Custom-ROM [ROM][OFFICIAL] Bliss ROMS v7.3 [axon7][N][25.04.2017]
  • 24 Antworten
Sunny
Sunny
Gesperrt
34.420
Team Bliss ist Stolz euch Bliss 7.3 vor zu stellen,
Ganz frisch von XDA heute für euch Liebes Forum und Freunde des Axon7 [emoji3]
Hier geht es zur BlissRoms Website
Hier geht es zum Original Thread auf XDA
Substratum Theme Engine
Status Bar
  • Status Bar Tuner w/ additions in System UI Tuner
  • Clock customizations located in Blissify app
  • Status Bar gestures - DT2S, Notification Count, etc located in Blissify app
  • Network Traffic Monitor located in Blissify app
Navigation & Button Options
  • Nav Bar Tuner located in System UI Tuner
Recents Options
Notification Settings
  • Battery Light options
  • Notification Light options
Quick Settings Options
  • Quick Pulldown
  • Vibrate On Touch
  • WiFi Easy Toggle
  • Advanced Data Tile
  • Extra QS Tiles for Input Method, Advanced Reboot, Night Mode, etc. (More being added as we go)
Display Options
  • Automatic Brightness
  • Night Light
  • Sleep options
  • Expanded Desktop
  • Ambient Display
  • Dashboard Options - Suggestions
  • Wakeup Options - Volume Rocker Wake
Animations
Sound Options
Display & Light Options
Notifications
More Stuff Included
Houdini Application Compatibility Library (Bliss-x86 Builds Only)
Taskbar - Thanks to @farmerbb (https://github.com/farmerbb/Taskbar)(Bliss-x86 Builds Only)
  • SuperSU - Huge thanks to @Chainfire
  • Dev Options enabled by default
  • System UI Tuner enabled by default (with extras added in)
  • Settings tiles for Substratum & Superuser/SuperSU
  • OMS Enabled - Ready for Substratum!! (included in our Bliss-x86 builds)
--Many other settings throughout the rom. Take some time to familiarize yourself with all the blissful options!
Bliss Source
BlissRoms · GitHub
BlissRoms Devices Source
BlissRoms-Devices · GitHub
BlissRoms Kernel Source
BlissRoms-Kernels · GitHub
BlissRoms Vendor Source
BlissRoms-Vendor · GitHub
Bliss-x86 Source
BlissRoms-x86 · GitHub
Bliss-x86 kommt mit OpenGapps eingebaut (Auf dem Pc können wir keine Recovery nutzen)Für alle Handys oder Tablets empfehlen wir:
Open Gapps Project
Bliss - Official
Bliss - Nightlies
Bliss-x86 - Stable/EDU/Bleeding Edge ( Pc Version )
  • Versichert euch das ihr Root habt
  • Eine aktuelle TWRP sollte installiert sein
  • Ladet euch die neueste Bliss Rom und GApps
  • Startet in die Recovery
  • Macht einen Backup eurer jetzigen Rom
  • Macht einen Factory Reset plus Whipe Cache, Dalvik, System und Data!!
  • Flash Bliss Rom
  • Flash Google Apps package (für 7.1!) *Root ist nicht eingebaut und muss extra geflasht werden!!*
Der erste Boot kann bis zu 10 min dauern.....lasst euch und eurem Handy Zeit
If you have a major bug to report that has not been reported already, please take the following steps to report it to us. It will save you and our team quite some time.
-Download the Catlog app from the Play Store.
There is also a donate version which you can purchase to show appreciation.
-After downloading the Catlog app, go to the app settings, and change the log level to Debug.
-Clear all previous logs and take the exact steps to produce the error you are receiving.
-As soon as you receive the error (probably a force close), go straight into Catlog and stop the log recording.
-Copy and paste the entire log either to Hastebin or Pastebin
-Save the log, and copy and paste the link into the forum with a brief description of the error.
-You can also open trouble tickets on our website for bugs.
@jackeagle, @pjgraber03, @electrikjesus, @nprev420, @rwaterspf1, @BitOBSessiOn, @Deliberate, @xboxfanj, @Vortex1969, @Dark_Eyes_, @blueyes, @asianflavor, @nicholaschum, @TheStrix , @apophis9283 , @beany> , @fizbanrapper , @iRockaNexus , @Nyks45 , @techfreak24 , @aapav01 , @ideaman924 , @acuicultor
Thanks to @skyliner33v for making our wallpaper & optional boot animations, @electrikjesus for making the current boot animation as well as others,
@pjgraber03 & @electrikjesus for developing and maintaining our website,
@death2all110 for developing the Bliss Wallpapers app, and @nicholaschum, @genesixxbf3 and @tobitege for the OTA xml generator.
