kingoftf
Ehrenmitglied
- 56.848
Hier ein anderes ROM MIU V8 von einem "anscheinend" bekannten Dev.
Als Besonderheit scheint (laut Google Translator) bei dieser Version die Displayhelligkeit verbessert worden zu sein. So zumindest meine Interpretation von der Übersetzung.
Original Thread:
乐视2 MIUIV8.11.19三指应用 全局动画 冰箱IOS显秒 指纹 破解主题 全网通1119更mandfx_官方刷机包_ROM下载_刷新教程_最新最全的安卓系统下载_乐2/乐2 Pro论坛_移动叔叔 - 手机版
Features laut Google Translator:
>>> Update log <<<
New production full access to ROOT permissions Shuangqing not lost ROOT random brush test does not appear part of the application does not pop ROOT authorization problem
Increased support for the EUI5.6 version of this version, whether you are EUI5.6 or EUI5.8 support direct brush into, does not appear to restart the problem repeatedly.
Added global over-animated switching support IOS animation Blur animation Nine-end animation DX8 animation IUNI animation switch
Auxiliary function inside to restore the call flash function
Screen Assistant transparent adjustment to slide do not have to manually enter so much trouble
Fix automatic brightness adjustment to the lowest black screen problem
Repair VoLTE HD calls
Repair small probability of desktop weather can not switch successfully
Fix the dropdown search box to restore the official style can not search for the problem
LCD density increased three kinds of value interval is adjusted to 20
Software, a key to the refrigerator to thaw the software to prevent inadvertently touch MENU inside
Optimizing the notification bar The search box toggles the direct restart of the notification bar while optimizing IOS switching
Optimization Status Bar Virtual Key Code Partial Feature Adjustment Scenario Switching Support Tip Current Mode
A key brush machine process optimization support selection is double clear
Viper audio upgrade the latest official version of the latest 2.5.0.4 driver integrated
Xuan Mai set part of the function optimization paging adjustment for the 4-page features at a glance
Fixing icons with official default theme is not a rounded corner problem
Repair Xuan Mai set the desktop layout can not switch the problem
Need to call the flash can be set in the phone - call the state inside the open
Recommended to open the Security Center - Power - Power saving mode - timer switch power saving mode (at night more energy-saving standby longer)
Based on the official latest MIUIV8 development package unpacking, complete ROM production
Add full permission to get ROOT ROOT Shuangqing not lose random testing does not appear brush part of the application does not pop ROOT authorization issues <br /> use the latest version of SuperSU better perfect perfect ROOT authorized management compatibility crack themes, download directly paid theme without installation xposed frame <br /> crack the system limits the application does not support the deletion of systems Cami streamline millet lock screen Illustrated bulky need can turn on USB debugging applications market in addition to the default search download external SD card write the appropriate limit streamline some may Will not be used to add the system application Busybox and init.d command support to add exclusive MIUI system based on customized Hyun Mai settings, no default desktop icon in the system settings which open to support the addition of desktop shortcuts.
Xuan Mai settings support delete, delete the settings do not retain the option (if you feel good function set can be deleted does not affect)
Common Required Settings:
Support advanced power: normal mode recovery mode Brush mode
Support the button to switch the menu key and return key to switch the mutual function
Support three finger down function function as follows:
Customize Startup Application | Shutdown Menu | Close Screen | Back to Features | Task List | Home Page | End Current Program | Profiles | Screen Graffiti | Activate Flashlight | Mobile Data, Bluetooth, Auto Brightness, Auto Rotate, WIFI Switch | Clean up memory
Support shake mobile phone function support shaking vibration sensitivity adjustment function is as follows:
Support the status bar Virtual key function Support key vibration key position Virtual key click and long press function function as follows:
Adding software The refrigerator function supports freezing of the system as well as installed applications
Can be used on the phone is very important but very important APP hidden, like frozen inside the refrigerator, use the time to thaw in the run, and to prevent APP secretly run and run traffic.
Support double-click the HOME key lock screen is very convenient and practical
Flash function support calls to make up for lack of official support frequency adjustment support ring mode vibration mode silent mode
Add WIFI password viewer features support replication WIFI password easy sharing
Support desktop icon layout adjustment 4 * 54 * 65 * 55 * 66 * 6 and other types of display layout supports Desktop Weather
Support for custom screen LCD density adjustment The smaller the screen density, the more content will be displayed
Support to remove the charging sound screen shot sound switch
Add a system test entry View network information Battery information
Add Developer Options Import Do not double-click the version number directly
An increase in official website Sina microblogging mailbox anytime Cohesion feedback recommend <br /> Status Bar:
Support double-click the status bar function as follows:
Support long press the status bar function as follows:
Support to open the status bar Time seconds Display the status bar time accurate to seconds
Support status bar time display year week day month week and so on
Increase the sliding status bar to adjust the screen brightness function
Add the status bar style features a key to switch IOS status bar style
Add enhanced network speed function Double row display supports single row and hide
Increase the removal of the official notice bar search box switch to open the default accessibility:
Add Viper Sound Classic V4 sound installed by default to install the driver directly
Add the Xposed framework one-click install uninstall feature (integrated with the latest 86 version)
New upgrade screen assistant Support two style switch Support for transparency adjustment (for a better experience Suggested task list to glory set lock task)
Return key, house key, menu key, long press function of the task key: support the following options
Turn off the screen | End the current program | Activate the flashlight | Screenshots | Open the glory settings | Restart the phone | Turn off the phone | Pull down the notification bar | Custom launch the installed application
Support the core control of custom operation CPU core support open all the core
Support core control increase CPU frequency display refresh every second.
Download auf Mega:
MEGA
Installation wie üblich, notwendig ist ein TWRP Recovery einer China-Version wie die Dev-ROM 18s.
ROM aufs 2 Pro kopieren, reboot in Recovery, Factory Restore und ROM flashen, Reboot, erster Start dauert Ewigkeiten, danach Einrichten und mit Google Installer V2 die Gapps installieren.
Original Thread:
>>> Update log <<<
Download auf Mega:
MEGA
, da hatte ich am Strand mit dem 2Pro und der MIUI (ältere Version) schon mal massive Probleme, überhaupt was zu erkennen.
