wemsinho
Enthusiast
- 775
Einige ehemalige Samsung Galaxy S I9000 ( Project Voodoo, Galaxy S improvements | Open Source project homepage )und Nexus S Besitzer kennen vielleicht das sehr umfangreiche und großartige VOODOO Sound Projekt von Supercurio. Einige vermissen diesen Mod bei dem Galaxy Nexus.
Es gibt Infos hierzu die euch nicht vorenthalten wollte
Supercurio hat in einem Post auf XDA die Entwicklung für´s GNx bestätigt:
xda-developers - View Single Post - Anything related to Sound: features or fix requests. v10: Bass Boost
14.Februar 2012
um dann ein paar Tage später ein klein wenig zurück zu rudern da aufgrund der anderen Hardware gewisse Teile nicht umgesetzt werden können
Voodoo mods for Galaxy Nexus - xda-developers
19.02.2012
Einige Sachen werden jedoch bald umgesetzt
14.Februar 2012
Yes Galaxy Nexus will receive Voodoo Sound improvements!
I started the research phase but didn't actually developed it yet.
Features planned:
- Analog headphone amp
- Mono switch
- DAC high performance mode (instead of default: low power)
- Speaker tuning: a bit more bass.
As usual: no ETA so please don't count too much on it as long as it's not actually released![]()
19.02.2012
Won't do:
Voodoo Sound:
Yea, I know, I said a few weeks ago I might add Galaxy Nexus in Voodoo sound but eventually that won't be the case for several reasons.
- Galaxy Nexus audio quality potential is good but not quite as good as what I target.
- Galaxy Nexus audio codec, TI TWL6040 has no DSP, which means:
Parametric EQ
Stereo enhancements
Advanced recording presets using Dynamic Range Compression
Using hardware: those cannot be done.
Its the signature and exclusive features of Voodoo Sound and what matters to me.
I know devices with WM8994 tend to become old compared to the latest generation but I don't care.
Sound quality stay just as excellent and class-leading, that's what's important no matter how many new devices are released each week.
Will do:
Voodoo LOUDER:
That's why I created this different app, in order to host useful audio mods/hacks even if they don't reach the quality and features I require for Voodoo Sound.
Things I'll implement here:
- Analog headphone amplifier control, with perfect OS integration and automatic optimal setup for the best audio quality results.
If there are a few dB left to squeeze at maximum output level, the biggest interest here is the opposite: with optimizations for sensitive headphones & in-ear.
I'll implement a few more things but you'll see it by yourself.
Where there will be no compromise, its about usability, seamless experience, automatic optimal settings and most importantly no custom kernel requirements (only root)
This is why it require more work (and more time) than random hacks but eventually its of course worth it as I'm sure it will become one of the app you'll use daily.
Wi-fi screen-off fix:
Wi-fi is terrible with several routers (loosing every packet as soon as the screen turns off) and that has to be fixed.
I started working on it as well but as usual, I target a patching & flashing free solution.
