[Mirror] Original Firmwares OxygenOS [aktuell OxygenOS 5.0.3]
CerealKiller77
CerealKiller77
Stammgast
435
OnePlus 3T - Original Firmwares OxygenOS
FUll ROM
Android 8.0.x
OxygenOS 5.0.3
Part 1 | Part 2
OxygenOS 5.0.1
Part 1 | Part 2
OxygenOS 5.0
Part 1 | Part 2
OxygenOS OpenBeta 18
Part 1 | Part 2
Android 7.1.x
OxygenOS 4.5.1
Part 1 | Part 2
OxygenOS 4.5.0
Part 1 | Part 2
OxygenOS 4.1.7
Part 1 | Part 2
OxygenOS 4.1.6
Part 1 | Part 2
OxygenOS 4.1.5 (wurde von OnePlus zurückgezogen)
Part 1 | Part 2
OxygenOS 4.1.3
Part 1 | Part 2
OxygenOS 4.1.1
Part 1 | Part 2
OxygenOS 4.1.0
Part 1 | Part 2
Android 7.0.x
OxygenOS 4.0.3
Part 1 | Part 2
OxygenOS 4.0.2
Part 1 | Part 2
OxygenOS 4.0.1
Part 1 | Part 2
OxygenOS 4.0
Part 1 | Part 2
Android 6.0.x
OxygenOS v3.5.4
Part 1 | Part 2
OxygenOS v3.5.3
Part 1 | Part 2
** Jeweils die 2 Part Files downloaden und 1x entpacken, so dass ihr 1 .zip Datei erhaltet **
Reaktionen: rebell96, ger_kar, TeeJayd und 2 andere
OxygenOS 3.5.4 Android 6.0.1 eingepflegt.
Changelog:
  • Optimizations for US-TMO Network
  • Optimizations to Reduce Lag when Battery is below 5%
  • Optimized Bluetooth Connectivity
  • Optimized Battery Saving Mode: GPS and Orientation Preferences will be restored when Battery Saving Mode is closed.
  • Fixed Flashlight Usability Issue in WhatsApp
  • Increased System Stability
  • Implemented Various Bug Fixes
Reaktionen: freeztyler und Bandit1964
OxygenOS 4 - Android 7.0.x und OpenBeta 1 - Android 7.0.x eingepflegt.
Changelog OxygenOS 4 und OpenBeta 1:
  • Upgraded to Android 7.0 Nougat
    • New Notifications Design
    • New Settings Menu Design
    • Multi-Window View
    • Notification Direct Reply
    • Custom DPI Support
  • Added Status Bar Icon Options
  • Improved Shelf Customization
OxygenOS 4.0.1 - Android 7.0.x eingepflegt.
Changelog OxygenOS 4.0.1:
    • Multi-Window View
  • Updated APN Settings for select Carriers
  • Fixed Proximity Sensor bug during calls
***Known Issues and Fixes
  • Apps might not download from Play Store.
    • If you are trying to download via Data Roaming, it will not work. This is a known Google issue.
    • Please follow Google’s troubleshooting steps and see if the problem is resolved.
    • Try turning on Battery Saving Mode and reset Play Store app preferences.
    • If you have these 3 apps installed: Truecaller, AVG Antivirus and PayTm, please try to force stop or uninstall them before performing download from Play Store.
  • If you still experience mobile data issues caused by APN, please go to APN settings page and manually choose try all the options. In the case that mobile data is still unusable, please send me a pm along with affected career and device model.
  • WiFi connectivity might still fluctuate, if you experience this issue, please send me a pm.
@TimeTurn
Es hindert Dich niemand daran einen eigenen Thread mit entsprechenden Mirrors zu erstellen.
Würde durch Moderatoren gelöscht oder mit diesem Thread zusammengefasst, macht also keinen Sinn. Zwei Threads zum gleichen Thema wird nicht gern gesehen.
Du kannst aber, so habe ich das beim S3 und S4 früher immer gemacht, den OP fragen, ober er Deinen Mirror ins Startpost einfügst..
So habe ich mir bei Share-Online immer meine Freimonate verdient...
Finde ich auch völlig OK. So haben beide Seiten etwas davon...
Reaktionen: CerealKiller77
OxygenOS 4.0.2 - Android 7.0.x eingepflegt.
Changelog OxygenOS 4.0.2:
    • Multi-Window View
    • Added Status Bar Icon options
  • Fixed Google Play Store download bug
OxygenOS 4.0.3 - Android 7.0.x eingepflegt.
Changelog OxygenOS 4.0.3:
Hi all,
We are starting the incremental roll-out of OxygenOS 4.0.3 for OnePlus 3T.
