[BUILD.PROP] Hier kann alles was mit der Build.prop zu tun hat rein!
  • 6 Antworten
MasterBoy71
MasterBoy71
Hallo zum zweiten, oder doch schon zum 3. ? Egal.....
Hier kann man sich über die BUILD.PROP auslassen.
Ich habe ja das HUAWEI P8 lite (ALE-L21C432B574 EMUI4.0 MM6.0)....
Hier meine Build.prop:
audioril.lib= libhuawei-audio-ril.so
bastet.service.enable= true
dalvik.vm.checkjni= false
" .heapgrowthlimit= 192m
" .heapmaxfree= 8m
" .heapminfree= 2m
" .heapsize= 512m
" .heapstartsize= 8m
" .heaptargetutilization= 0.75
" .isa.arm.faetures= default
" . " .variant= cortex-a15
" .isa.arm64.features= default
" . " .variant= generic
" .stack-trace-file= /data/anr/traces.txt
debug.aps.battery_limit= 5
" .hwui.render_dirty_regions= false
drm.service.enabled= true
fw.max.users= 1
fw.show_multiuserui= 0
gsm.fastdormancy.mode= 3
hw.lcd.density= 320
keyguard.no_require_sim= true
media.stagefright.use-awesome= false
modify_ram_show= true
net.bt.name= Android
persist.radio.apm_sim_not_pwdn= 1
" .service.tm2.tofile= true
" .sys.dalvik.vm.lib.2= libart
" . " .dualcards= true
" . " .jankenable= true
" . " .pgps.config= 0
" . " .strictmode.disable= true
qemu.hw.mainkeys= 0
ril.hw_modem0.rssi= -1
" .hw_modem1. " = -1
ro.balong_debug.port_num= 7
" .board.platform= hi6210sft
" .bt.bdaddr_path= /data/misc/bluedroid/macbt
" .build.caracteristics= nosdcard
" . " .date= Mon Jun 27 11:31:41 CST 2016
" . " .date.utc= 1466998301
" . " .description= hi6210sft-user 6.0 MRA58K eng.jenkins.20160627.112413test-keys
" . " .display.id= BalongC52B311
" . " .fingerprint= hi6210sft/hi6210sft/hi6210sft:6.0/MRA58K/jenkins06271131:user/test-keys
" . " .flavor= hi6210sft-user
" . " .hide= false
" . " . " .matchers= Mali-400 MP;Mali-450 MP;ARM;Honor;
" . " . " .replacements= unknown;unknown;unknown;unknown;
" . " . " .settings= 4;1.2GHz;1.0GB;405 MB;4.00GB;540x960;4.3;3.0.8;2.0
" . " .host= localhost#1
" . " .hw_emui_api_level= 9
" . " .hw_emui_lite.enable= true
" . " .hw_real.version= C900B574
" . " .id= MRA58K
" . " .nohota= false
" . " .product= hi6210sft
" . " .tags= release-keys
" . " .type= user
" . " .user= android
" . " .version.all_codenames= REL
" . " . " .base_os= leer
" . " . " .codename= REL
" . " . " .emui= EmotionUI_4.0
" . " . " .incremental= eng.jenkins.20160627.112413
" . " . " .preview_sdk= 0
" . " . " .release= 6.0
" . " . " .sdk= 23
" . " . " .security_patch= 2016-06-01
" .camera.beauty.algo.doc= 1
" .carrier= (Eigenes Netz)
" .cellbroadcast.emergencyids= 0-65534
" .check.modem_network= true
" .com.android.mobiledata= true
" . " .google.gmsversion= 6.0_r4
" .confg.hw_bootversion= C900B574_BOOT
" . " .hw_fastbootversion= C900B574_FASTBOOT
" .config.hw_systemversion= C900B574_SYSTEM
" . " .amrwb_disable= true
" . " .app_big_icon_size= 120
" . " .avoidScreenFlash= true
" . " .bg_call_twinking= true
" . " .carkitmodenotif= true
" . " .colorTemperature_K3= true
" . " .conn_diagnose= true
" . " .delay_send_signal= true
" . " .fm_type= libbcmfm_if
" . " .fp_navigation= true
" . " .huawei_smallwindow= leer
" . " .hw_accesscontrol= true
" . " .hw_allow_ums_and_mtp= true
" . " .hw_alterMime_type= 1
" . " .hw_directly_callfdn= true
" . " .hw_disable_cops= true
" . " .hw_dts= true
" . " .hw_emerg= on
" . " .hw_glovemode_enabled= 1
" . " .hw_gps_power_track= true
" . " .hw_hotswap_on= false
