Honor 3C Geteste Customroms von XDA
  • 11 Antworten
Huayra
Gast
Ich habe gerade Custom Roms gefunden, die der XDA User Codelover bereits getestet hat.
Getestet hat er bisher*
[FONT=Hind, sans-serif]MIUI v5 v4.10.3[/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif]
[/FONT][/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif]LewaOS[/FONT][/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif]
[/FONT][/FONT][/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif]ColorOS 1.0[/FONT][/FONT][/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif]ColorOS 2.0[/FONT][/FONT][/FONT][/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif]AOSP Nexus*[FONT=Hind, sans-serif]Themed[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
[FONT=Hind, sans-serif]Android L Themed[/FONT]
[FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif][FONT=Hind, sans-serif]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[FONT=Hind, sans-serif]Lexus[/FONT][FONT=Hind, sans-serif]/[/FONT][FONT=Hind, sans-serif]EMUI 3.0[/FONT]
Folgende Hinweise dazu
[FONT=Hind, sans-serif]RECOMMENDED STEPS FOR ROM FLASHING USING TWRP[/FONT]
[FONT=Hind, sans-serif]WARNING[/FONT]
[FONT=Hind, sans-serif]* This guide is applicable for*clean installation*ONLY, might not be suitable for upgrade.
* Part #1 is*required*if you are using my ported recoveries like TWRP 2.8 which is optimized for Intl. set.
* Part #1 is*not needed*if you are using CWM v5.x by rua or TWRP for chinese set ported by @flufytendo.
* DO NOT replace 'update-binary' if the ROM is using AROMA-INSTALLER! ('update-binary-installer' maybe? TBC)
* DO NOT replace 'update-binary' in other non-rom updater zip, it's optimized for ROM installation zip only.
* DO NOT use my patched 'update-binary' on device other than Honor 3C 3G, it might be harmful to other device.[/FONT]
[FONT=Hind, sans-serif]Prerequisites[/FONT]
[FONT=Hind, sans-serif]* Make you have a zip archive program installed. ([/FONT][FONT=Hind, sans-serif]7-Zip[/FONT][FONT=Hind, sans-serif], WinRAR, WinZip, etc)[/FONT]
[FONT=Hind, sans-serif]* Make sure you have created backup for your files stored in your phone internal storage.[/FONT]
[FONT=Hind, sans-serif]Part #1 (Modify the ROM to be compatible with my ported TWRP)[/FONT]
[FONT=Hind, sans-serif]1) Create a new folder, download the custom ROM you want to try/use and place it inside the new folder.[/FONT]
[FONT=Hind, sans-serif]2) Download my patched*[/FONT][FONT=Hind, sans-serif]update-binary[/FONT][FONT=Hind, sans-serif]*.zip and extract it to above folder, you should have '[/FONT][FONT=Hind, sans-serif]update-binary[/FONT][FONT=Hind, sans-serif]'.[/FONT]
[FONT=Hind, sans-serif]3) Open the ROM with your zip program, navigate to '[/FONT][FONT=Hind, sans-serif]META-INF\com\google\android[/FONT][FONT=Hind, sans-serif]'.[/FONT]
[FONT=Hind, sans-serif]4) Drag & drop the extracted '[/FONT][FONT=Hind, sans-serif]update-binary[/FONT][FONT=Hind, sans-serif]' &*[/FONT][FONT=Hind, sans-serif]REPLACE[/FONT][FONT=Hind, sans-serif]*with the existing one, answer '[/FONT][FONT=Hind, sans-serif]YES[/FONT][FONT=Hind, sans-serif]' if prompted.[/FONT]
[FONT=Hind, sans-serif]5) Drag & drop my fixed '[/FONT][FONT=Hind, sans-serif]updater-script[/FONT][FONT=Hind, sans-serif]' if there is one provided for the*[/FONT][FONT=Hind, sans-serif]target[/FONT][FONT=Hind, sans-serif]*[/FONT][FONT=Hind, sans-serif]ROM.[/FONT]
[FONT=Hind, sans-serif]6) Connect your phone to pc and copy the modified ROM to external storage. ([/FONT][FONT=Hind, sans-serif]MicroSD[/FONT][FONT=Hind, sans-serif]*[/FONT][FONT=Hind, sans-serif]Card)[/FONT]
[FONT=Hind, sans-serif]7) Also copy '[/FONT][FONT=Hind, sans-serif]UPDATE-VersionJumper*.zip[/FONT][FONT=Hind, sans-serif]' if your*[/FONT][FONT=Hind, sans-serif]target[/FONT][FONT=Hind, sans-serif]*[/FONT][FONT=Hind, sans-serif]ROM version is different from your current ROM, eg: 4.4 -> 4.2[/FONT]
Übersetzung durch TSC Yoda:
Empfohlene Schritte zum Flashen via TWRP
WARNUNG:
Diese Anleitung gilt nur für Neuinstallationen, für Updates ist dies möglicherweise nicht machbar
Teil #1 ist erforderlich, wenn meine portierte Recovery wie "TWRP 2.8" verwendet wird
Teil #1 wird nicht benötigt, wenn CWM v5.x von @rua oder TWRP portiert für chinesische Sets von @flufytendo verwendet werden
NICHT die "update.bin" ersetzen, wenn Aroma-Installer gebraucht wird
NICHT die "update.bin" ersetzen in einer anderen Nicht-Rom-Updater-Zip, sie ist nur für die Rom-Installation-Zip geeignet
NICHT meine gepatchte "update.bin" für ein anderes Gerät als das Honor 3C 3G benutzen, es könnte Schäden am Gerät geben!