Here are some highlights:
Added Wi-Fi IPv6 Support toggle
Optimized Smart Wi-Fi Switcher, if turned on, device will switch to data connection if Wi-Fi signal is consistently poor
Fixed crashes for Line
Increased stability of the Camera app
Optimized exposure when taking night time photos
Updated Audio Parameters and improved the quality of audio recordings
Updated APN settings for select carriers
Amazon Prime App will be pre-installed for India Users
Wi-Fi disconnections
If you experience frequent WiFi disconnections, please go to Settings > Wi-Fi > Configure WiFi (Top right hand corner) > Scroll to bottom of the page and check the IP address format (IPv4 = Single line, IPv6 = Multiple lines)> If the IP address is IPv6 based, then turn off the IPv6 Support toggle and see if the disconnections stop.
If you experience frequent WiFi disconnections due to switches between WiFi and data, please try turning off the Smart Wi-Fi Switcher at Settings > Wi-Fi > Configure WiFi and see if the disconnections stop
If you still experience WiFi connectivity issues, please send me a pm. Thanks.
For those who were on previous versions for OnePlus 3T, we appreciate your active feedback and attempts to reach out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to hearing your continued feedback in the bug reporting forum here: Bug Reports - OnePlus Forums.
Please follow the link below for the UI/UX experience survey. We’d really appreciate a few minutes of your time, as it will help us make OxygenOS even better.
- Feedback on UI/UX: OxygenOS 4.0.3 Official Release for OP3/OP3T
As always, this OTA will be incremental. The OTA will reach a small percentage of users today, and we'll begin a broader rollout in a few days.
Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy!
Never Settle.
OxygenOS OpenBeta 3 - Android 7.1.1 eingepflegt.
Changelog OxygenOS OpenBeta 3:
Key updates in this build:
  • Upgraded to Android 7.1.1
  • New Shot on OnePlus wallpaper option
  • Gallery Improvements
    • New photo editor with watermark and photo straightening options
    • Newly added media will be highlighted in Photos section
    • Image location will be displayed on grid view
    • Media can be grouped by month and year
    • Folders and individual media can be hidden
  • General bug fixes
  • Android pay not able to work on London TFL/Tube
    • This can be resolved by updating the app via Play store
  • Compatability issues with certain third party apps
OxygenOS 4.1.0 - Android 7.1.1 eingepflegt.
Changelog OxygenOS 4.1.0:
  • Upgraded Android 7.1.1
  • Updated Google security patch to 1st March 2017
  • Added expanded screenshots
  • Improved picture taking of moving objects with blur reduction
  • Improved video stability when recording
  • Improved WiFi connectivity
  • Improved bluetooth connectivity
  • General bug fixes
- Feedback on UI/UX: OxygenOS 4.1.0 Official Release for OP3/OP3T
Never Settle.
Neuste Firmware Part 2 nicht vorhanden
Tippfehler im Link.
Jetzt funktioniert es.
Danke für den Hinweis.
OxygenOS 4.1.1 - Android 7.1.1 eingepflegt.
Changelog OxygenOS 4.1.1:
Improved WiFI connectivity
Fixed Instagram swiping bug
Fixed hardware buttons malfunction bug
General bug fixes
Reaktionen: ger_kar
OxygenOS OpenBeta 4 - Android 7.1.1 eingepflegt.
Changelog OxygenOS OpenBeta 4:
Release notes and feature changes in this Open Beta build:
All new launcher, added support for shortcuts on 7.1.1
Redesigned app drawer
Redesigned UI for launcher settings
Added status bar icon option to display real time network speed
Added Notification Denoising
Added Gaming Do Not Disturb mode
Added automatic Night Mode
Added Secure Box for file encryption
Optimized touch latency
Optimized camera EIS for videos
Improved contacts management with linking and merge functions
Added quick pay option for India
Bug fixes and general improvements
I’d also like to add some basic info for a few of the features that are not self-explanatory.
Spoiler: Basic info
We’ve simplified the Settings options and added another gesture to get to them quickly, a pinch motion from the homepage of your launcher.
Notification denoising
This is to allow priority levels to be assigned to peek notifications and will let you grant only the most important apps and their notifications the ability to interrupt you. This feature can be found under Settings>Device>Notifications
This allows you to lock the capacitive and home buttons while gaming or in other apps where it’s easy to hit those buttons buttons unintentionally. This feature can be found in Settings>Advanced>Gaming Mode
Automatic Night mode
You are now able to set Night Mode to activate and deactivate at a certain time or according to a specific cycle of day and night. This can be found under settings>Display>Night Mode
Secure Box
This is for all files (including pictures and video) that should not be easily accessible to other people. It can be set up with its own pin, and once items are moved (by long pressing and selecting “set as secure” in the settings option) they can only be viewed in the secure box portion of the file manager. This can be found under Apps>File Manager>Secure Box
Quick Pay (India primarily)
This will allow users to set up a QR-based quick pay feature that can be quickly accessed while the screen is either on or off with a long press of the home button. This will only activate right now if one of the following apps is installed: Paytm, Wechat, or Alipay. This can be found in Settings>Security & Fingerprint>Quick Pay
Please make sure you take a bit of time to fill out our survey on UX & UI here: OxygenOS Open Beta build 13 (OP3) and 4 (3T).
