JWayne84
- 22
Hat das schon wer installiert? Probleme?
Changelog:
System
• Optimized the experience with a split-screen of apps
• Further optimized system power consumption and increase battery life
• Fixed the small probability issue that expanded screenshot may stop working
• Fixed the issue that cache is not deleted after uninstalling apps
• Fixed the issue that the screen may flash when using fingerprint unlock
• Fixed the issue that Horizon light is not activated normally
• Fixed the small probability issue that NFC can not be turned on
• Fixed the small probability issue that Parallel Apps can not be turned on
• Fixed the small probability issue that the fan of the Warp Charge 30 Wireless Charger may not work
• Fixed the issue that Play Store could not install the app
• Updated Android security patch to 2020.11
Network
• Fixed the small probability issue that network interruption issue in some apps
• Improve the stability of communication functions
Changelog:
System
Network
