joker.20
Hier ein klasse rom :
I'm good because MY FIRST ROM for this machine, fast, fluid and stable
-Fully deoxed
-Updated upgrades ram optimization
-Added tweaks to improve the smoothness and fluidity of the system
-Added tweaks I / O
-Added new listing apn settings
-Host-Atualizado to avoid advertising on apps
-Added flash player 10.3
-Zipaligned
-Changed Bootanimation
-Added Battery-circular%
-Added Chanfire3D
-Added ES Explorer
-Added Rebooter
-Added Titanium Backup
-Superuser
-Improved system speed
-Added 2 wallpapers to live according to climatic effects climate prediction
-Removed launcher LG
-LG-Deleted Widgets
Added Launcher galaxy mod s2
-Number of homescreens
-Choose which to put as the main
-Landscape-mode
-Home-screen with 4x4 or 4x5 icons
-Dock with customizable icons number
-Indicators of angina-autoocultar
-Choose the number of pages of apps
-Choose number of icons for apps page
-Organization of alphabetical or custom apps
-Transition between pages of SDAs 3D or normal
-3d-apps or normal effect
-Creating folders in desktop and apps
-Autoocultable-dock
-Themes to customize
-Etc etc
-Added to internal sd:
(For optional installation by the user)
Kingdroid Apps
Kingdroid Drivers:
-Drivers for Chanfire3D
(Explanation: The main feature of Chainfire3D is the ability to load additional plugins in the driver that includes the application, opening endless opportunities in gaming. For example, the ability to play games for Tegra processors for handsets without the Chip carrying a number of drivers from Nvidia. P)
First, after loading the driver in the application can activate a feature called "Night Mode" (Night Mode) which will save battery because that will show the screen on a scale of red, a color according to various sources reduces the consumption of LCD, OLED and AMOLED. It also has a role in reducing the size of the graphic textures, making the performance of our Android to play certain games better and more fluid. We may also reduce the quality of the textures, making the memory consumption is lower and thus improving the performance of our device while minimizing battery consumption.
How to use games without Tegra Tegra Zone 2?
It is a delicate operation, do this at your own risk:
1) Enter the application root and set permissions for it
2) Click the option CF3D driver and install, after this, reboot the phone
3) Back to Chainfire and go to "Install plugin" and install the three departing
4) Then navigate to "Default OpenGL settings" then "Use Plugin" and activate "Nvidia"
-Provide for me the Samurai 2: Vengeance and vice XD
etc
Kingdroid Walls:
Wallpapers
SAUBIENDO...
SCREENSHOTS:
Change Log V1.5TOUCHWIZ
-Nuevos ajustes del build.prop
-Añadido teclado Swype
-Añadido nuevo bootanimation (por ErosizeD)
-Mejoras graficas en menus
Change Log V1.5LG
-Eliminado TouchWiz launcher + apps enlazadas
-Full LG Soft
-Widgets agrupados (ahora mas limpio al elegirlos)
Change Log V1.5GO
-Añadido GO Launcher EX por defecto (por votación)
Change Log
Change Log V1.5LG
-Full LG Soft
Change Log V1.5GO
Change Log V1.4.1
-Mejoras en en consumo de bateria
-Limpieza de archivos
-Añadida app musica MUIU (caratulas,letra canciones,etc)
-Eliminado LGWorld
-Editado Framework
-Nuevos nuevos graficos en status bar
-Nuevos nuevos graficos en Notificaciones
-Nuevos nuevos graficos en conexion USB
-Nuevos graficos menu launcher
-Nuevos graficos gmail
-Nuevos graficos mms
-Nuevos graficos google maps
-Nuevos graficos popup emergentes
-Nuevos graficos LGMail
-Nuevos graficos de ajustes
-Nuevos graficos youtube
-y muchos mas graficos que ahora no recuerdo XD
-Añadidos nuevos ajustes y Tweaks en build.prop
-Market actualizado a su version 3.1.3
-Cambiado Facebook for android
-Cambiado Twiter for android
-Eliminado LGWorld
-Editado Framework
-Fully deoxed
-Added tweaks I / O
-Zipaligned
-Added Chanfire3D
-Added ES Explorer
-Added Rebooter
-Superuser
-LG-Deleted Widgets
-Landscape-mode
-Autoocultable-dock
-Etc etc
Kingdroid Apps
Kingdroid Drivers:
etc
Kingdroid Walls:
Wallpapers
ENLACE DE DESCARGA DE LA ROM V1.3:BASE 10E
imprescindible wipe data/factory reset y wipe cache partition
ENLACE DE DESCARGA DE LA ROM V1.5TOUCHWIZ:BASE 10E
WIPE RECOMENDADO wipe data/factory reset y wipe cache partition
ENLACE DE DESCARGA DE LA ROM V1.5GO:BASE 10E
ENLACE DE DESCARGA DE LA ROM V1.5LG:BASE 10E
NUMERO DE DESCARGAS DE LA ROM V1.4.2:
839 DESCARGAS
ENLACE DE DESCARGA DE LA ROM V1.4.1:BASE 10E
EXTRAS Y MODS
WIDGETS ORIGINALES LG + LAUNCHER LG:
(Instalar desde recovery,como una rom,sin wipe)
WIDGETS ORIGINALES LG (SOLO WIDGETS):
TODAS LAS SYSTEM/APPS ORIGINALES:
SAUBIENDO...
NUMERO DE DESCARGAS DE LA ROM V1.2:
