kingoftf
Ehrenmitglied
- 56.848
Hier ein neues ROM von WAZL
AOSP mit integrierter LE Stock Kamera, auch Infrarot soll funktionieren.
Thread auf Unclemobile:
http://bbs.ydss.cn/forum.php?mod=viewthread&tid=919849&extra=page=1&filter=typeid&typeid=3357
Features laut Google:
Download:
MEGA
Screenshots direkt nach der Installation:
- Thanks to the big bottom package
- Team exclusive transplant production, prohibit reference extraction!
- New music frog desktop
- Added music camera
- Optimize the power of radio frequency logic
- Updated to 26s baseband
- Add infrared
- DPI card brush to achieve: http://pan.baidu.com/s/1bpAKTif
- Add xposed support, boot can be used
- Increase the core crack, software installation unlimited
- Strengthen cpu control
- Strengthen the uninstall mechanism
- Other deficiencies will continue to follow up the repair
- Has been tested bootable root available, if not available you can brush a card brush
- Mainly maintain official stability
- Promotions can be uninstalled by the re manager
- After testing, ROOT authority is normal
- Percentage of electricity displayed
- Dolby
- Freeze unloading
- CPU content
- Advanced settings are implemented using code, not bundled with a large number of apk
- Dat format brush machine, authority better
- Pull down the lunar display
- Optimize init.d permissions
- Integrated busybox instruction set
Past Update:
- Advanced settings, misappropriation!- Screen assistant
- Strong unloading
- Power menu
- CPU parameter settings, control of heat, manual control core
- Go directly to the developer option
- Time to stay in the next period to add
- Self-opening management
- Status bar advanced settings
- Slide brightness adjustment
- Shake set
- Please click on the specific function
- It is so simple, brush into the experience
Download:
MEGA