Thanks to @Kryten2k35 for the original source of the OTA app.
XDA:DevDB Information
[ROM][OFFICIAL] Bliss ROMS v7.3 [axon7][N][04.20.17][download], ROM for the ZTE Axon 7
Contributors
aclegg2011
ROM OS Version: 7.x Nougat
ROM Kernel: Linux 3.10.x
Version Information
Status: Stable
Gekocht: 21.04.2017
Letztes Update: 25.04.2017 (OTA)
Wie immer gilt:
Bitte macht einen kompletten Backup eurer Daten. Esf mit eingeschlossen ( wenn möglich )
Eine saubere Installation wird empfohlen (Whipe Dalvik, Cache, System und Data)
Verlasst euch nicht darauf das ein Backup eurer Daten wiederhergestellt werden kann!
Weder ich noch Android Hilfe.de übernehmen die Verantwortung in irgendeiner Form, solltet ihr euer Handy Bricken/Abschießen und oder Daten verlieren oä.
Ich würde mich wie immer sehr über eure Kommentare freuen,
viel Spaß beim flashen und ausprobieren
sollte man zuerst Universal_Bootloader und Modem flashen?
Wenn du es nicht schon getan hast...... dann schon
ja kannst erst auch die Rom flashen dazu die gapps und dann das modem und bootloader hinterher und evt supersu :)
Der erste Eindruck ist sehr gut.
Was aufgefallen ist, nach der Installation und Einrichtung der Rom war kein Root vorhanden.
Ein nachträgliches flashen von SuperSU war nötig. (könnt ihr das bestätigen?)
Lautsprecher funktionieren sehr gut wieder.
Der Netz Empfang ist auch etwas besser als bei NucleaRom zb.
Mal gespannt wie sich der Akku über die nächsten Tage macht.
Über eure Erfahrungen und Meinungen würde ich mich sehr freuen
@Sunny76
hey also mit root kenne ich so (Einstellung - über das Telefon - auf build nummer - 7x drauf klicken -der Entwickler modus wird freigeschaltet - und dort weiter unten ist root zu finden.
werde sie nachert mal flashen und testen :)
Ja das kannte ich auch so. Entwickleroptionen brachten aber keine Option mit Root. Erst nach dem flashen der SuperSU zip
@Sunny76
okay habe grad gelesen auf xda das man supersu oder (magisk) flashen muss um root zu bekommen so steht es in der Anleitung habe nix gelesen mit das root schon integriert ist ?
Reaktionen: Sunny
Ja, das ist neu.
Gestern stand es da nicht[emoji23]
War wohl zu schnell. 10 min nachdem der Thread auf XDA kam.
Ich denke mal die haben nachträglich noch ihr copy n paste verbessert [emoji23]
Reaktionen: kevte89
ich werde umgehend mal probieren. hat jemand schon getestet? besser als Los, RR, etc.?
@Sunny76
Haha lach ^^ ja wer weiß XD
Naja habse jetzt auch drauf und läuft eig mal sehen wie sich Akku usw macht, ansonsten eig top wie RR auch :)
Reaktionen: Sunny
muss man wirklich vor Flashen auf 100% aufladen, wegen Battery Calibration?
@denf
nein das ist natürlich Quatsch:)
50% oder40% reichen vollkommen aus,es ist nur das weil das flashen und das starten sehr viel Akku zieht da können paar % verbraucht werden.
Und daher das der reboot auch ca 10 min braucht und der Prozessor heiß wird und somit natürlich mehr Kapazität gebraucht wird auch in der zeit mehr Akku gebraucht.
lg kevte89
Reaktionen: denf und Sunny
ich hab gerade RR 5.8.3 inkl. magisk geflasht. einfach perfekt:biggrin:. die beste Rom für mich.
@denf
Dann solltest du das auch da Posten, hier geht es um Die Bliss!!
@kevte89 wird sich über deinen Review dort sicher freuen
Reaktionen: MadCannibal und Highwaydesigner
@DeJe offizielle RR website. bei xda auch.
Reaktionen: DeJe
Die links hier sind reichlich schief. ;)
Habs jetzt gefunden. :D
Hallo!
Ich würde gerne dis Bliss Rom testen habe allerdings ein Problem:
Bin gerade auf RR5.8.3 und nutze den 6x6 Pattern in allen Instanzen... Wenn ich Bliss installiere schlägt er mir beim Booten nur den 3x3 Pater vor und da kann ich nicht entsperren!
Kann mir einer helfen wie ich dieses Problem umgehe?
