GalaxyKeks
Dauergast
- 370
Seit heute gibt es offiziell die unoffiziellen nighly build für unser geliebtes Touchpad.
G+ - Erik Hardesty schrieb:Erik Hardesty - 5:24 AM - Public
I recommend using these unofficial CM9 nightly builds for the Touchpad now.
https://twitter.com/#!/cm_tenderloin
Watch here for a changelog: Gerrit Code Review
I probably won't be releasing alphas unless there is something very particular I want folks to test.
Be sure to thank Eye Baller and Teamwin for making these.
CM Tenderloin (@CM_Tenderloin) on Twitter
Sign up for Twitter to follow CM Tenderloin (@CM_Tenderloin). Nightly builds of Cyanogen(mod) 7 for the HP Touchpad/Tenderloin.
Spreadsheet zur Fehlersammlung von PJF16. Mit machen ausdrücklich erwünscht
https://docs.google.com/spreadsheet/...WlrZnl3di1nM3c
Installation:
Wie gehabt, über CWM oder ACMEInstaller.
Falls ihr nicht von CyanogenMod kommt, wird im Falle von der CWM Methode ein Wipe vor dem flashen empfolen.
Der Vollständigkeit halber:
Aktuellste GApps sind hier zu finden.
Danke dafür an RalfXtra
CAN I UPDATE *DIRECTLY* FROM CYANOGENMOD 7?
Yes. And you can try it even without a wipe of /data. The key is to use ACMEInstaller2 (see link below) rather than the ClockWorkMod Recovery to do the installation. If you use the ClockWorkMod Recovery, you’ll run into troubles, and though CyanogenMod 9 will install, you’ll need to reset(format) your data.
Our testing has shown that ACMEInstaller2 will resolve the issues. Your results may vary, but it may be worth using it to upgrade. Especially since newer versions of Titanium backup will crash on start up.
The process for using ACMEInstaller2 is exactly the same as when you first installed CyanogenMod 7.
I’VE NOT INSTALLED ANY VERSION OF CYANOGENMOD BEFORE. HOW DOES THIS WORK?
Please read all previous instructions/documentations for CyanogenMod 7. Start with the instructions for Alpha 1, then 2, 3, and 3.5. This should bring you up to speed with how to install and what to expect.
ACMEInstaller2 is the latest version of the installer and will do it all for you. You will need the files at the end of this document:
ACMEInstaller2 and update-cm-9.0.0-RC0-alpha0-Touchpad-fullofbugs.zip and
bootie (?)
Nightlys (oben immer das aktuelle):
Aktuell: Nighlies nun auf CyanogenMod.com
- update-cm-9-20120604-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120603-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120602-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120601-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120531-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120530-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120529-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120522-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120520-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120517-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120515-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120513-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120509-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120507-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120430-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120428-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120422-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120418-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120417-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120408-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120404-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120329-NIGHTLY-tenderloin-signed.zip
- update-cm-9-20120327-NIGHTLY-tenderloin-signed.zip
- update-cm-9.0.0-tenderloin-20120322-0800-signed.zip
- update-cm-9.0.0-tenderloin-20120321-0800-signed.zip
- update-cm-9.0.0-tenderloin-20120320-0800-signed.zip
- update-cm-9.0.0-tenderloin-20120319-0800-signed.zip
- update-cm-9.0.0-tenderloin-20120318-0800-signed.zip
- update-cm-9.0.0-tenderloin-20120317-0800-signed.zip
- update-cm-9.0.0-tenderloin-20120316-0800-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120305-0600-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120304-0600-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120303-0600-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120302-1426-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120301-060001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120229-060001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120228-044030-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120227-070001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120224-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120223-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120222-040155-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120221-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120220-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120219-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120218-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120217-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120216-040001-signed.zip
- update-cm-9.0.0-tenderloin-KANG-20120215-040001-signed.zip
Falls hier mal nicht aktuellQuelle schrieb:
Was wurde gefixt? (Nightlys):
- Ab dem 02.03.2012 Touchpad spezifisch -
>Changelog<
Changelog (Allgemein CM9: hier) TP spezifisch hier zu finden. Fixes vom Vortag gehen ins aktuelle Build.
