serv-r
Hallo Neptune23, danke für Info.
Da steht HTC-T002-V0- das heißt das die Software für MK809 Passt- sehr überaschend gut! hab den für 45 eur gekauft inkl. versand von deepin-de !!!
Die Flashanleitung über MK809 / T002 Smart TV (Typ HTC-T002-V0) stimmt nicht so ganz im vorherigen Beitrag.
und die beiden Links von "Tool & kurze Anleitung, Treiber" funktionieren nicht.
Anleitung
[Rooting]
Only needed if you want to run root access apps (Driodmote, VNC server, Set DNS etc..)
I followed the instructions on XDA Developers but ran in a little problem so I've rewrote them here.
1) Install Android SDK - Install only the 2 support packages - USB Drivers and platform support. - Download here
Edit you system variables PATH string (located under system properties) and add on the <Andriod SDK> - platforms-tools directory
2) Download the attached files on the forum post ***
3) Add lines to the file located in <Your Android SDK location>\extras\google\usb_driver\android_winusb.inf
Under the [Google.NTx86] and [Google.NTamd64] section:
Code:
; WINDOW/YUANDAO MK809
%SingleAdbInterface% = USB_Install, USB\VID_2207&PID_0010
%CompositeAdbInterface% = USB_Install, USB\VID_2207&PID_0010&MI_01
4) Connect the USB DC port to your computer USB port (I found using my laptop with the TV stick still in the television the easiest way to do this)
5) Once the MK809 is powered up turn on USB Debugging under Developer Settings and allow installations from unknown sources under Security settings.
6) Start the Installation of the PDA.net (ADBDriver) drivers.
Select Other for the type of device you have when prompted.
When prompted to plug your device use the "Connect to PC" option under Settings->USB on your MK809.
In the android status bar a little Jelly Bean icon should display saying you are debugging applications via. USB.
Close down the PDA.net driver program that is now running in your Windows system tray.
7) Extract the TPSarky 7zip file and run the TPSarkyRoot.bat
This will reboot the device 3 times, after each reboot you need to go back in to settings > usb > Connect to PC. before continuing.
If this worked, Your Rooted!
8) Visit the app store and install Super User.
Das ist nur Copy Past Anleitung von XDA... , nach der Anleitung habe ich meine Software gerootet- hat gut funktioniert, trotz dem übernehme ich keine haftung über ev. enstehende Schäden.
MFG
Anleitung
[Rooting]
Code:
MFG
