[ROM] X620 23s Beta CH/ EN
  • 6 Antworten
kingoftf
kingoftf
Ehrenmitglied
56.848
Hier eine sehr gut funktionierende ROM von einem bekannten Chinesischen Entwickler, die wohl erste 23s, in den Telefon-Infos schon als Stable bezeichnet.
Features laut Google Translator:
23S update instructions:
23S generally updates the content
Voice Assistant Integration
Intelligent volume
Suspended Ball Related Optimization
The Bluetooth Discovery button adds an open time limit
Add a geo-fence entrance to the steward (Qualcomm platform) (music 2 high-pass version of the X520 yet added)
Calendar, my music as, notes, gallery, theme store APK support from the upgrade
A key replacement related optimization
Cloud storage to increase the direct upload entrance
Clock, lock screen, SMS, phone support global theme (note the need to develop the theme of the author)
As well as partial BUG and functional power-saving optimization
Add the complete ROOT SuperSU-v2.79-SR3
Keep the weather, the application store (application store in the system / app / LetvStore inside LetvStore.apk.bak LetvStore.apk to restart it)
Remove the headlines from the desktop and enjoy it
Retention preference backup, for some users to restore the software data
The Net Speed Display (Steward - Flow Control - Flow Settings) is on
【Settings】 interface to increase and music toolbox and freezer, intelligent recording screen
Hosts block some ads
Modify the desktop Live button to lock the screen
Increase the RE Manager (well uninstall the built-in software)
Streamline the official a large number of useless software and resources, more memory more power
Preservation of music video, music, search, search, compass, remote control, butler and other practical tools
Built-in 4 software, you can not in the settings in the freeze or uninstall delete, restart (hope to help activate and then delete Oh)
Power saving tips:
Close a variety of software since Kai, delete some useless built-in software, do not install too many XP plug-ins, can not tick the best not to activate, so much power
Developers option / the animation zoom off, so more fluid
CPU core settings and freezer! From the LAY team cold rain night God, without permission, to prohibit the use of stealing, or chase deal!
● Support xposed framework component custom installation or uninstallation
● support xposed frame (module must artifact)
● frame module to use: Open the toolbox → xposed frame → module, which in the module to restart the tick on the line
● support model camouflage (QQ space can pretend to talk about tail, what to change anything, need to brush into the xposed framework components)
● support for Dolby sound entry (sound quality is more robust)
● Support for freezer rooms (which can freeze or unload any unwanted applications)
● Support Wifi password view (you can view the connected WIFI password)
● support for memory release (after the release of large memory, 4G can be left 3G, 3G can be left 2G)
● Music Toolbox adds performance monitoring
● Added Turbo download
● Add a custom modification of the DPI value
● Add a flash of incoming calls (turned on by default, can be turned off in Settings - Accessibility)
● support Viper sound
● support cpu core functions, can be free to open nuclear
● Support advanced power, restart to Brush mode
● Customize the status bar
● Add shortcut entry to project mode
Thread auf Leeco.re:
[02.08] Le 2 EUI5.9-23S closed beta first edition | drawer desktop | voice assistant | Viper sound | status bar | DPI | complete root
Original Thread:
http://bbs.ydss.cn/thread-758556-1-1.html
Download:
MEGA
Installation wie gehabt, ROM aufs 2Pro speichern, Reboot in Recovery, Fullwip (außer internem Speicher)
ROM flashen, auf Englisch einstellen und konfigurieren, danach mit Google Installer die Gapps installieren und, falls gewünscht, mit Morelocate2 die Apps auf Deutsch umstellen.
Download Google Installer siehe Anhang.
Screenshots © Pete80Pro
Läuft bisher, habe sie gestern Abend geflasht, sehr rund und ohne Bugs.
Es sind natürlich noch einige chinesische Apps installiert, die sich aber zum Beispiel mit Titanium gut deinstallieren oder zumindest einfrieren lassen.
  • Google_installer.apk
Reaktionen: Epasmic
Es gibt eine neue 23s Beta3 mit Patch von heute (!), allerdings auch nur CN/EN
Habe mir diese Rom einmal gefasht, funktioniert eigentlich ganz gut. Nur bekomme ich kein GPS-Signal, obwohl GPS aktiviert ist. Was könnte der Grund dafür sein?
Bei mir funktioniert sie nicht, eine Fehlermeldung nach der anderen trotz Fullwipe. Bin wieder auf der Purple, die sehr gut funktioniert.
Könntest du mir bitte sagen, welche Rom die "Purple" ist? Ich habe ein le 2 ohne Pro. Vorher lief das BB72 Rom relativ gut auf dem Handy. So wie ich das sehe, wird diese Rom nicht mehr weiterentwickelt. Eigentlich schade.
Le 2 X620 Purple Fire rapid repair version of the fifth edition based on EUI5.9 production enhanced performance rapid experience Root stable version
MEGA
[doublepost=1492545125,1492544780][/doublepost]23s Official Stable steht vor der Tür, ein ROM gibt es schon, aber noch als Beta, scheint aber wohl demnächst offiziell zu erscheinen.
http://bbs.ydss.cn/thread-839603-1-1.html
Based on the official release of the official release of the 23S official version of the stable production
Aber unverständlicherweise Sicherheitspatch vom Dezember 2016
Läuft nach Aussage einiger Tester noch nicht so rund.