Beispiel: Fixes vom 15.02.2012 findet ihr im Build vom 16.02.2012
- Workspace: Fix wallpaper scrolling without hwui (MERGED)
- DropTarget: Manage landscape strings programmatically (MERGED)
- Workspace: Custom Vertical/Horizontal Padding (MERGED)
- DeleteDropTarget: Haptic Feedback on Long-Press (MERGED)
- DeleteDropTarget: "Cancel" when dragging from AllApps (MERGED)
- CellLayout: Better Scaling (MERGED)
- Preferences: Show/hide homescreen icon labels (MERGED)
- Safely restart services to avoid race conditions. (MERGED)
- 1.1.7: no more ifdef ALLOW_BOOT_NORMAL, test stock.sh presence (MERGED)
- Add 2nd-system profile for dual boot (MERGED)
- Use frameworks/compile/libbcc from CM (MERGED)
- su: Remove usage of system properties (MERGED)
- Fix Mms app crash when vibrate preference has not been set. (MERGED)
- Mms: Added Dutch translations (MERGED)
- cm: Update Vibrant maintainer (MERGED)
- Lockscreen : Fix vol wake for lockscreen security type none (MERGED)
- Settings: Volume rocker wake - Fix string description (MERGED)
- Bulgarian T9 search and dialer buttons (MERGED)
- Remove bt_enable log spam (MERGED)
- Update Turkish translations (MERGED)
- fix sms receiving for some Samsung CDMA phones (MERGED)
- elGR - Added missing strings (MERGED)
- Settings: tr: CM9: Added Turkish Translations (MERGED)
- Added Turkish Translations (MERGED)
- french: profils and root mode (MERGED)
- Update Russian Translation-Vol long press skip tracks (MERGED)
- Support for Virgin Mobile MMS. (MERGED)
- Japanese: update translation (MERGED)
- Settings: Added cpu info and memory info to About Phone Settings (MERGED)
- Update korean translation (MERGED)
- PT-BR strings for lockscreen in profile settings (MERGED)
- Add missing includes for threads.h (MERGED)
- Change PT-BR profile title in global action menu (MERGED)
- zlib: Update to version on adler32/slhash repo as of Mar 07, 2012 (MERGED)
- NatController: Raise the max length of an interface name (MERGED)
- Fix custom LED values string (MERGED)
- audio: set mRecordState in AudioInputStreamMSM72xx::set (MERGED)
- audio/msm7x30: set mRecordState in AudioInputStreamMSM72xx::set (MERGED)
- audio/msm7x30: perform null checks when calling libhtc_acoustic functions (MERGED)
- Mms: remove sms split preference and replace with xml config option (MERGED)
- Enable nfs mount in both dynamic and static busybox. (MERGED)
- Wake up with volume buttons (Settings part) (MERGED)
- Telephony: Make partial QCOM USIM support more widely available (MERGED)
- Telephony: Make the compat-flag verification method available everywhere (MERGED)
- superuser: Prompt user to enable root access (MERGED)
- Add preference for enabling root access (3/3) (MERGED)
- adbd: Disable "adb root" by system property (2/3) (MERGED)
- su: Root access is now controlled by a system setting (1/3) (MERGED)
- Revert "SpeechRecorder is missing from -userdebug" (MERGED)
- bootanim: Don't cache textures if they're expected to use a lot of VRAM (MERGED)
- Revert color change from Change-Id: I5da9d4f075b8c273f6e84c75c2566c658bfcd897 as (MERGED)
- update sample scripts (MERGED)
- 1.1.5: allow to disable overclock menu
- 1.1.4: support for unlocked devices
- VoiceDialer: Updated Dutch translations
- Fix inheritance of PRODUCT_PROPERTY_OVERRIDES for CM audio files
- added audio files contributed by "Dennis Cleiren"
- Bluetooth: Updated Dutch translations
- exynos4: added getphys stub for samsung omx plugins
- frameworks (ICS): Updated Dutch translations
- Japanese : initial translation for ics
- Fix photo editor glitches on most fx on Galaxy S II
- tether down: mTetherInterfaceName vs mInterfaceName mismatch
- exynos4: getphys implementation on buffermanager for samsung omx
- Various fixes + French translation
- Added Galaxy S II values
- Add Samsung camera settings
- DeleteDropTarget: Long-Hold To Uninstall
- 201 : Fix auto mounts for removable storage
- 101 : Fix auto mounts for removable storage
- [Exynos4] Added Samsung OMX specific macros
- vendorsetup: add galaxys2 lunch combo
- Toolbox implementation of chown has a bad print
