sundilsan
Enthusiast
- 4.779
ich habe diese anleitung gefunden + eine prerooted 5.1.1 stock rom für das 612er. kann ich das so bei meinem nagelneuen z3 tablet (32gb) mit derzeit 5.0.2 android anwenden? habe bisher kein root und bootloader ist unverändert geschlossen.
1. how to install the newest Android 5.1.1 for Sony XPERIA Z3 Tablet Compact Wi-Fi SGP612
a) first of all, check your firmware version (if you already have the newest one, you do not need this tutorial)
b) download and install latest Flashtool from this article
c) download also latest Android 5.1.1 (mirrors Google Drive or Mega) for Sony XPERIA Z3 Tablet Compact
d) paste the ftf file downloaded in step c) to folder „Firmware“ included in the XPERIA Flashtool
e) open the XPERIA Flashtool, click on flash and choose downloaded firmware, than click ok. Important - if you do not want to delete any data of your tablet, just uncheck flashing userdata.sin file. All data will remain in your phone, but sometimes it can cause additional troubles. So it is better (and I recommend that) to do the backup of your personal data, than proceed with clean instalation and then restore your personal data.
f) turn off your tablet and when Flashtool shows pop up window, connect phone to PC with holding volume down button
g) after few minutes all is done and your tablet gets the new firmware
geht das so einfach oder habe ich was übersehen?
