[ROM] king_3d_rom_v1.1 mobile data works too
  • 0 Antworten
joker.20
joker.20
Hier ein neuer custom rom. so langsam gehts los. sehr nice!
werd ihn natürlich selber flashen und berichten. ob hier das problem auch besteht mit dem mobilfunkdatenverbindung.
here is the second version of the Italian Rom created
by me for the optimus 3D.
The KING_3D_ROM_V1.1
characteristics:
version 1.0
based V10D
optimized ram
added root+su
added busybox
added animated theme created by me
removed the original app
added performance patch
added gps europe patch created by me
changed bootanimation
lg home removed
added launcher go ex (very fast and powerful)
added root Explorer 2.16
the new market optional (open root explorer and go
to,data/app/nuovomarket.apk and install)
the keyboard created by me optional (open root explorer and go
to,data/app/htc_ime by king.apk and install)
version 1.1
Fixed bug data network
Add more APN
Add anti-ad hosts
Installation procedure:
make a backup of applications and data with wipe
because you will delete 'all the contents of your
phone
1) copy the files on the external sd
2) reboot into recovery (ClockworkMod 4.0.0.9)
3) make a backup nandroid (useful to restore your
files and apps)
4) make the full wipe (Cache, date and Dalvik)
5) Flash zip from sd card -> select the file
6) reboot system now
Optional 7) reboot into recovery and go to backup and
restore / advanced restore / YOUR BACKUP / Restore
date (this puts all the files and apps as you had
before flashing this rom but leaving unchanged the
current Rom)
CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM
INSTALLATION REQUIRES A LONG TIME, EVEN 5 MINUTES, AND THE FIRST TO START is very slowly because recreate the cache, do not be alarmed
1 st version:
Download KING_3D_ROM_V1.1.zip for free on Filesonic.com
2 nd version:
-Equal to the first except that the pixel density has increased, this increasing the screen resolution and the 3D effect in the gallery!
http://www.filesonic.com/file/1555685051/KING_3D_ROM_V1.1-PIXELDENSITY+.zip
