*HILFE**_HTC 10 ohne OS....Flash Probleme
  • 5 Antworten
boto2000
Liebes Forum ich bin mit meinem Latein am Ende.
Mein HTC 10
  • S-OFF
  • TWRP geflasht
  • auf HTC__001 gewechselt (ehemals O2)
  • MicroSD
  • kein OS vorhanden
ALT
C:\HTC>fastboot getvar all
(bootloader) kernel: lk
(bootloader) product: htc_pmeuhl
(bootloader) version: 1.0
(bootloader) imei: 354261072171614
(bootloader) version-main: 1.95.206.3
(bootloader) boot-mode: download
(bootloader) version-baseband: 1.0.U010141a@60714.2
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PS620000
(bootloader) cid: O2___102
all:
finished. total time: 0.095s
NEU
(bootloader) max-download-size: 1578400000
(bootloader) serialno: FA655BN03681
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) version-main: 3.16.401.2
(bootloader) boot-mode: RUU
(bootloader) version-baseband: 2.0.U010241a@71204
(bootloader) cid: HTC__001
all:
finished. total time: 0.362s
C:\HTC>fastboot flash zip PMEUHL_3.16.401.2_FullStock.zip
target reported max download size of 1578400000 bytes
sending 'zip' (113493 KB)...
OKAY [ 6.498s]
writing 'zip'...
(bootloader) HOSD CL#1012001
(bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408]
(bootloader) Perform pre-update
(bootloader) WARN Skip partition_info due to unmatched partition name
(bootloader) WARN Skip lockbooter.img due to unmatched partition name
(bootloader) WARN Skip backup_android-info.txt due to unmatched partitio
(bootloader) n name
(bootloader) get 35 images from zip(zip_type=3)
(bootloader) start@35
(bootloader) splash1.nb0@BYPASS
(bootloader) usb_typec_otp_ad.img@BYPASS
(bootloader) rcdata.img@BYPASS
(bootloader) slpi.img@BYPASS
(bootloader) hyp-8996-1.img@100%
(bootloader) modemst1.img@BYPASS
(bootloader) lksecapp.img@100%
(bootloader) pmic-8996-1.img@100%
(bootloader) keymaster.img@100%
(bootloader) devcfg-8996-1.img@100%
(bootloader) aboot_signed.img@100%
(bootloader) xbl-8996-1.img@100%
(bootloader) boot_signed.img@BYPASS
(bootloader) dsp.img@BYPASS
(bootloader) hosd_signed.img@100%
(bootloader) tp_SYN3708.img@BYPASS
(bootloader) rpm-8996-1.img@100%
(bootloader) cmnlib64.img@100%
(bootloader) tz-8996-1.img@100%
(bootloader) venus.img@BYPASS
(bootloader) adsp.img@BYPASS
(bootloader) usb_typec_otp.img@BYPASS
(bootloader) pg2fs_ship_signkey.img@100%
(bootloader) rfg_3.img@BYPASS
(bootloader) cmnlib32.img@100%
(bootloader) recovery_signed.img@BYPASS
(bootloader) dzdata_32g.img@BYPASS
(bootloader) sensor_hub.img@BYPASS
(bootloader) cota.img@BYPASS
(bootloader) cache.img@BYPASS
(bootloader) fsc.img@BYPASS
(bootloader) cs_CY8C.img@BYPASS
(bootloader) modemst2.img@BYPASS
(bootloader) apdp-8996-1.img@BYPASS
(bootloader) radio.img@BYPASS
FAILED (remote: 90 hboot pre-update! please flush image again immediately )
finished. total time: 8.875s
OKAY [ 5.986s]
writing 'zip'...
