[ROM-p920] KING_3D_ROM_V2.0
  • 19 Antworten
boostermbkking
11th version of the KING_3D_ROM by KING3Developers.
  • Based on v10k
  • Busybox + Root + Su
  • Full deodex apps & Framework
  • Franlov kernel
  • System converted in ext4
  • New framework
  • Optimized ram
  • Increased speed of microSD
  • Performance patch
  • Increased speed of system
  • Added more ringtones and notification sounds
  • Added ubuntu font
  • Added live wallaper
  • Added widgets dialers
  • Added 2D-3D converter
  • Added KING-manager
  • Removed LG Apps
  • Added new apn
  • Game installed on external sd
  • Best 3D menù
  • Android Market 3.1.5
  • Facebook 1.7.1
  • GoLauncher 2.58
  • KING-manager 1.0
Installation procedure:
make a backup of applications and data with wipe because you will delete 'all the contents of your phone
1) copy the files on the external sd
2) reboot into recovery (ClockworkMod 4.0.0.9)
3) make a backup nandroid (useful to restore your files and apps)
4) make the wipe 3 (Cache, date and Dalvik)
5) Flash zip from sdcard -> select the file
6) reboot system now
7 optional) reboot into recovery and go to backup and restore / advanced restore / YOUR BACKUP / Restore date (this puts all the files and apps as you had before flashing this rom but leaving unchanged the current Roma)
CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM
INSTALLATION REQUIRES A LONG TIME, EVEN 5 MINUTES, AND THE FIRST TO START is very slowly because recreate the cache, do not be alarmed, JAM IS NOT NOTHING
Rom screenshots
Download:
KING_3D_ROM_V2.0
Now I want to talk about the new program that you will find in the rom, free downloadable also from the market, is called King-manager, is an app created by lpirro (team member of the Rom as well as very good programmer), at my request, you can check with this rom changelog of the new ROM, you can download a new version of the rom if available via mobile phone and then flash from cwm, but most importantly, you can report bugs and ask for help the Roma to me directly via the function bug report and I will answer all very quickly trying to satisfy everyone who wants a mobile rom and my performance even though they are starting out with Android, in short, I will give you a better feeling with the Roma than all the others that for every problem you have access to the forum to report it But with this app wherever you are and for whatever reason, it is trivial, you can contact me to ask for clarification ...
THIS 'DO A GIFT THAT I WANTED TO ALL THOSE WHO TRUST IN ME Put DEVICE FOR THEM! ! !
I leave you now with the screenshots of this fantastic, functional and useful app:
PREVIEW:
SCREENSHOT
if you want support for this rom to me please write in English or Italian.
Hallo habe schon
KING_3D_ROM_V1.9
muss ich alle 3 wipe machen oder muss ich nicht um update zu machen
gruss
hi boostermbkking,
do we need to full wipe (Dalvic, Cache and data) if we have V 1.9. installed ?
Regards
Ja, da ein neuen Kernel + ext4 (Dateisystem) eingekocht hat.
ok danke habe gemacht
also komplett wipen? quasi so das alles weg ist?
so liest es sich. Du kannst es auch ohne Komplett-Wipe versuchen und schauen ob es funktioniert.
also im king-manager zeigts mir die 2.0 an..heißt das automatisch dass alles klar ging oder kann es sein das einige sachen nicht übernommen wurden?
weil wenn das so ist hät ich jetzt auch kein plan wie ich das überprüfen könnte:/
Könnte sein, dass du jetzt kein ext4 hast. Am einfachsten bekommst du das mit z.B. Quadrant raus, bei dem Ergebnis 2300-2700 hast du kein ext4, bei über 3000 sollte alles passen :D
ich hab 2928 :D
hab ichs jetzt oder nich??? was ist eig ext4?
und falls jemand die antwort hat würd mich mal noch interessieren in wie fern sich das neue kernel bemerkbar macht? hab kein plan was das is :D
übrigens ist das forum hier der knaller!!
Gibts irgendwo ein tutorial wie man genau die neue rom drauf spielt?
Dankeschoen
Kann mich nicht begeistern. Bin nach längerer Zeit wieder zu ThiaiZ zurück, weil mir das gar nicht gefallen hat. Sehr langes booten, teilweise sehr lange Rechenzeiten beim installieren von Apps o.ä. aber auch das scrollen hat manchmal gestockt. MMn war der neue Kernel wohl ein Rückschritt.
ich habe keine von dir genante probleme,und erreiche auch in Quadrant sehr gute werte
gruss
hatte genau die gleichen symptome und bin auch zurück zu ThiaiZ. am kernel sollte das aber nicht liegen, ich verwende den auch mit ThiaiZ-1.5.1 und hab die probleme da nicht. (quadrant 3100~3500)
ich habe Quadrant 3600-3800
Hab auch schon 3700 gesehen - nach mindestens 3x in folge ausführen :) war eher als Richtwert gedacht und ungefähr sind wir ja da... (hängt auch ziemlich davon ab, wieviel apps installiert sind)
Sent from my LG-P920 using Tapatalk
Ich hab nur 2666 punkte mit thiai
Ausserdem wird mir bei system in formation nur "Cores: 1" angezeigt. Warum auch immer..
Und da steht ARMv7 prozessor. Ich dachte ich haette einen texas instruments?
Frage: hab auch kein ext4 und komm auch so über 3500 bei quadrant?! (mit dem acura kernel)
Die Plattform also wenn ich das richtig verstanden habe das motherboard ist von TI der chipsatz ist von powerVR (denk ich mal), ich habe iwo auch mal gelesen das die software von dem chip sogar von nvidia geschrieben wurde ?! ( bin mir bei allem jedoch nicht so ganz sicher :))