Voraussetzungen:
installiertes Zip-Archivierungsprogramm
sicherstellen, dass ein Backup aller relevanten Daten im Gerät angelegt wurden
Vorgehensweise
1. neuen Ordner erstellen, die gewünschte Custom-Rom downloaden und diese im neuen Ordner ablegen
2. meine gepatchte "update-binary.zip" downloaden und im oben genannten Ordner entpacken, es sollte ein "update-binary"-Ordner erscheinen
3. die Rom mit dem Zip-Programm öffnen, zu "META-INF\com\google\android" navigieren
4. "update-binary" austauschen
5. mein gefixtes "updater-Script" einfügen, falls es dies für die Ziel-Rom gibt
6. Gerät mit dem Rechner verbinden und die Rom im externen Speicher (Micro-SD-Karte) ablegen
7. auch "UPDATE-VersionJumper.zip" kopieren, falls die Systemversion unterschiedlich sind (Bsp. 4.4->4.2)
[FONT=Hind, sans-serif]Part #2 (Installing the custom ROM)[/FONT]
[FONT=Hind, sans-serif]1) Boot into TWRP. (Note: If you can''t use LiveTWRP, flash it to device.)[/FONT]
[FONT=Hind, sans-serif]2) Enter [[/FONT][FONT=Hind, sans-serif]MOUNT[/FONT][FONT=Hind, sans-serif]] menu -> umount all*[/FONT][FONT=Hind, sans-serif]except[/FONT][FONT=Hind, sans-serif]*'[/FONT][FONT=Hind, sans-serif]MicroSD[/FONT][FONT=Hind, sans-serif]' and '[/FONT][FONT=Hind, sans-serif]cache[/FONT][FONT=Hind, sans-serif]' partition; Disable MTP (If enabled),*[/FONT]
[FONT=Hind, sans-serif]3)*[/FONT][FONT=Hind, sans-serif]<-[/FONT][FONT=Hind, sans-serif]*[[/FONT][FONT=Hind, sans-serif]Home[/FONT][FONT=Hind, sans-serif]], enter [[/FONT][FONT=Hind, sans-serif]Wipe[/FONT][FONT=Hind, sans-serif]] menu -> [[/FONT][FONT=Hind, sans-serif]Format Data[/FONT][FONT=Hind, sans-serif]]. (Note: Type 'yes' to continue)[/FONT]
[FONT=Hind, sans-serif]4)*[/FONT][FONT=Hind, sans-serif]<-[/FONT][FONT=Hind, sans-serif]*[[/FONT][FONT=Hind, sans-serif]Home[/FONT][FONT=Hind, sans-serif]], enter [[/FONT][FONT=Hind, sans-serif]Settings[/FONT][FONT=Hind, sans-serif]] menu -> [[/FONT][FONT=Hind, sans-serif]Restore Defaults[/FONT][FONT=Hind, sans-serif]] (Note: Reset TWRP settings)[/FONT]
[FONT=Hind, sans-serif]5)*[/FONT][FONT=Hind, sans-serif]<-[/FONT][FONT=Hind, sans-serif]*[[/FONT][FONT=Hind, sans-serif]Home[/FONT][FONT=Hind, sans-serif]], enter [[/FONT][FONT=Hind, sans-serif]Install[/FONT][FONT=Hind, sans-serif]] menu, navigate to*[/FONT][FONT=Hind, sans-serif]/external_sd/[/FONT][FONT=Hind, sans-serif], select your custom ROM .zip[/FONT]
[FONT=Hind, sans-serif]6) Make sure zip md5 verification turned off, then follow on-screen instructions to install the ROM.[/FONT]
[FONT=Hind, sans-serif]7) Install any necessary add-on package, like VersionJumper, SuperSU, gapps, etc.[/FONT]
Teil 2 (Instalation der Custom-Rom
1. in TWRP booten (wenn LiveTWRP nicht geht, dies aufs Device flashen)
2. ins MOUNT-Menü gehen -> alles außer MicroSD und Cache-Partition unmounten, MTP auschalten, falls eingeschaltet
3. zurück auf Home, dann ins Wipe-Menü und FORMAT DATA
4. zurück auf Home, dann in Settings und Restore Defaults
5. zurück auf Home, dann in Install, zur externen SD-Karte navigieren und die Rom-Zip auswählen
6. Sicherstellen, dass MD5-Check ausgeschaltet ist und den Instruktionen am Bildschirm folgen
7. alle benötigten Add-Ons installieren (wie VersionJumper, SuperSU, gapps,...