(bootloader) n name
(bootloader) splash1.nb0@100%
(bootloader) rcdata.img@100%
(bootloader) slpi.img@100%
(bootloader) modemst1.img@100%
(bootloader) boot_signed.img@100%
(bootloader) dsp.img@100%
(bootloader) venus.img@100%
(bootloader) adsp.img@100%
(bootloader) rfg_3.img@100%
(bootloader) recovery_signed.img@100%
(bootloader) dzdata_32g.img@100%
(bootloader) cota.img@100%
(bootloader) cache.img@29%
(bootloader) cache.img@58%
(bootloader) cache.img@88%
(bootloader) cache.img@100%
(bootloader) fsc.img@100%
(bootloader) modemst2.img@100%
(bootloader) apdp-8996-1.img@100%
(bootloader) radio.img@100%
(bootloader) Update zip file OK
(bootloader) end@Done
OKAY [ 16.291s]
finished. total time: 22.286s
C:\HTC>fastboot flash recovery twrp-3.2.1-4-pme.img
sending 'recovery' (56580 KB)...
OKAY [ 3.443s]
writing 'recovery'...
(bootloader) start@1
(bootloader) recovery@100%
(bootloader) Update partition OK
OKAY [ 2.241s]
finished. total time: 5.691s
gerne würde ich das HTC 10 OREO aufspielen....
benötige Hilfe bei:
  1. Link zur Datei *.img/*.zip (passend zu meinem Handy) ?
  2. Passende Anleitung zum Flashen
  • Im Downloadmode?----
  • Im Bootloader Modus?----
  • passende fastboot Befehle bzw. Toolkit für RUU (falls bei mir möglich)
Ich wäre sehr dankbar wenn ich mein HTC wieder zum Leben erwecken könnte.
Was ist passiert, da kein OS mehr drauf ist? Kannst du ein Bild vom Downloadmodus machen?
Reaktionen: boto2000
Hatte ein CustomRom drauf "welches?- keine Ahnung mehr"
Batterie bis zum letzten Tropfen ausgesaugt.....HTC geladen ....Android gibt verschiedene Fehlermeldungen raus...
APK werden beendet etc. ,
kurzerhand beschlossen das Handy neu zu flashen um die nervigen Beendigungen aus dem Weg zu räumen.
Fehler gemacht.......beim flashen!!
C:\HTC>fastboot flash zip 2PS6IMG_PERFUME_STB01
error: cannot load '2PS6IMG_PERFUME_STB01': No such file or directory
C:\HTC>fastboot flash zip 2PS6IMG_PERFUME_STB01.zip
Invalid sparse file format at header magic
error: write_sparse_skip_chunk: don't care size 733480062 is not a multiple of the block size 4096
sending sparse 'zip' 1/2 (1048572 KB)...
OKAY [ 57.815s]
writing 'zip' 1/2...
(bootloader) ERR lzipv2_init : Cannot open file /dev/fastboot_download_p
(bootloader) lBOm8
(bootloader) ERR [SD_UPDATE_ERR] update_fb_ZIP_buf: can not find ZIP hea
(bootloader) der
(bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 22
(bootloader) ERR Update zip file failed.
(bootloader) ERR ZIP ERROR, exit read zip loop
(bootloader) ERR ZIP ERROR CODE, 22
FAILED (remote: 22 RU_HEADER_ERROR )
finished. total time: 59.158s
und jetzt stehe ich hier!!!!
Da du ja TWRP drauf hast, warum flashst du nicht wieder eine Custom- Rom. Nur damit das Gerät erst mal wieder läuft. Oder willst du wieder die Stockrom haben?
@rolkeg
siehe da....vor lauter Bäumen sehe ich den Wald nicht mehr.
Hast Recht ...ich werde ein Custom- Rom ziehen und flashen....
danach kann ich in Ruhe erlernen wie ich zurück zum Stockrom komme....
Ich gehe mal ans WERK.....Informiere nach Erfolg
Zur Stockrom über SD Karte Methode ist ganz leicht. Kannst S-OFF und offenen Bootloader lassen. Nur wenn du das Gerät verkaufen willst, würde ich den Bootloader schließen und S-ON gehen. Melde dich wenn du Fragen hast.