" . " .hw_media_flags= 3
" . " .hw_music_lp= true
" . " .hw_navigationbar= true
" . " .hw_sdInstall_enable= true
" . " .hw_showTestInfo= true
" . " .hw_sim2airplane= true
" . " .hw_smartcardservice= true
" . " .hw_subtitle_support= true
" . " .hw_support_geofence= true
" . " .hw_touchplus_enabled= true
" . " .hw_useCtrlSocket= true
" . " .hwft_PinPukUnlockscr= true
" . " .incall_notify_mms= true
" . " .ipv4.mtu= 1400
" . " .isSLEntitleSet= true
" . " .launcher_matchcard= 0
" . " .multi_task_enable= true
" . " .notification_sound= Bongo.ogg
" . " .pre_apn_NotDel= true
" . " .protocol_errors= false
" . " .readBtAddress= true
" . " .ringtone= Huawei_Tune.ogg
" . " .ringtone2= Hello_Ya.ogg
" . " .show2846= true
" . " .signalplus.xpass= true
" . " .support_ca= false
" . " .updatelocation= true
" . " .vc_call_vol_steps= 6
" . " .virtual_hd_voice= true
" . " .widevine_level3= true
" .cust.cdrom= /system/cdrom/autorun.iso
" .dual.sim.phone= true
" .expect.recovery_id= leer
" .huawei.dev_version= false
" .hwcamera.previeweffects= true
" . " .use.videosize.1080p= true
" .hwui.drop_shadow_cache_size= 6
" . " .gradient_cache_size= 1
" . " .layer_cache_size= 48
" . " .path_cache_size= 32
" . " .r_buffer_cache_size= 8
" . " .shape_cache_size= 2
" . " .text_large_cache_height= 1024
" . " .text_large_cache_width= 2048
" . " .text_small_cache_height= 1024
" . " .text_small_cache_width= 1024
" . " .texture_cache_flushrate= 0.4
" . " .texture_cache_size= 72
" .magic.api.version= 0.1
" .media.NxpSmartPACurve= ALE_1203:1,-49.5:33,-33.5:66,-17:100,0,0;-15:
" .mmi.electric_test= false
" . " .hall_sensor_test= false
" . " .nfc_test= false
" . " .otg_test= false
" . " .smartPA_test= true
" . " .support_camera_otp= true
" . " .support_slave_camera_otp= true
" . " .touch_screen_columns= 14
" . " .touch_screen_rows= 24
" .networkstatus.delaytimer= 20
" .opengles.version= 131072
" .product.board= BalongV8R1SFT
" . " .brand= hi6210sft
" . " .cpu.abi= arm64-v8a
" . " . " .abilist= arm64-v8a,armeabi-v7a,armeabi
" . " . " .abilist32= armabi-v7a,armeabi
" . " . " .abilist64= arm64-v8a
" . " .device= hi6210sft
" . " .locale= en-US
" . " .manufacturer= HUAWEI
" . " .model= hi6210sft
" . " .name= hi6210sft
" . " .platform= hi6210sft
" . " . " .pseudonym= 1ARB9CV
" .ril.ecclist= 112,911,#911,*911
" .setupwizard.mode= OPTIONAL
" .sf.lcd_density= 320
" .sys.umsdirtyratio= 2
" .systemui.debug= true
" .wifi.channels= leer
sys.refresh.dirty= 1
ENDE, endlich, habe schon ganz verspannten Hals vom ständigen hinundher mit dem Kopf!!!!
Vielleicht is die BUILD.PROP ja in dieser Form wichtig für euch?
Markus
What?
Hast du das etwa alles vom Smartphone Display abgetippt?
Reaktionen: MasterBoy71
[emoji5]
Zumal die Build.props zu 99% gleich sind. Sind ja nur Stock Roms verfügbar. [emoji6]
@mblaster4711 !!Ja und wie!! LoL
wie kann ich meine Build von "BalongC52B311" umbenennen in ALE...... ?
Zunächst muss der Bootloader offen sein, dann brauchst du noch "root-Rechte", dann ist es eigentlich einfach.
Mit dem Tool "System Tuner" vom Google-Playstore, kannst du dann die Build.prop ändern!
Aber mal ne Frage: "Wozu willst du einfach nur umbenennen?" bringt dir ja nix wirklich!
Markus
dachte eben nur es wäre doch aussagekräftiger wenn anstatt "BalongC52B311" das eigentlich installierte Build steht, ist ALE-L21C432B574