The names of some of the new features may change based on your feedback!
Also, remember to tell us about any bugs you may find using the bug report forums, found here.
Please note:
If you have already flashed an Open Beta (you are currently running the latest Open Beta) you will receive this new build as an OTA.
If you ARE NOT running open beta software and would like to, please refer to the flashing instructions found here:
Once you migrate to the Beta path, you will continue to receive Open Beta OTAs. You will NO LONGER receive the regular Official Stable OTAs.
Moving back to the Official OTA path from the Beta path will require a clean flash (FULL WIPE of all data and cache)
If you want to clean flash this build and start beta testing please go here and follow the instructions: OnePlus 3T OxygenOS Open Beta 4
PS: I’m sure you’ve noticed that @Tony L. did not post this. For all future beta build posts, I will be the main point of contact. I’m currently in the process of taking over the Beta Program from him, so he can focus on the MP Early Access Program and future OTA versions of our software.
OxygenOS 4.1.3 - Android 7.1.1 eingepflegt.
Changelog OxygenOS 4.1.3:
Hi all,
We are starting the incremental roll-out of OxygenOS 4.1.3 (7.1.1) OTA for OnePlus 3T.
Increased system stability
General bug fixes
*****Important: Known issues and fixes:
Bluetooth logging issue
For those experiencing bluetooth logging issue on previous 7.1.1 builds, you can free up your storage space by deleting the oem_log folder. Please go to File manager > Storage > oem_log > Delete.
Never Settle.
OxygenOS OpenBeta 6 - Android 7.1.1 eingepflegt.
Changelog OxygenOS OpenBeta 6:
Hello everyone,
It’s update time again! This update includes changes to UI with optimizations for several system apps and bug fixes.
Release notes and descriptions for this Open Beta build:
New dialer and incoming call interface
We created a new answering mechanic to go along with the refreshed UI below: Swipe down to answer and swipe up to reject an incoming call
UI optimizations for Messages, Settings and Contacts
Refreshed UI
New action bar for Messages and Settings
Collapsible and expandable action bar (more to come in the future)
Optimized high power usage notifications
Optimized the system which notifies you when apps are using a lot of battery
Bluetooth optimizations
Night mode optimizations
Bug fixes
Please make sure you take a bit of time to fill out our survey on UX & UI here: OxygenOS Open Beta build 15 (OP3) and 6 (3T).
And please remember to tell us about any bugs you may find using the bug report forums, found here. Bug Reports - OnePlus Forums
Please note:
If you ARE NOT running open beta software and would like to, please refer to the flashing instructions and the full ROM found in the downloads page here: Downloads - OnePlus.net
Moving back to the Official OTA path from the Beta path will require a full install and clean flash (FULL WIPE of all data and cache)
Please let us know how you feel about the beta builds here, we are watching.
OxygenOS OpenBeta 7 - Android 7.1.1 eingepflegt.
Changelog OxygenOS OpenBeta 7:
Hello everyone,
This new update includes optimizations and bug fixes with a new way to report any new crashes and bugs you find.
  • Enabled Bug report feedback app (User Feedback)
  • Fixed duplicate Contacts after upgrading
  • Fixed Contacts search function bug
  • Fixed alarm clock occasionally not ringing
  • Fixed certain app crashes
  • Fixed some display issues with Dark and Light themes
  • Optimized power consumption
  • General bug fixes
OxygenOS OpenBeta 8 - Android 7.1.1 eingepflegt.
Changelog OxygenOS OpenBeta 8:
New additions:
Ambient display 2.0
Lift up display
Sharing functionality for Shot on OnePlus
All new OnePlus Font (Available in English, Chinese, and Japanese only)
UI Improvements:
Gallery v1.7
Recorder v1.6
Weather v1.7
File Manager v1.7
Other UI refinements
Optimizations:
Enhanced launching speed of 3rd-party apps
Optimized management of foreground and background processes
Other changes:
Setup wizard adjusted to suit the style of Android 7.1
Refined contact import process from SIM card, now supports dual numbers and an email address
Automatically add corresponding country codes when making calls during roaming
Updated Android Security Patch level to 1st May 2017
Spoiler: Explanations of features and optimizations
Ambient display 2.0
Lift up display
These two are a new implementation of Ambient display, meant to help stop accidental wakes while pulling the phone out of your pocket. Activation of the screen now requires a “double tap” action. While lift up display does exactly what it says, it turns on the screen to peek at notifications when the device is lifted.
You are now able to share the cool pictures you find in the Shot on OnePlus section in wallpapers
There is now a Font switcher setup in settings.
Things are faster now..
Please make sure you take a bit of time to fill out our survey on UX & UI here: OxygenOS Open Beta build 17 (OP3) and 8 (3T).
Please note:
  • Hondabiker
schnueppi
schnueppi
schnueppi
schnueppi
schnueppi
TomTim
rotkreuzhelfer
