I
in4mer
I was wondering if anyone was experience a problem with the mediapad. I have two units and they have both been experience the same symptom. The unit would awake from deep sleep mode and drain the battery with the screen on and the CPU on full. I have been monitoring my tablet and the cpuspy records the tablet in deep sleep mode for 136hrs:46 with other CPU speeds at less than 2 minutes. However, at 1188mhz, it was recorded for 4hrs:56 which is draining the battery so when I turn it on, it notifies me that it has 2% left. I've used betterbatterystats but I don't quite understand how to read the data. It says that it's been away for approx 5 hours which is when the CPU was at 1188mhz.
More info
This was happening on HC as well, so I'm wondering maybe if these units are defective if no one else is experiencing it. Having said that, I've read that huawei warranty/CS is horrendous.
Any help would be appreciated it is appearing on two identical units.
Cheers!
More info
Cheers!
c/wc/ec)11435/10179/0 2.4%