Hier der Link zu den Roms
Roms
Vielen dank an Polluxx ;)
Hallo Huayra,
bitte beachte, dass wir hier in einem deutschsprachigen Forum sind.
Ich bitte dich daher, die Texte zumindest so weit zu übersetzen, dass auch User ohne Englischkenntnisse deinen Thread verstehen können.
Dazu entsprechender Auszug aus den Forenregeln:
Themen/Beiträge in deutsch:
Wir sind ein deutschsprachiges Forum, weshalb auch alle Beiträge und Themen in deutsch zu verfassen sind. In Ausnahmefällen (z.B. dann wenn die Übersetzung durch technische Hilfsmittel erfolgt ist und daher Fehler bzw. Missverständnisse zu erwarten sind) kann der original- bzw. englischsprachige Text beigefügt werden.
Danke
Ich kümmer mich heute abend darum
Ich wollte euch gerade ein paar erfreuliche Nachrichten mitteilen.
Nach dem qu4nd oben eine gelbe Ampel zeigte, spar ich mir die herausgesuchten links.
Es gibt zahlreiche ROMs, in einem russischen Forum, die verstärkt entwickeln, modden und aktualisieren. Einige habe ich die letzten Tage getestet. Funktionieren alle soweit gut. Der Rest ist pure Geschmackssache.
Ich kann kein russisch, dem nach kann ich es auch nicht übersetzen. Auch ohne größere Sprachkenntnisse ist man(n) in der Lage, von dort eine ROM herunterzuladen und zu flashen.
Dalet11 EMUI3.0 ist nicht die einzige ROM, die als Alternative zur Stock in Frage kommt und an der herumgetrampelt werden muss :)
Ich habe jetzt den Startpost mit einer Übersetzung versehen.
Du hast Dich trotz mehrmaliger Aufforderungen nicht um eine Übersetzung gekümmert!
Beim nächsten Mal wird KOMMENTARLOS gelöscht!
Markus (Super-Moderator)
Reaktionen: Giorgo und qu4nd
Hat jemand schon paar dieser roms probiert und kann berichten?
Hab jetzt 1 tag die neue 2.5 von dalet11 drauf und bin eigentlich zufrieden...
Aber evtl verpass ich was besseres :)
Wie ist zb die miui?
Ja, habe alle durchprobiert.
Die Downloadlinks zeigen auf ein Forum, mit weiteren gemoddeten.
Am saubersten ist die Google KK 4.4.2 von RMG/Win-ter. Stand 12.12.2014, trägt im Dateinamen ein 'clean'.
Und die HTCSense ist auch prima, allerdings nur EN.
Alle anderen sind grafisch toll aufbereitet, basieren allerdings auf der StockROM. Teilweise mit China-Zeug, teilweise Russisch. Bei denen braucht man noch eine Tastatur. Eigentlich alles kein Problem.
Geschmackssache
Hab mein Honor noch nicht.
Wars schwer die Roms aufzuspielen?
Danke fürs Feedback.
Konntest du auch diese MIUI V6 probieren, glaube dieser Winter hat auch ne beta davon gepostet gehabt. Miuiv6_Beta4_H30-U10_5.1.29
wie habt ihr das gemacht?
ich komm nicht mal zum downloadlink
keine Chance, ich kann weder russich noch chinesich
*kopfschüttel* wozu postet man per c/p einen Beitrag, aus einem anderen Forum, wenn man damit nicht umgehen kann? Und auch nicht beachtet, wenn drunter steht, bitte nicht weiterverteilen und direkt verlinken? *kopfschüttel*
Nun fange ich an, zu verstehen warum Ampeln geschaltet werden.
Also, Du klickst den Link an (Überschrift oberhalb der Bilder). Dann landet man irgendwo auf einem Thread im Forum. Scrollt hoch auf den 1. Beitrag. Klappt den/die Spoiler auf. z.B. Прошивки 4.2.2 oder Прошивки 4.4.X. die Lateinische Buchstaben und Zahlen kann man ja ohne Probleme erkennen und zuordnen. Und voila, unten drunter ist der finale Downloadlink auf einem Filehoster.
Oder alles aufklappen, irgendwo rumklicken, alles runterladen, irgendwann findet sich irgendwo schon die ROM.
Oder man schaltet die Google-Webseitenübersetzung ein und kommt mit gebrochenen Automatendeutsch klar.
Viel Glück.
Hat von euch jemand die miui v6 probiert und kann sagen wie die läuft und ob deutsch dabei ist?
Hab von xda die v5 geladen und diese lief ganz OK aber hatte kein deutsch...
Kann ich sie deutsche Sprache irgendwie nachträglich einfügen?
