Glitch kernel v13
  • 12 Antworten
theKingJan
theKingJan
Dauer-User
456
Hi Leute,
Ich habe jetzt die glitch kernel v13. im recovery Menü hat sich ein neuer Punkt gebildet dieser heißt GLITCH dort gibt es ein paar Unterpunkte die ich nicht verstehe zum Beispiel leakage wenn ich dort egal ob high middle oder low nehme wird mein Handy extrem langsam. Kann mir mal und. All diese Punkte erklären???
Anzeige
  • Gerade eben
  • Neu
Ich kopiere das einfach mal aus den Glitch-FAQ ...
4)What is Leakage (LL,ML,HL) and what one should i use? Easy explanation: start with HL. If it allows you to OC how much you want, stay there. If not, move down until you get what you want. For people who want more: Well, we made different leakages because koflem couldn’t OC, and he felt left out, so he started compiling on his own, which gave Tk-Glitch the idea to make three different versions. They have to do with the differences in different phones. Take for example different phones run better with different OC/UV. The leakages are the same way. They adjust the int voltages, which is something not configureable (yet) in userspace, so we have to configure them that way when we build. That way both the voltages that you are used to (the ones controllable via voltage control) are tailored to your device, as is the int voltages (the ones only we can do). Most people have no idea, but there are dozens of variables that we play with to make so that all of you can OC and UV as much as possible with as much stability as possible. Some aren't device specific, some are. We are trying to make the best experience possible for a wide range in chip quality, therefore we make different leakages, as well as making the kernel configurable via voltage control. From a stability/performance standpoint, and by extension standpoint, there is only one leakage right for your device. Different leakages aren't better in some ways for you and worse in others, there is only one good one for your device. Sorry if that didn't make sense, I tried to make it as informative as possible without it being overwhelming.
Danke,
Dass komische bei mir ist, dass wenn ich bei HI (High leakage) anfange auszuprobieren ist mein Handy langsam genauso bei ML und LL. Doch wenn ich die kernel flashe ist mein Handy sau Schnell. Also habe ich jetz die Kernel ohne irgendeine Auswahl zu treffen.
ich hab beim neuen auch noch nichts geändert, er läuft so auch sehr gut bei mir. hab bis v13 RC1 immer die HL version verwendet.
wenn du so probleme hast, dann will ichs auch gar nicht ausprobieren, hehee.
Genau
Ich wusste halt nur nicht ob man da was auswählen MUSS.
Was heißt toggle logcat
Damit kannst den logcat aktivieren um systemprozesse mit zu loggen.
Was heißt loggen??
theKingJan schrieb:
Was heißt loggen??
Log = etwas verfolgen, aufzeichnen....
Wahrscheinlich dumme Frage;
Sollt ich das anmachen???
Was hab ich für Vorteile / Nachteile???
Ganz ehrlich?
Wenn du fragen musst was "loggen" ist, wirst du es mit 100%iger Sicherheit auch nicht brauchen.
Reaktionen: Radagast
Gut gut
LOL ....
