash do a wipe cache and dalvik Link1
CWM package ForzaferrarileoV3.1 1.7GHz version (for who gets bootloops with normal version) Link1
Older version(not recommended)
CWM package ForzaferrarileoV3 Link1
CWM package ForzaferrarileoV2 Link1 (seems not working on some rom )
CWM package ForzaferrarileoV1Link1
Source here
CREDITS :
Sony for source
Arakmar for his Ramdisk
Amin and Mericon for the help
Dpiroto for the last bootlogo
QUELLE: [Kernel][ICS] ForzaferrarileoV3.1 | 1.9/1.7GHz version | TWRP | Recovery Indipendent - xda-developers
habe den Kernel geflasht, leider bootloop das scheint ein Fehler im Kernel zu sein echt schade
Auf welcher Android Version warst du als du den kernel geflashet hast?
Gesendet von meinem Xperia S
