[ROM] Stock 28s erste Beta für das X620
  • 13 Antworten
kingoftf
kingoftf
Ehrenmitglied
56.848
Von der Entwicklerin Xiajie die erste Beta der 28s Stock ROM
【11.01】乐2-X620-28S内测第一版|下拉温度_最新最全的乐2/乐2 ProROM刷机包下载、刷
Thread auf Leeco.re:
【11.01】 Le 2-X620-28S closed beta first version | pull-down temperature display | status bar switch | eye mode | music to shoot | to advertising
Features laut Google Übersetzer
28S closed beta first edition
Please double clear brush into
The first boot can skip the music as account verification, (do not network, can always skip)
Because it is closed beta official did not give the update log, their own experience
Because it is closed beta, if a little BUG is normal.
Drop the new music control panel and the temperature display
Remove the steward calendar theme shop browser wallpaper and other advertising services
Music toolbox new power menu new model modification (king open high frame necessary)
Update Super SU for V2.82-SR5 latest version
Other modifications and fixes are not described here
【Fingerprint and password】 add music to shoot the new function (lock screen page can use the finger to shoot the camera to open the camera)
【Display】 New speed display eye mode
【Settings】 new memory (you can view the memory used by each application)
【Settings】 new smart screen freeze and uninstall (can uninstall built-in software or freeze)
【Music Toolbox】 new eye protection mode
Remove the settings inside the print service function and reset and replace the machine
Support the status bar switch, you can switch the original status bar or three status bar, the default original
The music toolbox supports status bar switching
Support Shake Lock Screen Custom Operator Status Bar Virtual Key
Dolby Sound Viper Sound Screen Assistant WIFI Password View
Self-service management DPI settings CPU FM performance monitoring eye mode
xposed frame install / uninstall custom status bar memory release
Modify selinux state for tolerance mode;
host s shielding part of the ad
Increase the RE manager (good uninstall built-in software)
Built-in several promotional software, do not need to set the freeze or uninstall in the set to delete, restart (hope to help activate and then delete the oh)
Download:
2017.11.01-乐2-乐2Pro-28S内测第一版.zip
All Credits to Pete80pro
Fullwipe wird dringend empfohlen, da neue Basis.
Sicherheitspatch vom Januar...
Und Fingerprint funktioniert nicht
Komisch, noch mal neu installiert, nun funktioniert Fingerprint.
Link nicht funktioniert, zeigt:
{"error_code":31360,"error_msg":"expire time out error","request_id":8045901671000249416}
Bin immer noch mit dem Upload auf Mega beschäftigt, unglaublich, schon 6 Stunden und immer noch nicht fertig..
Neue Stable mit nur 1,17 Gb, da wurde kräftig gekärchert, um Bloatware zu entfernen (Stock ist sonst immer bei 1,5 Gb), habe ich aber noch nicht getestet, gerade erst gefunden
Le2-28S稳定版-至臻·简约2018V1 基于官方28_最新最全的乐2/乐2 ProROM刷机包下载、刷
Google Übersetzer
Ich lade das ROM mal runter und pack es gegebenenfalls auf Mega.
Download erstaunlich flott mit JDownloader, nur 30 Minuten verbleibend, sonst sind das immer Stunden....
Hier eine Liste der Files, die er scheinbar gelöscht hat:
FC Google Kontake sync
[doublepost=1515486634,1515485905][/doublepost]Kalender Sync geht auch nicht