- Cleanup/fix translations
- Remove CrespoParts from app drawer
- [Exynos4] added support for samsung codec
- Update Korean translation
- Interface Settings: signal status style (1/2)
- Fix STARTTLS handshake error in Email's SmtpSender class
- Modify UI Settings for EAP-pwd to display only necessary fields
- Restore BassBoost preferences on boot
- Interface Settings: signal status style (2/2)
- Finnish: translated new strings
- Ensure backup of voice search
- Custom LED notification (1/2 framework)
- Add Facebook contact sync support (2/2)
- Add Facebook contact sync support (1/2)
- headset fix for hdmi headphone jack Signed-off-by: Matt Filetto <matt.filetto@gm
- ShutdownThread: Set property to indicate radio shutdown
- Fix too long on/off text for setting toggle
- handle_compcache: update props to match MemoryManagement in settings
- DSPManager: Updated Dutch translations
- Add national data roaming and make it optional (2/2)
- Add national data roaming and make it optional (1/2)
- Do not delete all iptables rules
- Settings: Cleanup and move top level CM classes to .cyanogenmod
- hardware_legacy: Add PolicyClient APIs for FM feature
- hardware_legacy: Add support for audio session
- hardware_legacy: Add enums to support for FM and ANC features
- hardware/libhardware_legacy: Add interface function for LPA and FM
- audio_legacy: ignore screen_state=off/on parameter
- hardware/libhardware: Add audio policy functions for FM feature
- hardware/libhardware: Add APIs to support LPA session
- NotificationMgr: Force led notification even if screen off
- Settings: Power Widget - fix title bug in Widget Buttons and buttons order
- Display original SMS timestamp instead of reception date
- Cleanup unused translations
- CM issue 1753: Show full timestamps
- Settings : CMStats cleanup / Enabled by default
- Clean up GPS source strings
- Japanese: initial translation
- Configurable 0, 90, 180 and 270 degree rotation (framework part)
- Polish translation
- LatinIME: Add official Czech, Russian and Dutch dictionaries
- Settings: PT-BR translations
- french: wakeup volume buttons (moved)
- Update Simplified Chinese translations for Camera
- Update Simplified Chinese translations for Settings
- Add basic device settings app
- Add support for Caller Name Display
- Move digitizer power management into ts_srv
- Add hover debounce to touchscreen driver
- fix ARMv7 optimized strlen() usage condition
- semc: moved usb DevID / device
- Binary for changing touchscreen modes
- Close ctp_uart on screen off
- Prop and fingerprint updates. Update BUILD_ID to IML74K - fixes market compatibi
- Update BUILD_ID to IML74K
- audio/8660: htc and aic3254 support
- audio/msm8660: Fix closing Rx Device While VOIP in progress
- audio/msm8660: Fix for Memory corruption during VOIP call
- audio: msm7x30: fix ifdef derp
- Add SoundRecorder.apk to -userdebug
- Disable Pinyin and Openwnn IME's by default. These two IME's are of poor quality
- initial sensor config
- initial sensor config and libsensor
- initial sensor push without akm897x sensor
- semc: sync with local changes
- Hide statusbar/notification drawer on tablets
- Settings : Remove whitespace / duplicate ids
- Changes PhoneInterfaceManager to allow toggling of LTE from outside of the Phone
- Increase notification LED blink intervals to consume less power
- Allow unlinking of notification sound and ringtone volume. Thanks to http://foru
- Keep track of tetherable USB interfaces in both up and down link states
- Add CM_SNAPSHOT ro.cm.version label option for SNAPSHOT builds
- Add more CDMA SamsungRIL fixes
- Fix too long on/off text for Slovak
- CM: Settings: various spelling corrections
- french: remaining french translations (untranslated descriptions)
- NotificationManagerService: Fix notification led bug
- move the User Agent selection out of debug
- Remove Disable Bootanimation Preference
- tools: add module tags to makefile
- russian: t9 and Dialpads ldpi, mdpi and xdpi
- Allow Notifications and Ringtone volumes to be unlinked. Thanks to http://forum.
