MoDaCo r12 Custom Froyo (2.2) Rom ist erschienen!
Tasse
Features
  • Packaged for ClockworkMod (including 2.5.1.3)
  • Rebuilt using the MoDaCo MCR optimisation scripts
  • MCK (MoDaCo Custom Kernel) with Tun and CIFS modules, EXT4 support and more
  • Full up to date Google experience+ additional apps
  • Many updated parts
  • Patched libraries to allow Google account setup via WiFi (YES... a fix for the 'invalid MAC address' problem)
  • Removal of Chinese software bits
  • Reverted icons to stock style where appropriate
  • Tweaked to show full market
  • Set to English by default
  • Updated RIL and removed 'SecuritySMS'
  • MoDaCo bootscreen, no bootsound
  • UK English for Voice Dialler
  • Renamed 'FMRadio' to 'FM Radio'
  • Replaced ZTE clock apps with Google 'Desk Clock'
  • Updated lockscreen and homescreen background
  • Fixed 'emergence' typo on lockscreen
  • Insecure boot image
  • su / Superuser.apk root
  • Support for running scripts from /etc/init.d at startup
  • Terminfo support (for nano etc)
  • /system/sd mountpoint for A2SD
  • Spare parts included
  • Enabled hardware acceleration + stagefright tweaking
  • Changed browser homepage to Google
  • Streaming video sound fix (thanks flibblesan)
  • All languages enabled
  • Added stock Android keyboard with word prediction
  • Added HTC_IME (modified version for BLade)
  • Network Location / Checkin Provider signature fixes
  • Camera app with stock merges
  • Exchange Email fix
  • Updated APN list
  • Removed 'no signal' notification from lockscreen
  • Full online kitchen with additional options from the Chinese ROM
  • Stock Launcher updated to launcher 'Dialer' instead of 'Contacts'
  • Set default timezone to UK time
  • Restored 'Videos' link
  • Removed duplicate 'G' / '3G' icons in status bar
  • Fixed Calendar sync to online calendars + removed 'Orange Bar'
  • Added A2SD+ (also moves dalvik-cache to SD)
  • Improved 'call reject SMS' wording
  • MCR Reboot utility
  • A bunch of other stuff that i've forgotten
  • framework-res and core libraries are signed with the 'shared' certificate from the SDK, aiding those who wish to edit the framework-res to theme (or to alter the lockscreen). Simply extract, edit, resign with the shared certificate and push the file. Tidy.
[OLED+TFT] 09/Feb r12: MoDaCo Custom Froyo ROM download + Online Kitchen - Android @ MoDaCo
r12
  • Reoptimised - smaller, faster!
  • Updated all outdated components
  • Contacts should be fixed once and for all - if you uncheck Google contacts to use Smartdialer, Facebook Sync / Contact merge won't work!
  • r12 goes prebake
Reaktionen: natenjo
Ansich ein feines Rom, schnell und alles läuft super bei mir ... AUSSER: der Exchange Kalender synchronisiert nicht bzw ich sehe ihn nicht...
bin schon am überlegen ob ich nicht einfach wieder auf r11 zurückgehen soll..
@drcyber: Bevor Du zu R11 zurük gehst, kannst Du mal sehen, wieviel Platz das ROM auf der System-Partition benötigt? Paul sagt zwar es wäre schlanker als R11, aber wie schlank? Kann man es in eine 128MB Partition installieren?
Wie schön dass es jetzt ein Pre-Bake gibt. Damit sollten die sicher nicht ganz legalen Hinweise auf kostenlose R11 Downloads hier endlich aufhören...
Reaktionen: natenjo
Hi Salsa,
wo genau seh ich wieviel platz das Rom braucht? wobei meins ist nichtmehr ganz original, hab einige apps rausgeschmissen und andere hinzugefügt..
Ähm, erhlich gesagt bin ich da gerade auch ratlos... ich dachte das ginge mit Super Manager (kostenlose Alternative zum root manager), aber der zeigt nur den gesamten Platz an, nicht die einzelnen Partitionen. Auch Titanium hilft nicht.
Mit fällt jetzt nur noch ein, in das Upadte ZIP zu schauen, wie groß dort das system Verzeichnis (entpackt) ist...
Sorry, das hat ich mir auch einfacher vorgestellt...
ähm,
bash öffnen "df -h" zeigt die partitionsbelegung an?!
funktioniert beim r12 die Eingabe des PUK Codes, bei der r11 erschien bei mir jeweils nur eine Meldung, dass man sich mit dem Kundendienst des Netzbetreibers in Verbindung setzen soll?
Ich werde mir das Rom gleich aufspielen und dann werde ich das mal ausgiebig testen.
also, nach den ersten Stunden scheint das Rom annähernd perfekt zu funktionieren.
bin bisher sehr zu frieden und der Akku verliert kaum Saft nach der ersten Nacht.
mal schauen, obs so gut bleibt
Wie sieht es denn mit dem Batterieverbrauch beim Surfen im Internet aus?
EDIT: Funktioniert bei der Prebaked-Version eigentlich A2SD?
MfG d.ti
Bekommt man das sch*** McAffee wieder runter?
Reaktionen: MatterInlets
Klar:
Voraussetzung ist, dass adb installiert ist. Das ist ohnehin gegeben, wenn man sich an das How-To aus diesem Forum hält. Ich gehe im Folgenden davon aus, dass adb in c:\adb liegt.
- Connect your phone to the PC
- Clear WaveScure's cache on the phone
- Open a command prompt
- go to run go to C:\adb and then run these 2 commands
1. adb remount
2. adb shell rm /system/app/*wsandroid*
This should remove WaveSecure from your phone.
Im HowTo hab ich geschrieben, dass genau das nicht geklappt hat. :(
Lief aber eh irgendwie langsam.
Jetzt hab ich nen anderes ROM. :)
Dann hast du irgendwas falsch gemacht, bei mir liefs genau so.
Eigentlich nicht, aber das ist nicht der richtige Thread dafür! :)
Mir ist aufgefallen, dass bei mir der Akkuverbrauch sehr groß ist. Wie könnte man es Fixen?
Akku hält bei mir sehr lange, locker 2 Tage, sonst wars nach einem Tag immer leer.
Was bei mir nicht einwandfrei funktioniert ist,
wenn man unter TaskManager alle beenden möchte, dann öffnet das Gerät alle aktivenn Tasks.
Wollte auf die weise ne eingefrorene App beenden, dann hat ich das Problem.
Aber half dann aber die schöne Rebootfunktion.
Sonst funktioniert das Rom bisher super
Also bis jetzt nachdem ich akku kalibriert habe ist alles wirklich top. Gibt nichts zu meckern. Ausser beim TouchPal nur die englishe version bei ist und ein upgrade auf die deutsche nicht wirklich geht.
Wieso funktioniert das "Upgrade" auf die deutsche Version von TouchPal nicht?
arcsi
Nasemann
_heisenberg
_heisenberg