- Adds LTE toggle checkbox to PowerWidget Settings. Only shows for CDMA devices.
- GEStarRIL: fix DST handling exception (ported from GB)
- webkit: Change detection of which devices can use V8 and whether non vfp devices
- Fix running on armv6-vfp devices
Aktuelle Display Treiber (Ab Build 20-02-2012 inkludiert):
Aktuelle Fixes des Treibers:
Gerrit Code Review
Aktuell:
RootzWiki schrieb:Tracking IDs v15 for CM9 2012-02-28:
Bugfixes for hover debounce. The v14 version works fine, but the code wasn't working the way that I intended. This version provides the correct behavior.
Tracking IDs v14 for CM9 2012-02-27:
Changed hover debounce - it now doesn't start the hover debounce unless you hover for 30 cycles (about 0.3 seconds) which should smooth out slow scrolling a little bit. I also moved the power management of the digitizer into ts_srv and out of liblights. Liblights should just be for the screen / notification lights. The CM team originally located the digitizer power management in there in lieu of setting up communications between liblights and ts_srv. We're now able to use the same socket communications to determine when to turn the digitizer on/off as well as open & close the uart.
Tracking IDs v13 for CM9 2012-02-25:
Added a filter to debounce a "hover" after scrolling. If you scroll a little ways then hold your finger still, it will debounce to 2 pixels. This may make scrolling really slowly a little bit jumpy, but it will keep the screen from wiggling around if you hold your finger still after scrolling. This version also includes a newer version of ts_srv_set that can return the touchscreen mode that is currently in use. This will be needed for the new custom settings for the TouchPad that include the ability to change touchscreen modes.
Tracking IDs v12 for CM9 2012-02-16:
No changes to the way touch behaves. Updated the path for the socket to use what I believe it he proper location for a Unix socket. This also marks the unification of the finger and stylus versions of the driver and you can now choose which mode of operation you want on the fly. There is an additional binary included in this zip called ts_srv_set. Run it via adb or terminal emulator like so:
ts_srv_set S
The above command would set the touchscreen thresholds for stylus operation. Doing this:
ts_srv_set F
will set it back to finger mode. The setting will stick between reboots (yes, we're using a settings file of sorts -- a very basic one) but the setting will be wiped in a factory reset. The default setting is finger mode, so if you are a finger user, there is nothing that you need to do. This version also includes the power savings features from v11, of course. Settings for finger then stylus mode are unchanged, but as follows:
TOUCH_INITIAL_THRESHOLD 32 32
TOUCH_CONTINUE_THRESHOLD 26 16
TOUCH_DELAY_THRESHOLD 28 24
TOUCH_DELAY 5 2
Tracking IDs v11 for CM9 2012-02-15:
No changes to the way that touch itself behaves. I have added code to both liblights and the touchscreen driver so that liblights can tell the touchscreen driver when the screen turns off. The touchscreen driver will now close the uart connection that it uses to receive touchscreen data to save a little bit of battery power.
ts_srv_set S
ts_srv_set F
TOUCH_DELAY 5 2
Quelle: (Danke dafür an RalfXtra)
TouchPad Android Touchscreen Driver Development (Updated 2012-02-16) - RootzWiki
Anmerkungen/ Weiteres:
- Es sind tägliche Builds -> es werden täglich Dinge verbessert, es können aber genauso Regressionen auftreten!
- Reboot Fix für Build 15.02.2012. Ab Build 20-02-2012 schon enthalten
Donald Nice schrieb:Den angesprochenen reboot fix gibt es hier: http://ergh.org/cmtp/update-cm-9.0.0...fix-signed.zip
- [MODPACK][2/27] SUPREME Mods v1.1 [Faster, Smoother, Faster Wifi, Better Battery]
CyanogenMod unterstützen:
Danke, wie immer an die super Entwickler hinter CyanogenMod, speziell an das CM9 Team!
Wer das Team unterstützen will, tut das am besten mit einer Spende auf CyanogenMod.com (ganz unten)
